50 -
Everything posted by Jesse17
For the record it never said what it was in the ebay listing either, just said something like "rare hammer tool". So I still had no way of knowing what to search for.
Oh, I see. Thank you. I wonder if a mod should delete this thread since it has nothing to do with a hammer/tool. The thread is educational as the hame is part of a horse/mule harness. By itself it may not be recognized as a hame. Some use the hame as a handle on a walking stick, decorations in a home or barn etc.
What is this tool on the hammer handle called? What does it do, extend the handle or just give you a better grip or something? Are they something that used to be common? Do people still use them? I have one in a box of junk but had no idea what it was or that it had anything to do with a hammer, until I ran into this picture on ebay.
That's beautiful! I'm in awe of your work!
If you could have any tool, what would it be?
Jesse17 replied to joshua.M's topic in Tools, general discussion
TW90 belt grinder -
I thought about doing the twists after the bends, but my forge was built for blade work, so most projects won't fit in it once any long bends have been made. I have to do all the spirals, twists, etc. then bend the long pieces in one heat each.
OK, I made a second attempt. I think this one came out a little better, but there's still some rough areas. I REALLY need to find something to build decent anvil horn with. Sticking different size pipes in my vise isn't as great of a solution as I had hoped.
I wasn't sure how how much bar was going to be used in making the corners, or exactly how I was going to form the corners. So I kind of expected my twists to be in the wrong spot, and oh look at that, they are... But I did manage to make a ball like shape at the end of the piece you hit it with. So that's a 1st that worked out ok-ish.
newbie - treating/tempering 1060
Jesse17 replied to Shamus Blargostadt's topic in Heat Treating Knives, Blades etc
People use motor oil, but you won't want to temper it in your kitchen oven after you've quenched it in motor oil. I use vegetable oil myself. I recommend you install, shape, and finish your scales before sharpening the knife. Otherwise you will have to tape the blade while working on the scales, and that can sometimes discolor non-stainless blades. -
A thing of beauty, for sure!
High temperature oven modification
Jesse17 replied to arkie's topic in Heat Treating Knives, Blades etc
PID Controller $46.50 http://auberins.com/index.php?main_page=product_info&products_id=1&zenid=90b32ac5f8da355dc0ed454b403f29f8 Thermocouple $27.75 http://auberins.com/index.php?main_page=product_info&cPath=3&products_id=39 Solid State Relay $15.00 http://auberins.com/index.php?main_page=product_info&cPath=2&products_id=9 Heat Sink for SSR $9.95 http://auberins.com/index.php?main_page=product_info&cPath=2&products_id=45 Grand total: $99.20 Run the power to the oven through the SSR, the PID controller can use the relay to turn the oven on and off. They can be used to control a propane forge within a few degrees, so they shouldn't have a problem turning an electric element on and off fast enough to control an electric oven at any temp you want. -
I read on here, IIRC, that brass should be heated to red, then quenched to anneal it, then worked cold. I couldn't find any brass bar stock locally, but picked up a piece of scrap that looked to be a bearing race of some sort. It was a ring about 6" dia. and 1/2"+ thick. I cut a 1/4 of it off, heated until red (or a touch better) and quenched. Then tried to straighten it out with a 2.25lb hammer. Nothing. I repeated this process several times and the brass never budged. So I tried hitting it while it was red and it worked just like steel. That is until I turned it on edge, and hit it. Then it just crumbled. I moved back on the piece and flattened it again, with lighter blows this time. I managed to get it down to the 1/4"+ that I was shooting for. Then I laid out the area to remove for my knife tang (I'm making a finger guard, btw) and tried drilling it. My drill press would just sit and spin on the brass. I ended up having to start with nearly my smallest drill bit and work up in size with every bit size I had. Skipping one size the drill bit would just sit and spin. What the heck? I thought brass was softer than steel. Why is it so hard to drill, and why was the work it cold thing not working AT ALL?
Thanks! So, the handle is mostly for looks, and one operates it by grabbing both sides of the tongs to squeeze them together?
