Elemental Metal Creations
412 -
Everything posted by Elemental Metal Creations
It followed me home
Elemental Metal Creations replied to Glenn's topic in Blacksmithing, General Discussion
A friend gave me 8 backhoe teeth and in the box was this interesting piece. I have seen pictures of one (likely on hear) but I can't rember what it was called. -
It followed me home
It followed me home
Lesson learned. Don't ask a lawnmower repairman if he has a couple of old blades to get rid of unless you are serious! 72 blades, 10 short shafts and misc. bearings and pulleys. -
Thanks Thomas, I have that but I couldn't find a date.
Finally got my Cole vise cleaned up and mounted. It still has some of the original green paint on it. Does anyone know when these were made?
Blacksmithing gems and pearls
I have said this many times, people look at me funny when I tell them that youtube can get them hurt. Course some people look at me funny anyway ;-) -
You inspire me Ausfire. Beautiful work.
Show me your snakes
Elemental Metal Creations replied to ausfire's topic in Metal Sculpture & Carvings
New at scrap metal art.
Elemental Metal Creations replied to Elemental Metal Creations's topic in Metal Sculpture & Carvings
Thank you Das for the kind words. I like the idea of the nuts on the feet, I am also thinking about welding a piece of pipe on thee bottom of the owl so they could be mounted on a stake. -
I have recently started doing scrap metal art. Here are a few of my first pieces. Let me know what you think.
Vice repair advice and Id please
Elemental Metal Creations replied to Elemental Metal Creations's topic in Vises
Thanks for the tip. -
It only took about 10 min. to remove the bracket and spring. I used a Lennox diamond cutting wheel to cut most of the way through the welds and proper application of force to break them free, no damage to the body of the vice and I will be able to salvage the spring. Now to carefully grind off the welds. -
My Dad carried one in his tool box that is about 3' tall. He was a carpenter and retired in "78. I still have it in my collection.
Thomas, I know that wrought needs to be very hot, I guess that taking a sledge to it cold would be a bad idea. -
T.P., I wish I had access to a press, will have to talk to my mechanic. The jaws do have steel inserts welded in. I thought that the pivot holes may have been worn until I got it apart. Kozzy, I already plan on making a new bracket, I will see about the spring. Paragon, That is a pipe bushing, it fits perfectly so it may get to stay. Thanks to all. -
I picked up this vice from my nephew sat. I knew it would be a rescue/repair as it had been sitting outside for 20 years since he bought it. The only markings I can find is the weight, 100. Any ideas on who made this, or approx. age? The main post is bent just above the mounting plates for the moving jaw causing them to misaline. Some one went nuts with a welder, welding the bracket and spring in place, and adding adding 8 inches to the bottom of the leg. The biggest issue is the extreme pitting of the jaws. I am thinking of either welding them up and then grinding them flat or making some covers for them. Are there and options for repairing the jaws I am missing? Fortunately the screw and box are in pretty good shape.
It followed me home
Went to see my nephew yesterday and this followed me home. The bad thing is we never agreed on a price, it will be something forged when he decides what he wants. Not to worried though, we have been making deals like this for 50+ years. -
Pig roasting spit
Elemental Metal Creations replied to Elemental Metal Creations's topic in Blacksmithing, General Discussion
So 1" black iron pipe? -
I have been commissioned to make a pig roasting spit for a friend. We have settled on a height but I am unsure about the length for the spit and size of materiel. He said that he only wants to roast a pig about 50 lb, though I suspect that this may change in the future. My questions to anyone who has experience making or using a spit like this are, would 3 ft between uprights be sufficient, and would 1/2 in. stock be strong enough. Thanks in advance.
It followed me home
Das, that stuff gives me nightmares.I worked in an onion ring factory. the 2nd worst thing I had to do was change the belts on the friers in the middle of a shift, above 300 gal. of 360deg.f oil. The worst was fixing the belt in the flash freezer at -40 deg f. -
Champion 145 for $16. I was happy to give $75 a couple of years ago for one with a cracked pan.
I use ATF in my #40, works good in all weather.
It followed me home
Clay mixed with sand works great, I wish mine looked this good. -
Small cable damascus knife
Elemental Metal Creations replied to Elemental Metal Creations's topic in Knife Making
Das, I thought about cleaning the handle but decided not to on this one. Actually there are a couple of inclusions in the blade. I'm not to worried about it on this one as it will not get much use. I was just happy that I was able to get it to weld this good. I have a lot of cable in 1/2" and 1" to practice with.
