195 -
Everything posted by Shamus Blargostadt
My First Tomahawk
Shamus Blargostadt replied to Hunterbow Smithy's topic in Axes, Hatchets, Hawks, Choppers, etc
I was looking at a few online. They seem to range between $25 - $38. Shipping tends to double it though. Is a bull pin something common that could be bought in a steel supply or home depot type place? I did pick up a huge chisel looking thing at a second hand store with a mushroomed base, about 12" long and approximately 1.5" - 2" Diameter. I'm doubting I have the skill to draw this to a useful taper though. -
Beginner steel stock
Shamus Blargostadt replied to Shamus Blargostadt's topic in Blacksmithing, General Discussion
Yes I did search, asked around and read up to find sources. I just didn't know what to ask for, specifically. I'm still trying to learn the language and lingo of smithing. Oh and had a metal shop owner invite me over to rummage through their scrap pile last night! -
My First Tomahawk
I'm guessing that forging a proper tomahawk drift is an advanced project? -
Perfect! Thank you! -
ok this is going to be a really dumb question. If I want to buy some 1/4" square or round stock bars to start out forging some scrolls and other simple projects.. maybe tackle a set of tongs, what do I ask for at the Steel-R-Us store? Just "I'd like to buy some 1/4" square and round stock" or are they likely to counter with, "well buddy what kind of steel stock you looking for? We got 01, 1060, CPM 10V, some D2, or how about some L6....etc.. etc.. etc.." I just want to heat up some steel, smack it around, and learn how to make stuff.
would like advice on a coal forge
Shamus Blargostadt replied to Shamus Blargostadt's topic in Solid Fuel Forges
Thank you again Sir! -
Charles - The break drum I have is about 13.25" internal diameter (top) and about 5" deep. If my air is coming in from the bottom, are you saying the pot should look more like the drawing on the right, below? -
Thank you very much guys. As always, greatly appreciated! -
yes i have the break drum forge part built. it's propped up on cinder blocks. I took to heart the advice of folks here to consider a chimney. I don't know how to weld but a buddy says he has the scrap i would need to make this and I know a guy who will quote on fabrication and welding it. -
I'm thinking of fabricating the forge in this video. I was wondering on some vet thoughts on the design of the firebricks and the firepot location in relation to the chimney. Most coal forge's I see in videos have the firepot in front of the chimney. This is the first time I've seen it in front. Do you guys/gals think having the firebrick around the pot is helpful? How about if the bricks lined further up to the front, so the firepot was surrounded in the back and sides? the only problem I'm thinking is perhaps it will be harder to tend the fire, removing clinkers, etc.. the break drum I have is slightly larger than this one in the video, probably by 2"dia. I also have enough firebrick to come to the front. Just wanted to make sure I wasn't making a mistake before launching this.
camping hawk or hatchet
Shamus Blargostadt replied to homeshow's topic in Axes, Hatchets, Hawks, Choppers, etc
Steve - I've had two of those calls. Both times I had great fun wasting a half hour of letting them attempt to walk me through hacking a Windows PC, when I run Linux. Both times I got switched to an "expert" who proved to be just as dumb as the first guys. I just laughed my rear off at the stream of curses when I finally get tired and tell them it's a linux box and that they should get a real job. Die Hard Unix/Linux user here. I started with AT&T System V Unix in the 90s and refused to put microsoft anywhere on my resume since. BTW - the images look fine to me.. using ubuntu and chrome here. -
That sounds like a prudent approach Scotty. There is a flea market here with a selection of cheap crowbars, chisels, and hammers (smaller mass ball peins and claw types), usually around the $3/ea range but might go cheaper if I buy several. Any recommendations on what kind of tools I could consider making from those types of things?
I hit on this topic in a totally unrelated thread and wanted to ask another question. Thought I'd start a new thread for a beginner like myself looking for the same answers. The background is I acquired a leaf spring 1/4" to 1/2" thick from a scrap yard, and was trying to figure out how to break it down into workable chunks, being limited in tools and knowledge. I do have a makita chop saw but the general wisdom appears to be that it is designed for wood and using it for metal has a good chance of breaking the unit, at best. One good recommendation I had was to find a hacksaw blade that was 12 - 14TPI to saw it with. I found a 14tpi but it was really slow going. Another person suggested getting a bandsaw blade made for cutting metal and cut/punch that to install into a hacksaw. I'm in the process of finding a blade to try that. In the mean time, a local hardware store had a sale on Genesis 4.5" angle grinders for $20. They have terrible ratings on amazon for burning up and failing. I figured I'd give it a try and take it back if the motor burns. so.. to my questions. The angle grinder worked pretty darn good. I cut the steel with just a few breaks to let the motor cool down and used the 14tpi hack to move it along. It was a little scary though. Having been blessed with a vibrant imagination, I could easily envision the grinder blade disintegrating into shards, embedding them into my forehead and taking off fingers. It got a little less scary with time but it was hard to keep the line straight cutting freehand like that. I'm thinking curved cut and straight high speed circular blade isn't such a good thing. I want to cut it lengthwise now, for blade sizes. Has anyone used a sawzall/reciprocating saw for breaking down this size of steel?
That is one nice forge. Makes me wish I knew a welder, or knew how to weld. I wonder how much a shop would charge to make that table and hood setup.
I recognize the ambient noise. You just got peeps! Sounds like my basement. thank you for this, I was just wondering what the next step was going to be in my break drum forge
anvil price bubble?
Shamus Blargostadt replied to BIGGUNDOCTOR's topic in Anvils, Swage Blocks, and Mandrels
I saw a 350# Sweden Anvil at a flea market for $1500 last weekend. Looked beautiful but holy cow that's a lot of clams. -
The lowest tpi blade I could find was 14. It cuts but it's going to take a loooong time to break it down with a hack saw. I do have a chop saw. A bit embarrassed to admit I don't know the answer to this but can I get a blade to use in it that could cut this? It was passed down from my father-in-law who has since passed on. I've only seen them used for wood so it didn't occur to me that it might work for metal too. He was a hobby wood worker and left behind some nice wood working tools.
the bar is 3" wide, 38" long and 3/4" thick in the middle.. then it tapers to 1/2" thick on the ends. I mean to get a good angle grinder at some point but don't have one yet. I wouldn't have thought a hacksaw would be a good route but I'll give that a go Frosty. Thanks for the tip! I'm definitely seeing some axe heads in this Ronin. I'm wondering if I can cut a length, smash the middle down to make it thick enough to take a handle hole (ignoring the fact I don't have a drift yet) then flatten the heads for an edge.
Actually first thing I've ever forged. Grinding is definitely going to take a lot more practice, among other things. 5160 leaf spring steel, black walnut handle. I wanted to leave scale/forge marks across the top and handle area but I sanded off areas unintentionally. Blade is about 6", overall 12"
