billyO
544 -
Everything posted by billyO
Very nice. If you're looking for a project, how 'bout one for me??? :rolleyes:
Hello all. I'm new to larger projects (railings, gates both garden and driveway, etc) and am looking for information regarding minimum size requirements/suggestions for stock. Are there any resources other than experience that provides this information? ie: would 1/2" x 2" be too small, overkill, 'bout right etc for the outer frame of a gate? Is 1/4" square too small for inner frame elements? when scaling up to a 6', 8', 10' span how should one scale up the stock size? thanks in advance
As a physical therapist (that'a physiotherapist for those of you across either 'pond') by profession for the past 17 years with 12 of those in orthopedics, my first thought would be, OK but what's the problem. If it ain't broke, don't try to fix it.
AISI 4140 Structure after Quenching
billyO replied to oghshf's topic in Heat Treating, general discussion
I believe what Steve is referring to is the fact that oil and water doesn't mix, chemically/physically, unlike,say, salt and water. The salt dissolves in water, oil will not. The best you can do is stir the oil and water rapidly enough to break the puddle of oil into many tiny drops that are "suspended" in the water, not truly dissolved. As time passes, the oil, being less dense will form into a puddle again on the top and separate, whereas the only way to remove salt, once dissolved (a solution) is to evaporate the water. So...if you're quenching liquid is a mix of oil and water, the question remains, "how do you make sure you have a uniform solution for a uniform quench?" I believe that what Steve is referring to here is the actual rate of cooling for the liquid (degrees of temperature change over time) you are using so that you can compare to cooling rate curve of your specific alloy to determine the percent martensite, bainite, etc. Here's a great reference that should explain this more thouroughly(sp?). http://www.dfoggknives.com/PDF/Houghton_On_Quenching.pdf -
Do you think you could use the fire for the small part of the scroll, then do the rest cold? You hit the proverbial nail when you said, "Even heat (or non-heat) is best." With 'Even' being the key word. Heat just makes it easier.
Hello all. Last fall, I was given an older gas powered generator/welder and was told, "The last time I used it, a few years ago, it worked fine." We did a basic cleaning of the fuel system (ie, purged old fuel, cleaned out the bulb, screen, tank, new fuel line) added some SeaFoam to new fuel and the engine started and ran for about 60-90 seconds. The following week, I changed the oil and have yet to be able to start the engine. Actually, if I use starting fluid, the engine will run for a couple of seconds only. I know more about diesel engines than infernal combustion, so I could use some help. I'm thinking a carb rebuild is next, do you think this'll solve the problem? If it's anything more involved than that, I need to take it somewhere. thanks PS - It's a Marquette welder with an Onan engine. We're guessing it's circa mid- 1950's Let me know what more info you need.
Localize the forging heat only at the portion of the eye that you need to move?
From a fellow Pisces, and avid fisherman, I love your design for the fish. Your friend is lucky.
Hello all. Does anyone have any info on either a Famco 40 or Alva Fallen BT5 punch press? Are they good machines? thanks billyO
Hello all. If you go to the NWBA website, in the April, 1986 Hot Iron News, there are 6 different puxxles pictured. Have a safe and happy New year!
Is it possible to make a full sized jig, starting with something like thick aluminum wire (large enough to minimize further steps but small enough to handle the trip back to the shop as well as easy to handle) on-site to make the curve, then bring that to the shop and use as is or beef it up?
This most certainly isn't the answer, only an answer. I think it probably depends on the size of the axe, but I have one that I was told awas from the 19th century with a 14" blade and it looks like it was made by forging the blade and both sides of the eye flat then eye was formed by wrapping it and riveting making an eye that's approx 5-6" deep (pretty tough to punch/druft through this thickness) The edge looks like it's done the way many axes were, by welding a carbon steel edge piece.
