664 -
Posts posted by M.J.Lampert
these puns are the cutting edge
thank you Steve i have read some of Glenn's post where he shared some of Mr. Hofi's knowledge
Seb, yes the hole on the tapa is for the switch of an adjustable snare that I have built off of different designs I saw on YouTube
M.J.Lampert
what was his username on here?
praying for his family
so this cutie came into the family and has her bother (me) on cloud 9. Sonya Naomi
also some more progress on the Cajon, I am thankful that wood can have dents steamed out
a bunch more parts finished just have the main box to finish now, got 1 coat on the inside and might get the second tonight
M.J.Lampert
4 hours ago, Irondragon ForgeClay Works said:
A bolt of lightening hit so close to the house out in the woods the instantaneous clap of very loud thunder rattled the windows, convinced Axle and I to retreat into the house
one time me and some friends were messing around on the baseball Dimond and we had a strike that hit close enough to stand your hair on end.
last year I was pressure washing a piece of equipment during a rain shower when we had a lightning strike that I am certain was under 1 km away, the silo they stored the cement powder was pouring dust through the vents because of the shock wave, way too close for comfort
M.J.Lampert
great to see this expert out in the shop again
not sure if i want to embarrass myself that bad
some more progress pics on the Cajon
gluing the bottom on
the tapa (front) 1/8th Birch plywood cut and drilled
the top being glued on
a problem I had last night was that the brass screws are snapping before they get tight I pre-drilled to the specs on the package for hardwood (3/32nds) and it is drilled deeper than the length of the screw i had the clutch on the drill at 4 so it should have been low torque.
also just how bad I am at making things square
finally a mock up of what it will look like (before finishes applied)
have a great weekend
M.J.Lampert
5 hours ago, gewoon ik said:
Does a punch needs to be hardened?
someone will probably come along and quote a source but my understanding is that tools used for hot work don't get hardened because their use tempers them to a point where the hardening is lost, cold chisels on the other hand would be hardened
just my understanding of the little I've read
M.J.Lampert
looks better than I could do. I know at that age I would have loved something like that.
beautiful, reclaimed wood is so nice I'm glad its the "in thing" right now
njanvilman every time you post I know I will get a case of anvil envy but this one takes it to a new level.
Thank you for rescuing all these timeless artifacts. If only each one could tell their story...
Thomas if i was closer i would enjoy being a minion and a remover of unneeded tools i am certain i could put them to great use
on the other hand I hope you are around to use them for many more years
there's an old article by arki that shows some different designs in this section but not really a tutorial
updated logo to closer refer to such a name see profile picture
thanks all
George I didn't think of that, as I would've considered it Cultural Appreciation as it is recognizing a landmark, but I guess these days even if you don't offend the people its concerning someone else will be offended for them
messing around online the closes thing I could find was a Tundra Mountain ranch in Colorado. I checked on the BC name request registry and there was 24 names coming up that started with Tundra but nothing close, for some reason if I turned it from ironwork to blacksmith or blacksmithing they turned up no similar results. also found I could end it with "Co."
thus there is in my mind now preferred ideas, though I prefer the first i am open to others ideas.
Tundra Mountain Blacksmithing
Tundra Mountain Blacksmith Co.
M.J.Lampert
so i was looking at a map book near an area that I had been in and noticed this place thought it was an interesting place
this got me thinking that perhaps my name choice of Two mountains Ironwork which was meant to be describing an imaginary point in my mind but i recently found that that is the translation of a town in Quebec (Deux-Montagnes) so I decided to think of a Place that holds more significance to me while still keeping the touchmark so my mind when to my grandparents ranch at the base of the Ilgachuz Range so I decided to have a look and the closest peak in that system is Tundra Mountain.
now the reason I posted all this is I'm trying to decide between Ilgachuz Range Ironwork or Tundra Mountain Blacksmithing both which turn up nothing close in web searches
tia
M.J.Lampert
ps. ilgachuz
no matter what you made a fine knife and learned lots for the next one
17 hours ago, Irondragon ForgeClay Works said:
But, but, but how do you give someone a penny for their thoughts or throw in your two cents worth on a subject.
if we really want your thoughts we'll give ya a loonie, if we think your absurd we'll call you loonie
my projects/rambling/ other (pic heavy)
in Member Projects
Posted
warning pic heavy
the Cajon is now finished
a look at the internal snare mechanism. a 2" drum snare cut in half and attacked
will post a video in the next couple days
M.J.Lampert
