If I am understanding things correctly, a 5gpm pump is adequate for doing the actual work but not efficient practically in terms of getting the ram to and from the work?
I have done some research on valving circuits and discovered the regeneration circuit which in essence can negate the bore size and run a cylinder with less force at the speed of a cylinder with a bore the diameter of the the rod, of course with correspondingly less force. Then it can switch back using the cylinder in a normal fashion at slower speed and higher force.
Here is a link to a very good example, ( and much better explanation!) My link.
Does anyone have any thoughts if this could work and be a good set up? I like the idea of an adjustable displacement pump with on demand pressure explained above. It could also mean I could get this power unit for the $250 i metioned earlier and spend more doe on the frame and dies! Thanks for your opinions!