Does anyone have a reference for Angelo Bartolucci's works?
billyO replied to JRigoni's topic in Book Reviews
I know that a book of plates was prepared (I saw the original copy of approx 80 plates and it was beautiful, there's a plate showing how he took a piece of rectangular stock (I think 1/2 x 1 x 4) and forged it into a coffee creamer) and ready to go to printing, but there apparently was a disagreement between the family and the publisher so it's now in limbo, probably never to be published. Funny you mention it because for the past couple of months I've been thinking about trying to contact the Bartolucci family (I have cousins from not too far away from where he is from) to see if there's any possibility to get this project going again. I'd love to know if anyone else has any more info Oh yeah, I forgot to mention that the NWBA's Hot Iron News Spring 2002 has the plates for the gladiola you've got there and a hummingbird that he deomonstrated at the ABANA and NWBA conferences when he was here. Go to the HIN archives section of the NWBA website. -
I always thought the best hammer was the one that someone else was swinging... ;)
Good question, George, and not a quick answer (it rarely is with me, I guess), however since you asked, I'll give you my standard heat/ice speech...(can I bill for this?) Yes, there is more going on than just blood flow, but you're correct in your thinking that vasodilation is the key. Just so we're all on the same page, let me give a little background. With any mild/moderate musculoskeletal soft tissue injury, there's an acute and chronic phase of injury/healing. **My disclaimer: (Severe injuries should be evaluated by a surgeon, even though they have the similar physiological responses, that's why I'm not including them here.)** The acute phase is immediately following the injury to 2-3 days after the insult has been corrected, and the chronic phase is post-acute to healing. (to all the MDs, athletic trainers, and others in the audience who know more details than I do, please forgive my generalizations...) During this acute phase, there is still active swelling occurring and the goal is to prevent this excessive swelling (the chemical components of swelling initiate the tissue repair process, but excessive swelling impedes healing and rehabilitation). We prevent excessive swelling by what I call RICEM. Rest, Ice, Compress, Elevate and Medicate with NSAIDS as appropriate. What I mean by appropriate is you can ALWAYS put an ICE the injury, you can ALWAYS REST the injury, but compression may not be appropriate (ie, I wouldn't compress a neck strain), elevation may be difficult (ever elevate a hip strain???) and meds may not be wanted or contraindicated. As mentioned, heat always causes vasodilation, so this is contraindicated during active swelling because although heat feels good to most people, it will mainly contribute to more swelling and slowing down your recovery. There's also some debate as to the timing and/or depth of the vasodilation with icing (if I'm still current on my reading of the research) so the medical field still prefers ice during the acute phase of an injury (again, unless specifically contraindicated). So why ever use heat? The other thing that happens during both the acute and chronic pases of most soft tissue injuries is that all the surrounding soft tissue tends to spasm and contract in what the medical field calls 'muscle guarding' or 'muscle splinting' and this is the body's natural protective response to help prevent further injury. If you're not moving the injury, you're not increasing the damage, inflammation (Rest?) and pain. Heat will almost always relax soft tissues (a warm rubber hose is much more flexible than a cold one) which helps to make moving and rehab easier (a good thing from a PT standpoint most of the time), but remember heat always causes vasodilation, so this is contraindicated during any active swelling/inflammation. In my experience, the patients who do the best with sprain/strain type injuries are the ones who are able to pay attention to their discomforts and pains and learn to distinguish which ones are from tightness/guarding (heat and gently use these) and which ones are from inflammation/swelling (usually more of a soreness or burning, but mild inflammation is also often described as an ache) and to Ice these. So this begs the question "does this mean that I only need to ice the first few days after my injury?" My thought is that, in general, if you have any soft tissue pain when at rest, your body is telling you that you have inflammed tissues and these need to be iced and rested. Also, there is good research that ice can reduce spasms, and ice also tends to numb sensory nerves temporarily so this can help provide some temporary pain relief, further tipping the scales in favor of trying ice first. Don't forget to consider it the depth of the injury/inflammation. Tissue temperature changes from heat and ice only penetrate an inch or so, so this needs to be considered when deciding to use heat or ice. In general, what I tell all patients is to try ice first, if that doesn't provide any relief after a couple of days, then try heat if you want. Ice will never slow down healing, heat might. Howerever, if you use heat, you need to pay attention to how the area feels 30-60 minutes after you remove the heat. If it feels good, then continue to use heat if you want. However, if there's no relief or increased sorenss/ache 30-60 min after taking the heat off, then you're incresing the inflammation and you should NOT use heat. Above all, don't forget the basics: If you're getting better, keep doing what you're doing. If your not getting better or if you're getting worse, you gotta do something different. And above all, forget the "No pain, No gain!" mentality but remember "Use it or lose it!"' I'll try to clarify if necessary...
