I think your best and easist path would be to cut the block into strips. Then sandwich them into a bar and TIG weld the edges back into a more or less solid. Because of all the chrome, about 18% and nickel, about 11% 304 won't forge weld so TIG or MIG with SS wire are about the only options.
I have to agree that a great precentage of people I've met through blacksmithing are the most helpful, friendly, and encouaging. I know there are smiths out there who keep 'trade serects' and won't tell you anything, but I have yet to meet one.
I don't know if it will work on an anvil but back in the day, we cracked the side of an engine block of a 426 hemi. Those things were too expensive to just scrap it so we drilled and tapped a series of holes along the entire crack starting just past the end of the crack. After each screw was put in place it was ground off even with the surface and the next hole placed to overlap the first. It took a long time but the fix worked, no more water leaks.
Zom, are you sure that is a Hay Budden? All of the HBs that I have seen including my 190# say they were Manufactured Brooklyn NY on the bottom line. Course I could easily be wrong.
Back when I used to make steel in 200 ton batches, we would tap stainless out of the furnace around 2650 and the fancy alloys around 3000. In both cases there was all kinds of supper heat in the steel to allow us to pour it. The alloy steels 4140 or 8620 for example were actually run into a second ladle that was housed in a vacum tank so it had to be much hotter for the extra handling. So 2700 should be fine.
Those nails are the ones the are used to put together concrete forms. The idea being that you can drive them in tight with the first head and still easily pull them out with the other head once the concrete sets.
I've used muiratic acid to clean an old badly rusted hammer head. It had been sitting in a basement for years. I was really surprised how well it turned out. I just dropped it in a jar full. One thing to keep in mind, the fumes from that stuff will rust everything in the shop and it isn't too good for your lungs either so do it outside.
These are my first attempts at Chrismas ornaments. The large one is really too heavy for most trees and neither one is very straight. Something to hang in my shop. :)
Merry Christmas to All y'all
You might get in touch with one of these guys. My first blacksmith class at John C Campbell Folk School was taught by them. They're both based in Missouri.
http://www.washingtonforge.net/ Pat McCarty
Bob Alexander, you have to email him through the folk school web site.
I liked the ornament idea enough to give it a try. The first one turn into scrap. The second is made out of 3/16 round and is a little heavy. The other is 1/8 round stock. Neither one of them is very straight but a good learning experince none the less. I tried to forge weld the first with no success so the other 2 are mig welded into a large lump on each end. Then they are drawn out. The finish is from a brass brush.
I made mine by stamping a simple CK into a piece of mild steel then heating the pein of a ballpein hammer to almost melting point. Once the hammer was hot, I hit it into the stamp mark to make the stamp.
Here's a view of my post vise in a portable stand that one of the guys in our group(ABBA) made. One of the things that make it nice is that by adjusting the chain lengths you can make up for uneven ground.
One tip I learned from Steve Williamson is that once you have cut the horns/ears, lay them back down next to the stock. By being against the main body of stock they are not likely to burn off.
I gave $400 for my 190# HB that is in about the same condition as the one in the pictures. You can find another gun a lot easier than you can a good anvil.
For those who like to make wizards and other things out of railroad spikes this jig can come in handy. It's made by cutting most of one side off a piece of square tubing. Fold one end over and weld it shut. Attach a piece of 3/8 square stock to the bottom to hold it in the vise and lock the spike in place.
