new guy Posted March 8, 2009 Share Posted March 8, 2009 i want to make a homemade forge on the cheap so i can make tools for me and my son. obviously i cannot get a weber grill hot enough and i don't feel safe using a galvanized garbage can. so how can a start a forge with cheap materials? :confused: Link to comment Share on other sites More sharing options...
Finnr Posted March 8, 2009 Share Posted March 8, 2009 Blue Print 0133 the famous 55 forge. Finnr Link to comment Share on other sites More sharing options...
David Einhorn Posted March 8, 2009 Share Posted March 8, 2009 Blue Prints here:BP0133 55 Forge | Blueprints 100-200BP0115 5th Wheel Forge | Blueprints 100-200 Link to comment Share on other sites More sharing options...
dablacksmith Posted March 8, 2009 Share Posted March 8, 2009 ok.... what is a forge ? it is a place to hold fire (as far as coal ,charcoal or coke) and to be able force air to make it hotter! a hole on the ground will work! work with what you have on hand but keep in mind your goal... ive seen old forges that were wood and sand...they made a wood box with a pipe going thru leingthwise with a cap on one end (for a ash dump) . the pipe had some holes drilled into it about halfway down (middle of forge) that worked as grate air was forced down pipe and thru holes the box was filled with sand and sand was moved away from grate to leave a depression to grate.. verry simple and easy to change shape of fire just move sand ! ive seen same done with fireclay instead of sand ...or brake drum or tire rim or... i cant see your scrap pile but theyres bound to be sumthin....good luck! Link to comment Share on other sites More sharing options...
new guy Posted March 8, 2009 Author Share Posted March 8, 2009 thank you all for the help on this i will probably use the 55 forge or go for a sand and concrete lined hole in the ground. Link to comment Share on other sites More sharing options...
Glenn Posted March 8, 2009 Share Posted March 8, 2009 Do not use concrete as the heat can cause it to spauld throwing pieces of the concrete into your face. The sand can melt into a glass trapping some of the clinker and ash. It would better to use clay to line the hole in the ground, some use kitty litter when clay is not available. But what is wrong with just dirt? Link to comment Share on other sites More sharing options...
new guy Posted March 8, 2009 Author Share Posted March 8, 2009 that is good to know that kitty litter and clay is better than my ideas and exploding concrete in my face is not on my to do list. the clay lined hole sounds like a much more doable idea then all of mine. however i think that i will be using a relatively low temp forge. at what temp does sand turn to glass? Link to comment Share on other sites More sharing options...
John Martin Posted March 8, 2009 Share Posted March 8, 2009 Seems that we are having this question come up quite a lot latley, here is a real good example, with a tutorial, you can obviosuly modify it to be larger or smaller. Link: Charcoal Forge Gas is always another option: several kinds can be found here: Zoeller Forge Link to comment Share on other sites More sharing options...
blafen Posted March 9, 2009 Share Posted March 9, 2009 I made my first forge from straight up red river clay inside a tire rim with a piece of threaded pipe for a tuyere, and have gotten it up to welding temp with charcoal and a shop vac hooked up to a rheostat, the forge took me about two days and 20 dollars to make (most o the two days was spent waiting on the clay to dry) I had no preblems with the clay spalling, but at very high temps it kind of glazed over in a few spots, and i read you can make a very good refractory from ash mixed with clay. Link to comment Share on other sites More sharing options...
ThomasPowers Posted March 9, 2009 Share Posted March 9, 2009 if you are going to forge steel you will be above the melting temperature of sand. Link to comment Share on other sites More sharing options...
new guy Posted March 9, 2009 Author Share Posted March 9, 2009 all of this is good to know i think i will use clay or concrete to give a good thick inside layer to an old wheelbarrow i found at my grandmothers house. all i need to do is find a good metal pipe and the related fittings. oh and thanks to all for the ideas and help. i will try to post pictures of the final forge and what i am making when it is done. also can silt be used (i live next to a tidal lagoon) the silt is very clay like and it is not sandy. i think it is mostly clay. Link to comment Share on other sites More sharing options...
