Bob Menard
    62
Everything posted by Bob Menard
  1. You should charge big money for this, you know big shears big money.
  2. I have two the tie for just plain weird. The first was a branding iron for a silly white kid who wanted it for branding his own skin. Apparently this is some sort of family tradition started by his grandfather. The design he submitted was kind of intricate. I responded that this would be a tough design to create and had he thought it through. To get the design effect on his skin the temp of the brand would have to be just right. too much heat and the resultant burn would obliterate the delicate design. Too little heat and it would not be deep enough to be permanent and he would have to try again and get the indexing just right, again so as to not obliterate the detail. The second one was a mother who wanted a type of grappling hook for her 9 year old son. This was by her description to be used for scaling trees and building faces. Apparently this was some type of superhero training. I tried to have a conversation regarding climbing safety and life safety loading for such a device. She indicated she wasn't really interested is such information. Both commissions were declined but the letters were saved.
  3. The style of apron is really dictated by what you are trying to protect. My forging apron is primarily protecting my waist, goodies, and ends mid/lower thigh. This was arrived at by looking at a wear pattern on my clothing. If I need to protect my upper torso, say for welding, I have a leather welders jacket. Living in northern New England this doubles as protection and warmth. I like just a waist apron that ties in the back for freedom of movement. I have seen Smiths that seem to like the full frontal leather armor but for me at the end of the day it looks heavy and adds to the fatigue factor. Again what are you guarding against?
  4. The eye brow I have is removable and is mostly useful up to the point where the stack heats up. Once it is hot the eye brow is no longer necessary and the hood is drawing the smoke laterally back away from the firepot and keeping the local environment clear. I have a plan for the hood. If you would like it send me an email, ballandchainforge@yahoo.com and I will send it to you.
  5. Bob Menard
    Vise ID
    So many post vises were hand made, identifying yours in the absence of a makers mark is likely impossible. Some of the characteristics the help date a post vise is the extra detail added during it's construction, like chamfered edges and the extra detail added to the screw box. This is not always an indicator as the person/firm that made it could have been feeling expansive for that tool and added extra detail. It is not easy to forge a post vise and once you are into it adding embellishments might seem like a good idea at the time. Lets see some photos, it might help.
  6. Bob Menard
    Striking Vise
    Many vises are set to high for hammer work, good for filing and finishing just not hammering. Both of these are good hammer solutions. Of course the big heavy tools are necessary for serious hammer work. Good job guys!
  7. Good score for a hundred bucks. The pipe jaws look like an add on.
  8. This is a coal forge I made as a portable demo rig. It breaks down so the largest part is the hood. It can practically fit in a compact car. The table is 1/8" diamond plate bordered by 2"x 1/8" angle iron. The legs are 2" square tubing. The hood is 16G aluminum. It is set up for either an electric blower or a hand crank blower.
  9. Nice looking forge, it should serve you well. Once years ago I had a coal forge that had a grate at the bottom of the firepot instead of a triangular clinker breaker. It would degrade over time and I would have to replace it. I would suggest keeping a grate in place to protect difficult to replace fabricated parts and have an extra on the shelf to throw in when you are in the middle of a project and the primary burns out.
  10. I have found that the forge table is just that, a table. It holds coal/coke and tools. The fire is contained in whatever your are using for a fire pot. If you are not planning on moving the forge you can make the table from whatever weight material you desire, even masonry. The heart of any forge is the pot and tuyere.