Swage Blocks, what do you use yours for, and how often?
billyO replied to John B's topic in Swage Blocks
Hello all. I wish I had a swage with dish/spoon depressions, and all my holes are too big for what i do, but I bought mine because of all the edge groves, one side hex, one round, one a 90deg vee and one a 60 deg vee. I use it mainly to hold stock for chiseling round stock, chiseling on edge of square, turning square to triangle, round to hex, etc. -
Does anyone out there that can forge roosters?
billyO replied to HammerDown's topic in Problem Solving
Hello all. If you check out the NWBA newsletter, Hot Iron News (HIN) Spring 2002 issue (It's available as on the NWBA website), there's a storyboard of a demonstration done by a smith from Italy, Angelo Barrtolucci, on making a hummingbird out of one piece. It shouldn't be too tough to adapt it to a rooster. btw- I also saw a collection of his storyboards that were going to be published at one time and one shows how to make a creamer (as in coffee and cream) out of a single piece of rectangular stock...amazing -
Hello all, I had to respond.... Not necessarily, each injury should be treated individually (speaking as a PT for the past 17 years). But all PTs will give the same advice about this type of sprain/strain injury. Rest the overworked muscles, ICE the inflammed tissues, stretch the tight tissues and gradually build into any activity involving strength, especially when impact is involved. just my 2 cents....
Blacksmith for the Boy Scouts
billyO replied to Ridgewayforge's topic in Blacksmithing, General Discussion
Hello. Not sure if this info would help, but at our annual swap meet in Seattle, I met a few smiths who had started a merit badge the year before, and the NWBA donated some stuff. I bet you could contact them through the BSA to get info on how they organized their sessions/lessons. -
Hello all. One more thought on the anvil tapping. In my experience, if you use the hammer like you are 'throwing' the head at the work like some smiths talk about, you have a very light grip on the hammer and when I do the occasional tapping, its to readjust my grip on the hammer, either to correct for minor twisting from poorly aligned hits around the axis of the handle, or to make minor adjustments along the length of the handle when I feel that my grip is sliding back from the balance point of the handle, making my wrist "radial deviators" (as we say in the physical therapy field) work harder when picking up the hammer for the next blow. Which, if unreasolved, will give a good case of tendonitis. I also do this to adjust my grip on handles of hammers that don't fit my hand very well. I've got rather long, skinny fingers and skinnier handled hammers make me adjust more.
salt pot heat treating
billyO replied to gearhartironwerks's topic in Heat Treating Knives, Blades etc
John - I, too listened to Bob Kramer, and I asked him a similar question, and I understood him to say that all of the above are viable options. The best one is the one that YOU learn to use with YOUR equipment and YOUR technique, and remember that each time you make a blade with a new/different batch of steel, you may have to adjust your temps/times to get consistent results due to the vairable alloy contents in each different batch of steel. -
Spoon to handle Joint - How to?
billyO replied to Borntoolate's topic in Blacksmithing, General Discussion
Hello Borntoolate. If starting over is an option, why not forge all out of one piece? Forge the handle, leaving a blob at the end to flatten then dish into your spoon. Same thing for the fork...