MattBower Posted March 9, 2009 Share Posted March 9, 2009 Skip the concrete. Use clay. A wheelbarrow will make an awfully large, heavy forge. Portable, yes, but unnecessarily bulky. Just a thought. Link to comment Share on other sites More sharing options...
Frosty Posted March 9, 2009 Share Posted March 9, 2009 If it's silt it won't fire, it'll remain dusty and dirty. Fire clay isn't very expensive and should be easily available at a concrete plant or fireplace suplier though the latter is always more expensive. I think the last time I bout a 50lb bag it cost me around $23. Kitty litter is bentonite clay and though I've never used it for high temps it's been used for a long time, perhaps centuries for patching cupola melters. Mix the clay with sand or better yet grog, crushed fire brick to help prevent shrink checking and spalling. You also want to mix it as dry as possible, just enough moisture so you can ram it in place with a mallet, hammer, etc. The less water the less shrinking as it dries and the less shrink checking. Think dried lake bottom. Once you have it rammed in, use a dull blade like a butter knife to score the liner, think expansion joints in a sidewalk, this will cause it to shrink check along the scored lines rather than randomly. A wheel barrow makes a heck of a forge, I can't think who here on IFI built himself one a while back. And lastly you can do this exact same thing to your Weber grill, lots of guys do it with old grills. Frosty Link to comment Share on other sites More sharing options...
MattBower Posted March 9, 2009 Share Posted March 9, 2009 (edited) I think I paid $12.50 for a 50 pound bag of kaolin at the ceramic store, last time I bought some. Kaolin will tolerate in excess of 3000 degrees F. But most of a solid fuel forge lining will never get hot enough to truly vitrify, let alone melt, so the type of clay isn't all that critical. Bentonite is actually pretty low-firing as clays go, but it's fine for this. In fact it's a good choice because it has excellent green (unfired) strength. (The green strength is why it's used as a binder in sand casting.) Edited March 9, 2009 by MattBower Link to comment Share on other sites More sharing options...
Glenn Posted March 9, 2009 Share Posted March 9, 2009 Take a look at BP0133 the now famous 55 forge again. There is no clay used. The air pipe stands proud of the bottom of the forge about an inch and the first fire provides ash to insulate the bottom of the forge. There are no "fittings" required for assembly. Any dish shaped object will work, bottom of a hot water heater, ag disk, steel automobile wheel, break drum etc., even a flat surface will work, you will just need to pile the solid fuel a little deeper. With clay you can sculpt most any size and style fire pot you want at little or no cost. This is not to discourage you from experimentation. Please try new things and report back what works as we may be missing something here. Link to comment Share on other sites More sharing options...
new guy Posted March 9, 2009 Author Share Posted March 9, 2009 i still think that the concrete and grog will work for the liner of a wheel barrow and i cannot use the grill because my dad said no to that (i'm 15 me and my dad both use this account). i personally think that a bigger forge will work because no one wants to steal a 3 or 400 pound hunk of concrete and steel, also it is what we have lying around and it is cheap. although i might go with other ideas i like the 55 forge or a washtub forge it i can get those for free or cheap. can i use steel rebar for tongs? i have some 1/2 in sections lying around and i want to get rid of it (or use it both work). Link to comment Share on other sites More sharing options...
Glenn Posted March 9, 2009 Share Posted March 9, 2009 i still think that the concrete and grog will work for the liner of a wheel barrow IForgeIron promotes safety, but your personal safety is your personal responsibility. Please invest in eye protection AND a full face shield, as well as a full set of leathers, gloves, sleeves, apron, chaps, spats, and shoes. It is no guarantee, but will be much cheaper than having concrete particles removed from tender areas of the body and/or an artificial eye installed. Link to comment Share on other sites More sharing options...
