Hofi
Deceased-
1,086 -
Everything posted by Hofi
hofi@ein-shemer.org.il hofi
GRANT SARVER I NEW THE LATE RUSSEL JAQUA PERSONALY I MEET HIM TWICE AND HIS BEUTYFUUL WIFE. WHEN I DEMONSTRAT AT NWBA RUSSEL WAS VERY KIND TO LET ME DEMO ON THE ''GLADIETOR'' TALKING TO HIM ABOUT THE ANVIL I SAID -THIS IS A COPY OF THE ITALIEN STYLE- AND HE SAID YES IT IS LONDON PATRRN ANVIL YOU HAVE MORE THEN 100 DIFFERENT TYPES AND HERE MAY BE YOU TRANSFER TREDITION. BUT WHEN ONE MAKES THE SAME IT IS A COPY . THER IS NO OFFENCE BY SAYING THAT SOME ONE COPYID A FORM AND RUSSEL WAS HONEST ENOUGH A MAN OF INTEGRITY TO SAY ''YES IT IS A COPY. IN MORE THE THREE PLACES IN THE USA THE HOFI HAMMER IS COPYID THE SAME IN PAKISTAN AND IN CZHCK REPUBLIC SOME OF THEM EAVEN SAY THAT THEY INVENTED THE FORM -GOOD FOR THEM- I MY SELF SOME TIMES COPY A NICE FORM THAT I SAW SOME WERE AND DO IT MAY BE IN A DIFFERENT WAY BUT ALWAYS ALWAYS I GIVE CREDIT
THE SHAPE OF THIS ANVIL IS ITALIEN SHAPE ONCE UPON A TIME IT WAS CAST IN ITALY TO DAY IT IS CVASTED IN CHAINA IN EUROP THEY ARE SOLD BY ANGELE MASCHINENBAU ONE CAN FINED THE ANVIL IN HIS CATALOGUE IN FOUR SIZES 20-35-50-75 KG WWW.ANGELE.DE THE NIMBA ANVIL IS A COPY OF THIS TRADITHINAL ITALIEN ANVIL HOFI
STAN HOPE EVERY THING WILL GO WELL. I''LL BE WITH YOU ALL THE TIME DAY AND NIGHT.AND FOR ALL YOUR FAMILY TOO HOFI
IForgeIron Blueprints Copyright 2002 - 2007 IFORGEIRON, All rights reserved. BP1010 Forging a Point by Uri Hofi I want to show my system of forging points, which is one of the elements that we often do. This one will be a short 2'' (square point on round steel) forged in one heat. The points. Put the steel (5/8'' round bar) on the far edge of the anvil hanging out 3/16-1/4'' in an angle that is half of the future angle of the point. If the point is 30 degrees the steel will be in 15 degrees . You forge with the hammer 90 degrees to the steel when the hammer is a 1/3 out (beyond the edge) of the edge of the anvil. You hammer 2-3 times on a side and rotate 90 degrees and hammer the other side again 2-3 times creating an off center neck. You pull the steel towards you until the end of the steel comes in one line with the edge of the anvil with the neck up you tilt the hammer out to almost 45 degrees and forge straight down while rotating the steel 90 degrees every 2-3 blows. The tilted hammer forging 90 degrees to the anvil with the edge of the hammer we will move the metal fast and then creating heat. Then you bring the hammer back to an angle that compliments the angle and planish. The finished point 2'' long on 5/8'' round steel. The technique is based and derived from the bp how to hold and guide the hammer''. The handle of the hammer must always be parallel to the anvil. Uri Hofi
THE BASIC IDIA IS TO PUT THE TABLE APPART AND INSYOLE IN OTHER PLACE IF NEEDED. IN THE PHOTOS ONE DO NOT SEE THE FINISHED PRODUCE BUT THE QUESTION WAS ASKED AND HERE IS THE ANSWER. ON THE UPPER PART OF THE LEG A SMALL PLAT WITH A SLOT IS WELDED. ON THE WOODEN OLIVE PLAT TOP ON THE BOTTOM SIDE 3 GOOD WOOD SCREWS WITH A NICE HEAD ARE SCREWED IN TO A CERTAIN DEPTH ,THEN WHEN TUREN OVER THE WOODEN SCREWS HEAD IS GOING INTO THE SLOT AND THEN TURNING A BIT LIKE IN THE BAYONET SYSTEM ( like holding the lence in the camera ) THE TOP IS HOLDING THE WHOLE INSTLATION FRO FALLING APPART. NO NEED TO PUT A SCREW OR A PIN IN THE TENNON JOINT!!! HOPE THINGS ARE CLEAR FOR NOW HOFI
THE STEEL IS 1045. MOST OF MY CARVIUNG TOOLS ARE FORGED FROM. QUENCHED IN WATER AND DROWOUT TWICE TO YELLOW TO GET BINITE WHICH MAKES IT VERY HARD AND TOUGH AND A VERY GOOD AND LASTING CUTTING ADGE.BECAUSE THE GRAINE OF THE 1045 STEEL IS VERY SMALL .SOME TIMES IF SOME ONE WANTS A MORE PROFESIONAL TOOLS I FORGE THEM FROM W1-W2 OR O1 AND D2 WHICE ARE MORE COMPLICAT TO FORGE AND QUENCH. THE WOOD IN THIS CASE IS FROM ROOTS OF OAK TREE WHICH ARE VERY GOOD FOR MALET HITTING WHILE CARVING THE GOUGE AND ALLTHE TOOLS ARE FORGED WITH AIR AND HAND HAMMER , BELT AND MINI HAND GRINDER NO PROCESS PHOTOS YET ALL OF THE TOOLS THAT ARE IN THE THREAD ARE A BIT GOUGE WITH BIGGER RADUSE HOFI
Olive toped coffee table, designed and forged by Raffi and Sahar Hofi, My students and loved ones Hofi
carving tools forged for a customer hofi
