Whiskeymike
Content Count
75 -
Calendar
Everything posted by Whiskeymike
I'm wondering how the temperature of the oven relates to the material temperature and if they are always the same once the right amount of time has past. So for instance, if you need to heat treat steel at 500 degrees for 8 hours, you set your oven to 500 degrees - 1. Is there a rule of thumb of how long it will take the steel to come to 500 degrees? 2. If the steel was in the oven when you started the oven to rise to 500 degrees, when the oven hits 500 degrees, does that mean for relative certainty that the steel is also at 500 degrees? Or by scientific principles, will
Raise/Lower BBQ Grill - designs?
Whiskeymike replied to Whiskeymike's topic in Blacksmithing, General Discussion
Much appreciated folks. -
Perhaps this is a modern invention with no roots to the past. I found this when searching - But I don't see any ratchet. It seems to be a pin in his hand that just inserts to stop the wheel. it also looks like something made from previous parts, but not in the pioneer period. I assumed there was similar mechanisms used in fireplaces, but perhaps they were all trammel hooks or a form of it. -
I'm looking to make a gaucho/wagon wheel grill where you raise/lower the grill from the fire and wondering if anyone has seen blacksmithing designs for the ratcheting portion. It would be similar to these parts, but I'd like to stay fairly authentic. So if someone know of a 1800's/early 1900's reference material to such a thing, I'd appreciate a pointer.
Another one. https://www.tapatalk.com/groups/paleoplanet69529/making-bolsters-from-plumbing-caps-pic-heavy-t22661.html.
Thanks for the suggestions. The full tang with scales is a good idea for hand tools. Although the items I have in mind are about a 3-4 foot reach. In some cases, it’s to give reach in 4x4 raised boxes, without a lot of repositioning the chair. In other cases, it’s to reach the ground from the chair. In all cases, the head needs to be much lighter and smaller to reduce fatigue. Handle will be thinner and lighter as well. the search term suggested helped a lot. It provided some good examples to study. I’ll keep looking. One of them had a 4-5” tang, and the handle was split with a
I'm looking to make some garden tools for someone in a wheel chair. So they will be downsized in the head, shorter handle, but similar normal width. I'm trying to find information on the best practical processes for making the tang and ferule(I think that is what it's called, the cone that holds the tang to wooden handle). This doesn't have to be authentic processes from 1875, but focused on solid construction, will hold up well. Any thoughts? One thought I have is steel pipe/tube smaller in diameter than handle and then flare out the end on the horn/ a cone. Then make tool he
Got this load last weekend from a historic smithy established in 1906. Owner of the property was clearing it out. Unfortunately, most of the tools were sold previously. if anyone has ideas of what I can make out of the railroad plates, would love to hear it.
Great, thanks for the info. I had searched the forums and came up blank.
I'm wondering if anyone has tried putting a screen in a NA burner after the gas introduction to force mixing of the propane and air. Much like a gas lens on a tig torch flows the argon. Mike
Celtic Art references
John B, that looks very nice. I'm jealous of your patience. I'm brand new to black smithing, but have been doing metal work for a while. My wife is mostly Irish and we both enjoy the patterns and art, so I like to include those influences to keep on her good side. This is the starting layout for a design I'm working on for 3 Trellis that will go against pillars on the porch to support rose vines. I plan to make it from 16ga steel, and my hope is to make some celtic knots (or at least the weave pattern) from 1/4 - 3/16" steel rod and incorporate it into the design for the border aro -
Working on designing my forge skin. I'm planning a 4x7x12 internal work area. Inside will be lined with 2 inches of Kaowool, Rigidizer, 1/4" Kasto-like 30, and Plistix. Design is a small version of Essential Craftsman's forge where the top body separates from a floor which I think will make maintenance/modifications easier as well as the cool ability to temporarily in a pinch, raise it up with blocks to be able to heat something odd shape. Anything I've overlooked? Is there anything I should be doing to hold down the kaowool? Might be something I could design into the form.
What's the slot for? Getting the work piece back off?
Thanks for the recommendations. Picked them up on Amazon for less than a tenner combined. -
Something wrong with this ceramic insulation?
Whiskeymike replied to Whiskeymike's topic in Insulation and Refractories
Thank goodness, as I bought it last night. It was just half the price of everyone else I found and usually that spells too good to be true and it ends up being made out of tissue paper that burns my shop down. I ended up getting a $10 ebay coupon, so it came out to $90 to my door. I'm still in that earlier stage where I've read a ton of stuff, but only a 1/5th makes sense because I haven't done enough or it hasn't soaked in. I bought fumed silica last night and researched it for 30 minutes trying to figure out which one was the desired one - hydrophobic or hydrophilic. Something a -
I’m wondering if anyone knows if there are any reference materials on how to produce Celtic art such at Celtic Knots from rod. Specifically looking for order of operations, techniques, etc.
Anyone have a recommended regulator, pressure gauge, and hose setup for a dual burner setup? I know I need one that is adjustable from 0-30 psi. But is there a model/brand that is less prone to leaks, quality parts for adjustability. Is there a hose type that is better protected from stress and heat, or is it better to sheath the hose? I’d prefer to use something larger than a bbq bottle... do the larger tanks use a different connection type?
For Tweco Mig tips, is the threaded portion 1/4 28 thread? In looking at these things, I can’t confidently figure out if it’s 1/4 28 or M6 metric. whats the proper drill and tap for these?
Just picked up a post vise that’s missing the mounting bracket. They are stupid expensive on eBay. Anyone have designs on period correct mounting brackets. The flat bracket with three holes is easy, but wondering about the steel wrap around the leg, shims, etc..
Just picked up a post vise. Someone worked it over pretty hard. What are my options on fixing or replacing this? can I build it up with TIG? Brazen or weld? Are these available for sale somewhere? Build a new one on a lathe?
I’d love to know this as well. I just bought one that has very similar body lines. It’s sitting in evaporust right now. In a couple days, hopefully I’ll have some pics to share with markings.
How is it used? Is it for bending bar stock?
Anyone have any experience with Anvilfire's P-75 Black Beauty Forge Burner? I searched here and found only one reference. I'm a complete beginner, have read as much as I can of Mike's posts. Looking to make my first forge and planning a double burner box forge. Is it adjustable? Is that what is meant by the draft shield? Also, it mentions - "We do not provide a flare with our burners. Our burners are not a hand held torch, they go into a stationary device where a flare is not needed (the refractory lining creating the flare/flame holder)." Does that mean that I need t
