Charlotte
1,469 -
Everything posted by Charlotte
Excellent
- 6 replies
- liner lock
- padouk
Is a $140 hammer really that much better than a $40 hammer?
Charlotte replied to Pancho07's topic in Hand Hammers
Daswulf 's .02 cents is worth a lot more than that IMHO. I've collected a bunch of hammers over the years. Each one has its special characteristic in shape, weight and balance. To this day I still prefer one of the first hammers I acquired. I paid $2.00 that day It was used by the CCC prior to WW2 I have dressed the face and the pein and rehandled a couple of times. I got it at a country auction around 1961. The prior owner worked for the CCC (Civilian Conservation Core). My # 2 hammer is a Hofi Hammer bought here. It seems to me that a $140 driving hammer custom made for a Farrier might be justified. They have special requirements for their work. For general beating on iron the hammer is chosen mostly by what seems to fit the job you are doing atm. Personally I spread the same money over a number of hammers. -
I was talking to a corporate VP and he interrupted to my answer to his elementary question with " I Know" I responded to his eruption with " If you knew the answer you wouldn't have asked the question" My career did not prosper after that. Gave me a lot of satisfaction at the time though.
Hardies I've always used what ever Jack Hammer bit was available. driven punches I use cheap import sets for non critical sizes. Hot work carving or exact hole dimensions I use H13 because I can forge or grind thinner and more precisely with the expectation tool will hold its shape. I have also spoiled more than one piece of H13 by over heating while forging.
Actually, the above applies to a lot of work done by independent craftspeople. Product Liability adheres to a lot of smith work.
What are these things for?
Charlotte replied to Mountainhouseforge's topic in Tools, ID, and pictorial reference
I used a tool very similar to that to stretch brake springs when changing shoes. -
The above MFG calls their blanket INSWOOL-HP BLANKET INQUIRE Ceramic Fiber BlanketIron Steel Ferrous Foundry Copper/Nickel and other EEC Cement/Lime Glass INSWOOL-HTZ BLANKET INQUIRE Ceramic Fiber BlanketIron Steel Ferrous Foundry Copper/Nickel and other
Ceramic blanket is the usual term when talking to Mffg. There are different grades according to temp ratting. Depending of your intended max heat and time at heat different strengths are required. FASKAST 80 Castable Alumina, High Steel Ferrous Foundry KAST-O-LITE 20-45 G PLUS Insulating Monolithic 2000F Ferrous Foundry EEC Cement/Lime KAST-O-LITE 22 G PLUS Insulating Monolithic 2200F Iron Steel Ferrous Foundry Copper/Nickel and other EEC Cement/Lime KAST-O-LITE 26 LI G ON-LINE Insulating Monolithic 2600F To the best of my knowledge Kast-o-Lite is not a cement but a refractory clay composite. The above is from product catalogue http://www.anhrefractories.com/refractory-products
One inch thick refractory cement is way thick. Cement is not the same thing as refractory liner. A thin coating will last as long or longer than a thick coating. Most folks apply a coating of hardener to the inside surface followed by thin coatings of cement and reflective coatings. Frosty recommends, and I have found that a piece of ceramic kiln shelf in the bottom works well to ease the wear and tear.
Cobalt Drills are a good investment when drilling alloy steels. I keep three sets to drills. One hardware store quality for wood and casual handyman work. A better quality of highspeed steel with better sharpening for mild steel. Cobalt drills bought one at a time from machine shop supply houses. The above suggestions need to be followed carefully.
Your wife is very fortunate to have such a lovely gift. I know she is extremely pleased!
Forging is usually done on about 6" long area at one time. Long pieces tend to bend. One of my friends builds beds with Iron head and foot boards. He lays out his pattern on a platen table, puts clamps and fixed points at critical points then bends the pieces with a big propane heating torch to his pattern. Even heavy stock bends like candles left out in the hot sun when heated. I've seen vids of a big time famous sculptor bending long pieces from a long oven but he had a crew to help him handle the long red hot spaghetti.
http://www.pineridgeburner.com/
And still he/she stands His/her brow is wet with honest sweat, He/ she earns whate'er we can, And looks the whole world in the face, and wonders that so few understand
Read the Info on the supplier site. but length seems a little long for even heat
Acetylene produces a hotter flame because of the energy stored in the triple bond between the two carbon atoms. Unit cost of propane is substantially less than acetylene pre BTU. I use the same tips for silver soldering and brazing that I use with acetylene when doing small, pinpoint, jobs. The metallic working end units of acetylene equipment can be used with propane but they don't work as well. If I had invested in propane equipment I would use the same brand tips provided by the manufacturer. For larger jobs I have seen hard silver solder joints in stainless steel done with propane air, Turbo torch, units. All things in fuel rigs depend on exactly what you are doing to determine what the best is
Whimsy, I love your vision.
- 35 replies
- rabbit
- run rabbit
Mild steel works adequately for many purposes. Tongs made with better grades of steel tend to be lighter. But starting out you can work for a long time with mild steel. There are many examples of people making small but serviceable tongs out of railroad spikes. People have also made tongs with rebar. If you have access to a welding machine people often forge the jaws from heavier stock and weld on lighter handles.
Peabody Energy, one of the world's biggest producers of coal, has warned that it is at risk of going bankrupt in the very near future, thanks to a lack of "sufficient liquidity to sustain operations and to continue as a going concern" caused largely by the continuing downturn in the coal mining industry. In a regulatory filing on Wednesday, the US-based producer said: "There can be no assurance that our plan to improve our operating performance and financial position will be successful." Peabody has undertaken a huge program of cost-cutting in recent years to stave off a massive crash in the price of the commodity. The above appeared in a business article today. Many of us have experienced difficulty is obtaining "smithing grade coking coal" It actually looks like our difficulties will continue to increase. I posted this for your information.
Grandad used coat hanger. He was kind of sneaky, They never knew they were on the way to dinner until it was too late.
Forging Carver you missed the point. With that plate he can bend around a variety of different points. He can add additional points as he needs them by drilling more holes.
I totally agree and would like to add that since the human eye has tricks in evaluating color, if you start with #3 shade welding safety glasses in polycarbonate material, you will have a consistent evaluation of color. Polycarb safety glasses absorb both UV and Ir
- 31 replies
- horizontal
- refractory cement
(and 4 more)
Not all Peanut Oil is really peanut oil. I have friends that have gotten caught out with Oil that flashed when frying turkeys when the temperature said it should be ok. Suspect that it was adulterated with cotton seed oil. Really, the recommendations by the knifemakers to use real quench oil are what I would follow. The only benefit of using grocery store oils is convenience. Since veg oils go rancid quickly when exposed to air and grow things in the long run well thought out quench tanks and purchases of commercial oil is the was to go. That is my opinion but of course I don't make knives for anybody but my self and family.
Mark Aspery describes creating a "portable Hole" for use in creating shouldered anvil tools. Chapter 16 : Anvil Bottom Tools The Skills of a Blacksmith, Volume I, Mastering the Fundamentals of Blacksmithing WWW.markaspery.net