carving tools forged for a customer hofi hofi
HAPPY NEW, PEACEFUL AND GREEN YEAR. HOFI
The attached show the design and forging of my granddaughter Sahar Hofi in the last 2 months. http://picasaweb.goo...inshemer/SczUP# Hofi
http://www.angele-sh...foldershare.php Attuched the my 75 years birthday greetings from ANGELE GERMANY Click Here Hofi
Fciron thank you for your explenation and suport when Frank Turley said before asking me how I control and maintain the length of the point my my full answer was ''some knoledge in geometry and experience'' the squar steel is having 21.5 % more matirial then the round in the same dimention . means that if you round a piece of squar steel it will be longer 21.5 % 1/5 but while rounding the steel after forging squar it swels a bit there for practicaly we calculat 13-15 % longer in this operation. In every rond steel a cone is hiding and in the squar steel a piramid is hiding .The proportion in both of them between the full matirial and the cone and the piramid is 1 to 3 that means that if one leavs a ''blob'' of 1'' and start the forging from the behind towerds the point or with the hammer tilted or put the blob on the far end of the anvil you will always get a 3'' point !!! The beuty is that geometry is working in All diameters the same 1-3 many people thinks that if the steel is thicker you need a smaller blob to start with and this is wrong. and why did I start with the proportion between the round and sqar ? if you forge the point on a round steel there is 20 % less matirial and you forge squar piont you will get the point shorter but when you will forge to octagon and round you will get it to the right designed length. If one is forging a point from squar steel then one will have to start the blob a bit sorter 15% to get to the intendent length After having this geometry knoledge one needs some experience to master it. the longest point I forged in one heat was 10'' IN 5/16 AND 3/8 with my trick system Hope I made it clear enough Hofi
Can any one tel explain me the meaning of the words ''THE HOFI BLOB'' and how it is conected to the ''Hofi NEAT TRICK'' Hofi
Assorted types of anvil tools and anvil arrangments that can be used on any anvil http://picasaweb.google.com/hofi.einshemer/AnvilTools Hofi
another way to one heat tong blank is to use flat steel in this case 5/16x3/4'' Hofi
No levelers in there Hofi
Yes this is the actual jur I had several of them in my smithy at one time hofi
The problam is now that the BP are not in order .BUT I can make on with the PUCASA and put it in the forum the moment i''ll have the time for . Any how thank you for the interest Hofi
Sorry but I do not know of Fredolin wolf. those bulls are forged in Europe for centueries now and many blacksmith along the hitory of forging toke the chalenge of forging a bull Hofi
Tools I attuch tothe air hammer dies
Hofi replied to Hofi's topic in Power Hammers, Treadle Hammers, Olivers
This stand was commissioned for a collector of ancient jars this jar is 3000 year old and its value is 10000$ THE idea of the design is to show the beauty and grace of the jar without interfering in the jar form ,to hold it from the bottom and let it ''fly'' upwards. I also show here how I use big magnets to hold the parts together . The use of the magnet is some thing that I use very often i many places that I have to put parts together when one works alone HOFI http://picasaweb.goo.../AnticJarStand2
Beth + bentiron thenks I am working this year 4 days a week with my grandfather at the smithy but on top of forging I also work with hand and wheel ceramic (potery) and make ''ucarina'' type of flute, knit with wool, weave carpets,make all the drawings for my grandfather and many other painting,learn to sing jewish easteren liturgy easteren songs in Jerusalem and teaching perma-cultuer and natuer preservation. The dress in the photo Idid myself. yes one needs a good per of good and strong hands for this job and lots of knowledg ,II wet and soak the dates palmefibers in water over night many times in hot water to go faster but it is harder to plat olive branches SAHAR
Some of the ellements I forged for jobs I did in the last several years http://picasaweb.google.com/hofi.einshemer/AsortedElements Hofi
