AdamG
106 -
Everything posted by AdamG
Hi all, this my first axe/hatchet project. It is mild steel with a W2 bit. My forge welding skills are crap (especially in my gas forge) so I TIG welded the bit on after a failed attempt, thus the marks (I'm pretty new to that too). I kind of like it rustic anyway. I normalized once in ash and quenched once in warm water, then let the colour run back up the piece and cooled it again. Seems to work (no immediate chipping yet).
Railway track hot cuts
AdamG replied to Joel OF's topic in Hot Cuts, Anvil devils, metal cutting on the anvil.
Those are awesome. I can't recall what steel rail is made from... is it something like 1018 with just a hint of alloy? -
Try a san mai billet first... three layers. Use the one that will be your cutting edge in the middle. In fact, why not try mild steel around a core of 1070 to start. Grind them clean, stick them together with small MIG or tacks or wrap the billet tight with iron wire. Heat to dull red, sprinkle with borax on all sides until it looks wet, and heat to welding heat and quickly/gently/firmly hammer the layers together from the middle outward. Because it's so thin, it will cool quickly. Do a few hits, then back in the fire. Repeat. You'll have an idea when it's welded because it will cool evenly (can't tell the layers apart by colour) and will sound firm under the hammer. The sides may look ratty. Either forge them back in at a welding heat or cut them off (better for the first try). An alternative would be say 5 layers... a bit thinner than a square bar. Don't make a 2" thick bar at the beginning unless you want to risk that much material... it's up to you. I've made a couple of usable san mai knives with O1 and mild steel, and hoping to get better with billets of 15N20 and 1084 or W2. And ferric chloride isn't the only etchant... it's the one with the strongest contrast, but that's not always the best.
First Hot Cut Hardy
AdamG replied to Dylan Sawicki's topic in Hot Cuts, Anvil devils, metal cutting on the anvil.
Nice job! My first was not as nice... I still use it. -
And on a slightly different topic (different machine, also made by me)...
Ok, thanks. Please PM me with your website. Also, I just unhooked the pneumatic actuator I had made for the jack's pressure release, and sure enough, when closed right I get more pressure. I think your cautions still apply though. I made a stripping bottom die and I'll make a few different top punching dies but I'll have to be careful and maybe not use this for more than some lighter work.
Hmmm. Good to know. Do you sell yours? Can't find a website etc. Even if you do, could you get something like that across a border? I could look at making one myself, but the point of this thread is that I'd rather get back to forging! Also, I think that power pack has an internal bypass, so it uses the fast flow/low pressure to get the ram moving, and then the slow flow/high pressure once it hits resistance. I was going to use electric foot pedals for up and down, and maybe interrupt the signal with roller switches for the top of the travel.
Thanks, I have looked at your press. Maybe I should have done something like that, but I tried to start simple (avoid hydraulics). I have been thinking of replacing my jack with a single or two small cylinders and a power pack like this: https://www.princessauto.com/en/detail/2-stage-12v-dc-multifunction-hydraulic-power-unit/A-p8541666e I think the width of my frame is a bit excessive, and there's only the two 2.5 x 0.25" wall tubes for structure, so I'm a bit nervous of putting a hydraulic load on there, even if it's only a single 2" or 2.5" cylinder, or two 1"-1.5" cylinders. Any comments? Sorry, I meant this power pack: https://www.princessauto.com/en/detail/2-hp-ac-2-stage-multifunction-hydraulic-power-unit/A-p8677239e
I won't try to overpressure anything... I was just thinking that there might be air in the hydraulic cylinder inside the jack or something. If it sucks, it sucks!
Hi all, Any suggestions on how to get an air/hydraulic jack to pack some punch? This seems gutless!
This might not be the place for it, but here's a quick clip of what I was using the hammer on yesterday. To keep this somewhat related to this forum, I'll mention that I think I neglected to normalize the razor before heat treating. Next time I'll follow the rules.
So far so good! I'll upload a video soon, but as I suspected, the 1045 appears to be plenty hard, even with the aggressive tempering I did. Man, it feels good to use a hammer you've made! Next one is going to be a Japanese-style (dogleg) hammer with a stainless working surface (309).
I officially can't wait to get a new welder. I tacked on a couple of bits with my 6011 yesterday and it was painful.
Thanks for the input guys. I've decided that calling this exercise a root canal would be an insult to dentistry. I can also say that DC reverse polarity with enough Amps makes a world of difference! Oh, and using name brand electrodes.
This one is 1045. I quenched it from orange in cool water and then kept it at the door of the forge until I saw some colours on the faces, with flame coming through the eye hole but I won't do that again. Not even enough, and hard to control. I'll report back about hardness. I'm looking forward to having a proper rounding hammer, even though I have a good little modified store bought 3lb that's now a rounding hammer. First project is to clean up my hot cut (4140) and I'm set.
Thanks for the feedback... I agree that most of what's welded there is crap. It turns out all I could get was 110A on my AC buzz box. I thought I had 170 but that's for some crazy German voltage or 3 phase. I think I managed to get a reasonable 6011 root pass (3/32") but all of the 7018 was way too cold and was sticking like heck so I ran tracks all over filling in voids. Nasty. I'll have to grind it back and weld this up at a friend's place. By the way, can you TIG over a mess like that to burn it all in? I'm looking at those Everlast multi units.
Bit of an update... if one spring is not strong enough, just use more springs! I didnt get pictures of it all, but I added four springs per side to lift the bar and it works. Might need to weld on better rings for attachment points. This thing is likely to be slow and limited in its use, but if I can at least get some mechanical help piercing hammer eyes and fullering etc, it might serve a purpose. If I make a hydraulic press one day I will try to make the dies and die plates the same so I can repurpose them. This frame looks too short for the shortest hydraulic cylinders I can find.
I heat treated my rounding hammer today, and then I tempered it... possibly a bit much. I think it's not hard. But then my anvil is not hard either so I decided to handle it and see how it goes.
Would this make for a decent press? https://www.princessauto.com/en/detail/3-hp-ac-2-stage-multifunction-hydraulic-power-unit/A-p8677247e (it's 6 gal/min and 1 gal/min pump speed). I did not build this thing for the dimensions of most hydraulic cylinders, and there is no mechanism to keep the H bar well aligned... it's loosely fit against the inside two faces of the vertical supports. I might be able to shim that up with HDPE. But in any case, I would need short cylinders... maybe 6-8" stroke with a length of 10" or so. I was intimidated by the risks of hydraulics, but now that I have this structure, it might make better sense!
Hey, given that this is pretty beefy, maybe it could be converted to hydraulic later... maybe two small cylinders. What do you think?
Hi all, i am just about done a forge press (air/hydraulic, for cost reasons) and have made good progress so far I think. See: I have to finish the return springs and the foot controls but it's starting to take shape. I think I over-built by 10x, especially for an air jack. Also, I wonder about the middle h bar not staying perfectly level. Any suggestions are welcome.
Made your own tools! Feels great, doesn't it! Just even out those reins and you're golden. I'm going to try dragon/pickup tongs next. The bolt tongs seem tricky by comparison.
See? The circle of life!
- 77 replies
- blacksmithing
- hammers
(and 2 more)
