dimenickel
231 -
Everything posted by dimenickel
Broke 100# LG frame
dimenickel replied to Danny C's topic in Power Hammers, Treadle Hammers, Olivers
this is a good idea... got a plasma cutter and some 1/2" plate... cut it out and weld it up... should be better than the original -
Grain in blade that was broken
dimenickel replied to KenH's topic in Heat Treating Knives, Blades etc
grain size could be smaller ... it looks big in the pic crack a file in half... notice how fine the grain is there... thats what it should look like do 3 normalize cycles... and you start higher and go lower Kevin has good stuff on his site http://www.cashenblades.com/steel/1084.html http://www.cashenblades.com/heattreatment.html good luck -
Coal Price? NW Ontario Canada
dimenickel replied to Laertius's topic in Solid Fuels: Coal, Coke, Charcoal, Wood, etc
i used to get my coal through the hardware when it was about 23 bucks a bag, and switched off once they jack the price up so high... In my opinion it is not worth it !!!! at that point i switched to propane forge with blower ( at 32 bucks a 30lbs tank ) -one of these days i'll get back to coal when i can get a big order from a supplier ... and avoided getting skinned by the middlemen I'd look to gettin it from the states.... they got the good stuff down there -
Home build induction heater
dimenickel replied to Daniel.85's topic in Induction Heating, Oil forges, etc
i've been using that miller tig coolant and its been fine ..... otherwise its distilled water in summer -
even just heating a piece of steel ... theres almost alway some smoke that comes off the steel and that tends to get drawn into the air intakes on the side of my machine ( smoke being some kind of particulate )....for myself, i was amazed at the amount of dust i blew out of mine the first time i had the case cover off - perhaps having the air intakes coming from the back of the machine may help... or even having a filtered airbox at the back of the machine much like a remote air filter on a car if your machine uses much less fan cooling then your probably fine i can say, i really love my induction heater and would really hate to do without it.... marvelous machine !!!! -
here something to look at in terms of your design .... in my shop there alway alot of grinding dust, despite ventilation and a 1hp dust blower to suck out the grindings around the machines But, the dust alway finds its way into the fans and cooling of the induction heater... so i have to take the case cover off and blow out the insides often !! its annoying and not something i can avoid i'm thinking of putting some fine furnace filters on the air intake for cooling the electronics this maybe something you'll want to look at.... as most shops are extremely dusty..... Greg -
can you run a 3 phase motor on single phase power?
dimenickel replied to onetreeforge's topic in Problem Solving
well, it depends i'm not sure about electronic stuff or welders...as my experience is with hydraulic's you want your rotary to be much bigger for things that have a hard start eg.. for my hydraulic press i use a 7.5hp work motor and needed a 15hp rotary phase converter ( motor and box ) to be able to use it the advantage is that you can buy the cheeper industrial surplus motors ( which are more durable ) hopefully others will chime in about welders ? -
Some spearheads and a socket tool.
dimenickel replied to P. Bedard's topic in Spears, Arrows, Pole arms, Mace/hammer etc.
Hello if you want to make forgewelded sockets... the way i do it is take a piece of sheet iron the size of the socket and taper the ends - roll it round like a pipe and overlap the tapered parts and then forgeweld it over a mandrel, therefore now you have a pipe bout 1.5inch dia - now forge/narrow one end down to a taper... and bevel the end so when you weld it to the spear blade you don't see a weld joint make your spear blade with a tang ... tang looks like a short round plug - fit the socket to the blade tang/plug ... sand them clean of scale and fit them tight -forge weld An obvious short cut is if you have some 1.5 inch iron pipe ... ... then you'll only have to forgeweld the spear blade to the pipe to straighten... i tend to do as much over the anvil as i can then take a heat on the blade tang/socket junction.. clamp blade in vise, and insert a long bar into the socket ( make sure it fits socket tightly ) and manually align the bar with the blade as best the eye can tell ..... done !! Greg ps.. if you use socket size the same as shovel handle size... you can easily find shovel handles at hardware store for quick spear hafting -
Why not solid HC steel axe?
dimenickel replied to Aeneas61's topic in Axes, Hatchets, Hawks, Choppers, etc
if your slittin and driftin on the anvil by yourself, it is easier to go through mild iron ..... also you can work mild at a much hotter heat and things move quickly .... it all matters if you work by hand both ways make a good axe also ... had to edit you are incorrect about the old ways Persian Tabar axe heads were slitted and drifted in crucible steel ... which is ultrahigh carbon steel uhcs -
contemporary blacksmiths hammer in @ Monster Metal
dimenickel replied to monstermetal's topic in Everything Else
Wonderful ! and very creative gate work -
dudes, very cool can i make a small suggestion .... add quick connect coupler to the copper heating coil so you can switch coils quickly ... trust me it'll make a big difference as i find your constantly switching... having the coil close in size to the dim of the piece of iron makes a difference in heating time G -
hello video is very nice and punch came out awesome to quiet anvil, put silicone window caulking under the anvil.... it will deaden the sound and make anvil more enjoyable to work on .... aswell use metal straps or mechanical means of holding anvil feet to the stump ( to physically hold it in place ) take care Greg
I would say " use the appropriate protection for the job " I've used welding gloves, or leather gloves for 12 years... if you make a living with your hands ..take care of them.. ... take a month off work cause you've gotten a very bad burn.... who's gonna make the mortgage payments ????? (don't worry the banksters will understand ... hah )
you are correct... higher alloy steel can be brittle in cold environments (loss of toughness) you can see this on impact tests.... add abit of Ni to help with that
Tool Handles. Yeah, I know, hickory is king, but...?
dimenickel replied to Leland Stone's topic in Tools, general discussion
what ever the beams of wood pallet skids are made of... some maple , some oak .. its free and usually a hard wood.. ... use this to replace out hickory which has either split apart or cracked beyond repair... typical -
get a pail of water... clamp the blade so that the knife blade is completely under water and the tang is out of the water.... - this will make sure the blade doesn't get over heated take 2 propane torch... use both at the same time... use one to heat from one side of the tang and the other from the other side... - bring the tang up to a black heat.. ( just just before it starts to turn a dull red ) and let it air cool..... do this several times ! it should work.. if not, buy a small carbide drill bit the appropriate size .... drill in a very secure drill press... as chatter will break these quickly try to drill the holes prior to heat treat.... it'll save yourself some frustration Greg please pic's after your done !
very cool stuff ! induction is great i've used some small SiCarbide crucibles to melt with ... they even heat up along with the charge does yours have a duty cycle? Greg -
wonderful work !! thank you
Wonderful and awesome really nice to see the whole piece... thanks for showing
nice work ! like it alot G
Stump for anvil stand - Treating?
dimenickel replied to Jeff Lodge's topic in Stands for Anvils, Swage Blocks, etc
you can use pine tar ... that works well i put a mix of that and linseed oil on all my handles... even the shovels n garden hoes... the antifreeze is poisonous to fungus and mold, it works aswell -
the greenman is waaaay cool ! great machine
