AllStar Welding
    1
Everything posted by AllStar Welding
  1. That is not correct, If I am reading your response right. if not, then i apologize. When I use my rosebud on my oxy/propane, my O2 is on about 10psi, and propane at about 3-5psi. I light it the same as I always do. once lit, you have to turn the fuel down until it barely kisses the tip. then add Ox, then more gas, then Ox again until the little cones are close to 1/2" long. I regularly heat 5/8" rod to bend. it takes about 20 seconds to get cherry red. I use this setup nearly everyday in my shop. works very well.