  11. The original post seems to have been a little bit hijacked. As it has been I'll add a few comments of my own. Another method of making a hard point on a digging bar is to case harden the end. It is amazing how effective this technique is for improving mild steel. The downsides are if you have to dress the point you can grind the hard shell right off. Another problem, case hardening only effects the surface so if you are banging your digging bar on a rock you can drive to point back into itself because the softer mild steel core is not strong enough to support the hard point. I will use case hardening for tools like top and bottom swages and fullers that don't get dressed. Francis Whitaker had a few comments regarding tool making. He said you should use known tool steels, preferably new. Then you always know what it is you are working with. He also suggested you should get comfortable with a few grades of tool steel and become proficient with them. Your tool making will be more consistent and you will have a better result in the long run. Much of my tool making has been influenced by Mark Aspery as evidenced by the tools shown here. I use 4140 regularly and I am comfortable with the techniques of hardening and tempering it. I have to buy it new. Apparently in places in the US where there is oil drilling 4140 lays about in piles and is known as sucker rod. No oil in New England so no sucker rod. Anyhow... The technique to making hand tools with this material is to forge it to form, bring it above the critical temp, generally orange, and bury in vermiculite to cool very slowly. I find it takes all day to cool with this method so I just leave it in overnight. The next morning it is dead soft, like mild steel dead soft. This is where I do any filing or grinding to final shape. Then the tool is heated back above the critical temp. Not the whole tool but more like 4"-5" of the performance end. The struck end is on its own at this point. I then quench the end 1" or so in water dipping it up and down until water stays on the working end. For me this is a major selling point for 4140, water quench. I then abrade the end of the tool looking for the colors (purple to straw) which are generally an 1 1/2" away from the end. I watch for them to run toward the end, aiming for straw at the working end, and repeat the quench technique again. I re-abrade the end and let the colors run again. The tempering heat is supplied by the residual heat stored in the body of the tool. I will run the colors as often as the tool has heat for which for a chisel or punch is usually 3 times. I did make a hardy hot cut recently that ran the colors 7 times but the body of the tool was stocky. I don't ever quench the entire tool. It is made harder by quenching the tip and air cooling the rest but it is not made too hard, which would risk the tool cracking during use or making it harder than my hammer, which would be bad for the hammer. I have had good success with this method and my hot cut chisels work just as well as a cold chisel. I have yet to have a working end fail or a struck end crack.
  12. This is a small press I put together. It is not my own design. A very clever blade smith in Vermont made one and demonstrated it's effectiveness at a New England Blacksmiths Meet. I liked it so much I made one for myself. The frame is 2" square tubing with a 1/4" wall thickness. I added gussets at stress points. I am not sure it needed that but I had the welder and there I was..... It is powered by a 20 ton air over hyd. jack from harbor freight. It is a little slow but once you get the technique down it works surprisingly well. The first photo shows the build phase and the second shows it complete on a fabbed stand with casters. I will likely build a larger one in the future but for now the little one is working.
  13. It looks pretty stocky, maybe to heavy to carry around to picket a horse or even a small herd. Is there a chance it is some ones idea of art? I have seen stranger.
  14. Unquestionably interesting. The part I liked was the 3 different levels of tech represented in the video. The last being most recognizable to western eyes, hand crank blower, London pattern anvil, hammers with handles, forging standing up. All three were making the same agricultural implements. Some of those smiths could have been working with some of this higher technology but chose to do it a harder way. Hmmm, I wonder why. In the video side bar there was a French film showcasing a modern high tech steel plant featuring smelting from raw and scrap and forging with a 100 tonish hyd. press. I see a lot of people commenting on the internet lately about blacksmiths using power tools like it is a sin. I still think there are only few ways to forge an 80,000 lb. billet. A guy with a rock is not one of them.
  15. Last year I bought a 272 lb Peter Wright with similar edge damage for $300. The seller wanted $450 For what the time was to fix it I thought that was a fair price. Peter Wrights Are a good anvil and the one in the ad seemed to have completely fixable damage. I did think the price was high for the size and damage shown.
  16. Yes, my bad. There are 4 newsletters a year. And to think I'm an editor. Should have caught that
  17. Hi Jimmy, New England Blacksmiths has already come up and there are at least a dozen blacksmiths within a 30 min radius of you. Increase that to an hour and there are likely 50. Some of those are operating professional shops and could likely facilitate you with stock. In my shop if the drop fits in a 5 gal mud bucket it is scrap and thrown away. One of those 50 lb buckets would likely keep you going quite a while. I also sell stock off my rack to smiths who don't ever order enough to make it worth while to go the steel dealer. The Teaching Center in Brentwood NH is currently closed during the cold season but will be re-opening the last Sat of March. The programs offered there would likely be very useful to you. NEB is friendly and helpful and we want to actively encourage young people. Too many of our membership are old folks and without an infusion of younger blood the craft is not sustainable. Check out our website newenglandblacksmiths.org and see what is available.
