1,048 -
Everything posted by WayneCoeArtistBlacksmith
Check out the Build a Gas Forge attachment on the Forge Supplies page of my web-site. You can get my contact info on my Profiles page. Let me know if I can help you Wayne
Joel, you are correct there. I posted without thinking through what I was saying. When I have done that I used combination dies where the narrow portion is only about 1" wide. I put the kiss block on the wider portion. A kiss block is a piece that is clamped in place to keep the top die from coming past that point. combination dies are shaped like this: --
I would used a Kiss Block rather than the spring swage. Make a 3/4" block and weld it to a piece of angle iron about an inch wide. Clamp it onto the bottom die with a C clamp. Draw down to 1" square first then forge to round. You might want to use about a 1/2" spring fuller to isolate the mass and to get a smoother transition. Let me know if I can help you. Wayne
Keep checking back. I will send an e-mail to the president tonight. Let me know if I can help you. Wayne
Check out the Build a Gas Forge on my web-site. You can find my url and other contact info on my Profiles page. Let me know how I can help you. Wayne
Bob, you have the drawing correct, add a thin layer of Plistix or Metrikote. Also when installing the hinges, on one side of the bottom have two knuckles up and on the other side have 3 knuckles up. This insures that the two parts are always in the same orientation. Let me know if I can help you. You can find my contact info on my profiles page.
Bob, if you follow my plans you can use 1/4 - 20 bolts to bolt on the hinges and can use metal conduit parts the way Larry Zoeller at www.ZoellerForge.com suggests, or better follow Thomas' suggestion. Wayne
The Build a Gas Forge plans are written for a 20# Propane tank but also discusses using a Freon tank. Let me know if I can help you. You can find my contact info on my Profiles page. Wayne
it is a tapered tip. Most any welding shop should have them or can get them in. One is designated as Tweeko T Tip.. Be careful that they are the tapered tip. Look at the pictures closely. I looked on both Google and Ebay and they both have standard tips mixed in the T listings. Let me know if I can help you. Wayne
Be sure and get T tips. They give better air flow. Let me Know if I can help you. Wayne
I do not recommend using Satanite, use Kast-0-Lite instead. Kast-0-Lite is a light weight insolating castable refractory. When I apply Kast-0-Lite directly over the blanket I do not get any compression and no loss of efficiency, as a matter of fact the Kast-0-Lite improves the efficiency. Let me know if I can help you. You can find my url and contact information on my profiles page. Wayne
Metrikote AND ITC-100
WayneCoeArtistBlacksmith replied to coops1911's topic in Insulation and Refractories
I would not suggest using both the Metrikote and ITC-100. There can be undesired effects by combining these products. I believe that Metrikote is a better product for our uses and is costs much less. Let me know if I can help you. -
Newbie needing some assistance
WayneCoeArtistBlacksmith replied to Kabir Singh's topic in Gas Forges
Check out the Build a Gas Forge attachment at the Forge Supplies page on my web site. You can find my url and contact info on my Profiles page Let me know how I can help you. Wayne -
I do have a product that is good for patches and repairs. Let me know if I can help you. You can find my contact info on my Profiles page Wayne. -
WT, you can depend on Mikey to say exactly what he thinks. That is also true for Frosty and others on this forum. HAHAHAHAHAHAHA!!!!!!!!!!! Let me know if I can help you. Wayne
- 17 replies
- perlite refractory
- naturally aspirated
refractory cement type
Thanks Coop, I'll get it right out. Thank you Wayne. -
An octagon has 8 EQUAL sides, not 4 sides with the corners knocked off. Wayne
Check out the Build A Gas Forge attachment on the Forge Supplies page of my web site. Let me know if I can help you. You can find my url and contact info on my Profiles page. Wayne
- 17 replies
I too would suggest that you paint the interior with either Plistix or Metrikote. This will not only seal the breaks but improve the efficiency of the forge. BTW, I think that Mikey meant Wayne rather than Wade. Let me know if I can help you. You can find my contact info on my profiles page. Wayne -
liability form
WayneCoeArtistBlacksmith replied to Timber Ridge Forge's topic in The Business Side of Blacksmithing
I had written a document that was titled "Warning". It is not a "Release" or a "Waver". It is based on the Georgia law relating to Equine and Lama law and the You Pick It law. I believe that the all inclusive over reaching "Releases and Wavers" commonly used are over reaching and contrary to public policy and most are likely to be overturned if challenged. I believe that individuals and organizations are better off to use the wording in the article published by the Hammer's Arc. which is attached. WARNING.pdf Let me know if I can help you or if you have questions. Wayne -
Hello And Merry Christmas from Ga
WayneCoeArtistBlacksmith replied to Kevin Flanagan's topic in Introduce Yourself
ABANA was started at Westville, Ga. (close to Columbus) in 1973. The Alabama Forge Council's regional sub forge in in Phenix City, AL You can contact them at PhenixCityinfo@alaforge.org or go to www.alaforge.org and explore from there. Let me know if I can help you. You can find my url and other contact info on my Profiles page. Wayne ' -
kast-o-lite 30, how thin?
WayneCoeArtistBlacksmith replied to Jclonts82's topic in Insulation and Refractories
I have always cast about 1/2" thick just because of the space between the blanket and the edge of the door and it has always worked well. I see no reason that 3/18" would not work well and may be even 1/4" . 3/16" seems a little bit thin but try it and let me know how well it lasts. If I had free iTc-100 I would use it too! Let me know if I can help you. Wayne
