how can i make a homemade forge on the cheap?
new guy
  • Replies 98
It comes as a surprise to a lot of guys that you don't need 1/4" plate to build a forge. My 3' x 4' coal forge has a fire brick covered 14 ga. table with a couple pieces of 1" angle "joists" under it and it works a treat.
Frosty
1/4" rebar is probably on the light side for tongs but they'll work. Having small tongs is a good thing though, you don't want to have to handle larger and heavier things than you need to.
Keep your eyes open for a piece of RR rail or other heavy thick piece of steel. 1/4" plate only seems okay because you haven't worked on something heavier. Then again if it's what you have it's the best anvil you have. If it works it's an anvil.
Frosty
The plate may weigh 40 pounds but directly under the hammer there is very little weight to resist the hammer impact. As Frosty says, look for something heavier. A good place to start is something with a mass of 50 to 100 pounds or heavier. You want as much of the mass directly under the hammer face as possible so think rr track, hydraulic cylinder, etc standing on end.
The following is good reading and should give you several good ideas on how to get started.
Lessons in Blacksmithing
LB0005 Blacksmithing Anvils
all of this is true and i can see if i can find a very heavy rr track (80lbs and drive it into this giant stump i have lying around. the stump is 3ft in diameter and 3.5ft high it weighs a good 220lbs of solid oak. i would like to note that the plate works for me beacasue it is easily portable and i need to move it when i clean up after working. can i mount the plate to the stump and use that for an anvil?
just as an after though can i make a tamped down sand base for my anvil? and thanks to all who have posted i probably would not have the blacksmithing projects where they are without the help i have gotten here.
hey can i make a really decent knife out of an old file? will that be a good beginer project?
Yes, if it's a really decent file. Nicholson and Simonds both have excellent reputations. With some of the cheaper stuff I've read that it can be hit-or-miss. (OTOH my first blade was made from an Indian file I bought at Harbor Freight, and it got absolutely screamin' hard in the quench. So not all the cheap stuff is total junk.)
Grind off the teeth before you start forging, or anneal the file and then file off the teeth. If you just forge them flat you're likely to create cold shuts that won't do anything good as far as your blade's strength.
Here's a very useful discussion of carburizing that's going on at one of my other daily-read forums right now. Blister/shear steel They're talking about wrought iron, but it'll work on mild steel.
I've only tried it once, using charcoal with sodium carbonate as my carburizing agent and an old cast-iron Dutch oven as my crucible. I cooked it for maybe 12 hours at somewhere around 1600 F (guessing from color) in a large wood fire. (Think burning a half-dozen or so dead trees.) It definitely made a difference in the steel, but I wouldn't have expected too much from it, performance-wise.
Burying steel in hot charcoal and leaving it overnight would anneal it if it were medium or high carbon, but it's not going to carburize it -- certainly not to a degree that makes it suitable for making a knife. You'll save yourself a lot of time in the long run if you do a little research before you dive into this stuff.