  18. Thanks pike3e for stepping up. I would offer time in my shop but it is in Portland, ME and my sense is he doesn't want to travel that far. New England Blacksmiths tries to be a resource and facilitator to those with interest in NE Darth taco, when you get to a point where you seek the company of peers check us out. The benefits far outweigh the cost of membership
  19. New England Blacksmiths can be found at newenglandblacksmiths.com This is an ABANA affiliate and has been in existence since 1975. It is the best resource for Blacksmiths in this area of the country. For the bargain price of $20 pre year members receive 4 news letters a month, access to low cost training events and we maintain a teaching center in Brentwood NH. If you're in New England you should be checking us out
  20. The classic question, Do you shoe horses? Yep, every time I see one I say, "Shoo Horse"
  21. I would think the "welding community" should have gotten the memo by now about the hazards associated with the processes. I suspect that even when presented with the facts most commerical welders would opt out on respriratory protection. Excuses like it is uncomfortable, it is a pain to maintain,(IE wash it once in a while), the cost. The business owner complaints would likely include the costs of fit testing. With these challanges it is easier to have people just filter their air through a cigerette filter and negelect to mention the effect of metal and fumes on respriatory health. Knifemakers on the other hand have gotten the memo and grinding a blade is only part of the work that goes into the finished product. Most knifemakers aren't wearing a mask all day. They also can expose themselves to other toxins not the least of which include some woods with toxic sawdust. I have always felt that if a previous employer was not giving me safety gear I felt I needed, I supplied my own. Ones health is ones own responsibility. The information is out there thanks to Califorina. It just needs to be a priority.
  22. It is a pine ridge burner. I have had very good results with them and if I have any questions they have been very helpful. The doors have held up well. The oldest forge I have built is now 5 years old. I still have not had to rebuild one. They are not a big problem to fix but the real wear part is the metal exposed to the heat of the interior. it does tend to scale and wear and I know I will eventually have to make a new one but that is easily done and not at great cost. The real money in this forge is the gas train. That part does not see wear. You can screw up the burner by shutting both the gas and air off at the same time. If the forge is screaming hot and there is no air flowing thru the burner it can melt the baffle plate right out of it. I usually let the blower run until the interior is black hot then shut it down
  23. When I need to use a metal fume respirator I use one I get from my welding supply house. It is made by 3-M, model 6391/07003(AAD) and costs around $20.00 It comes with metal fume cartridges and can easy changed to organic vapor cartridges which are for painting, and other uses. The 1/2 face piece with cartridges attached easily fits under the welding helmet and it is comfortable for extended use. Bob Menard
  24. I have used the same tech for a blast furnace to smelt bronze. I have also inadvertantly smelted steel in one of these forges. It got away from me a little bit. Those ribbon burners can get mighty hot. The material is Castolite 30. As I mentioned above, 3200 degree rated. The fiber is regular kao wool though it is called something else. Bob Menard
  25. After being in business for a good long time I finally got a website. For a couple of years I went back and forth. I worried about the cost and would it make me too busy. Everybody had someone who could set it up for me, Don't you want to try my friend, son, daughter, football coach, etc. Finally I contracted with a local company with national ties to the Hearst Corp. Great idea! The expensive part of their service is the search engine optimazation but they have me #1 in my area for my 3 search phrases, Blacksmith Portland ME, Ironwork Portland ME, Art Fabrication Portland ME The site has paid for itself, at what it currently costs me, for the next 2 years and counting. It has increased my business and I have learned a new word, NO. There are only so many hours in a day and I have been able to cherry pick the fun jobs. I have referred jobs to other professional Smiths because even though I am saying no I don't want to dissapoint a customer. I am currently booking work 8 months down the road. Probably 1/2 of it from the website. The cheapest advertizing dollars I have spent over the past few years for results given Is the lettering job on the Truck. This is now followed by the website. I will continue to pay for the web service. Bob Menard www.ballandchainforge.com