Forgive me for the off topic question, but could someone explain to me what I'm looking at. The OP said they were fireplace tongs, but I'm having trouble comprehending how they work. Is that short piece with the rounded end a handle, and you hold a piece of firewood with the other end? If so, what provides the leverage to hold closed the tongs? Or is that piece a poker and you hold the firewood in the curved area below the hinge? That would seem pretty awkward to place the log where you want it. Like I said, I'm totally missing what these tongs are designed for and how they work. Thanks to anyone who want to explain it to me!
Thanks guys. I'll throw on a fresh blade and see if it won't cut the lower parts. If not, I'll try annealing it in the forge like njanvvilman described, and try again.
I started out trying to cut it with the band saw. I was making no progress even on the edge of the bottom flange. But maybe I already killed the saw blade as I had already spent 5 min. of running the saw on the top edge of the rail, which resulted in a less than 1/8" deep cut. That's when I switched to a cutting wheel on the angle grinder, and an hour later it was cut. OK, an hour and a half, but I'm confident I could do another one in less than an hour now that I have a feel for it.
Welcome! Just a noob myself, but having a blast leaning and playing!
I had a tenant move out and leave four set of drawers that go under a bed to support the mattress. I stacked them up to give me a bank of drawers 3 wide x 4 high. I screwed them together and stuck some 1/2" plywood (that originally would have been between the drawers and the mattress) on top for a work bench. I have some cement board scraps that are just the right size to cover the plywood, and make a back splash. Once I get the cement board installed in the next day or two, this will me my new grinding bench and power tool storage. I'll try to remember to take a picture when it's done.
I have some railroad track that I want to turn into knives. I cut an 8" length off with a cutting wheel, and now I want to reduce the bottom plate and the upright piece into strips 8" long and roughly blade width wide. The actual top part of the rail I'll draw out with a buddy's power hammer or on mine someday when I get it built. Originally I planned to anneal the 8" length of track in my forge then cut it from both ends with my port-a-band saw, but then I thought it might be quicker and easier to just cut the strips with a chisel while it's hot. The plan to anneal would be to stick it in my propane forge, heat it up then shut the forge down and close it up with firebrick to hold the heat in. Maybe use the PID controller to control the cooling rate. I don't know how well that will work. So my worry is that it might cool too fast and I end up still not being able to cut it with the band saw. But on the other hand, that's a lot of weight to be handling at forging temps if I decide to hot chisel it. I'm not really worried about handling it, but I've never split anything with a chisel yet, so I don't know how doable splitting 1/2" 1080-ish metal is. So how would y'all go about this project?
Nice! I would have sanded the scale off after heat treating it, but that's just a matter of personal taste. I like it very much.
Another thought, they seem fairly safe around heat sources, but they scare the heck out of me around running tools (or tools that are still slowing to a stop as you walk away) They love to grab moving things and stick their paws in machines. I remember an article in some woodworking magazine about a guy who's cat lost a paw in his jointer..
I've never heard of the place until I started getting into blacksmithing, and some of the images I've found on Google were from etsy. I don't know anything about etsy, my point is just that if I were their potential customer, they did a poor job of telling me their products even existed.
- 9 replies
- selling your work
- etsy shop
My wood shop has a cat door. I occasionally find that they have used the pile of sawdust under my table saw as a litter box. I find our 5 house cats fairly useless for mice. They kill them, but they also like to catch mice outside and bring them inside to play with. They they promptly let them escape in the house to have something to play with when it's raining out, I guess. I have much better luck in my shop with bar bait/poison.
Thanks! I did forget to wire brush it while it was hot. I set it in front of my shop when I finished, and started cleaning the shop for about 10 minutes before I realized I forgot. I've heard that soaking a knife overnight in vinegar will remove the scale. Does that work well for higher temp stuff like this, as well? Not that I'm too worried about this practice piece, just curious. And thanks for the tip on making the spiral. I didn't think of unwinding it from the middle, I tried opening it up by tapping backwards on the outside spiral, but it was just kinking stuff and making it worse.
The knife is just a cheap-o made in China, promotional thing. Thas one came from the AQHA (says so on the blade) when my wife renewed her membership. We have another one that is absolutely identical except for the scale color, it says Spalding Labs Fly Predictors on the blade. Both say made in China, headquartered somewhere or rather, USA.