Frosty Posted March 9, 2009 Share Posted March 9, 2009 New guy the younger: First off, it's good to have another kidsmith on the forum. You're in good company, we already have the pleasure of the company of a number of fine young men and are always happy to add another. Forget the cement, it IS DANGEROUS in a fire. Use clay and grog or sharp sand, no cement. This isn't a fireplace where you can get away with a fireplace mix design, it's a forge and will get hot enough to spall concrete. You seriously do NOT want to be eating hot flying concrete chips. It hurts, I know. One of the beauties of the 55 forge is nobody wants to steal an old cut up 55 gl drum. It's also at a good working height. Now, repeat after me. No C-E-M-E-N-T in the forge. Or do we have to tell your Mom? Frosty Link to comment Share on other sites More sharing options...
CRAFTBENDER Posted March 10, 2009 Share Posted March 10, 2009 I haven't done much hot work in the past but one day when I was piddlin, I took an old green porcelain cast iron bathroom sink and put some plain charcoal in it and stuck the exaust of a small shop vac on the bottom of the drain hole. It made a hot fire. That might work for you. Link to comment Share on other sites More sharing options...
MattBower Posted March 10, 2009 Share Posted March 10, 2009 Look, lad, dig a bunch of clay from the back yard or local creek, screen/pick out all the pebbles, mix it with enough water to make stiff mud pies, and line your forge with that. It is FREE and it won't blow up in your face. Even if it doesn't contain clay, the worst that'll happen is that it'll get dry and dusty. That's a lot better than blinding you. I'm not sure why you insist on paying for concrete that WILL NOT work (it will crumble when it gets hot, even if it somehow doesn't spall) and WILL be dangerous. Link to comment Share on other sites More sharing options...
new guy Posted March 11, 2009 Author Share Posted March 11, 2009 so i guess that no concrete and i live next to a tidal lagoon and i will use the silt from that. the silt is actually mostly clay and ground shells. will the shells go boom just like concrete or will i survive? what the heck is sharp sand any way? Link to comment Share on other sites More sharing options...
Matt Bower Posted March 11, 2009 Share Posted March 11, 2009 Little bits of shell won't hurt anything. Whole shells might pop if they're full of trapped air. Link to comment Share on other sites More sharing options...
new guy Posted March 11, 2009 Author Share Posted March 11, 2009 that is very good to know. and i am completely confused as to what sharp sand is? Link to comment Share on other sites More sharing options...
Frosty Posted March 11, 2009 Share Posted March 11, 2009 Sharp sand is from crushed stone the particles are sharp and angular literally broken rocks. Natural sands are either alluvial or aeolian meaning made by water or air action and they are smooth and rounded like a river rock. Rounded sand does not have the ability to "key" in an aggregate, think of it like marbles in a sack, no matter how hard you compact it it'll still move. A sharp aggregate will "key" together and becomes very hard and immobile when compacted. If you are making concrete you want the rounded aggregate as the cement holds differently and sticks to smooth rocks better than sharp angular ones. (Not to bring up the cement in a forge topic again, this is just FYI) Anyway, sharp sand has another benefit in a refractory, the points and sharp edges make points where steam can escape easily without damaging the refractory while the angular material holds it all together better. Rounded sand makes a stronger pocket being smooth and rounded but it also means the pressure from any steam is evenly distributed so when it does escape and it WILL escape it breaks some of the refractory in the process. Frosty Link to comment Share on other sites More sharing options...
new guy Posted March 11, 2009 Author Share Posted March 11, 2009 that is very good to know and i think that i can use a sharp sand/silt/ash cake to line an old weber grill and insulate it that way. thank you frosty and everyone else for all the help. i have not even started the forge because it is raining and i have school, and work comes before play, and i hate to work outside in the rain. Link to comment Share on other sites More sharing options...
Please sign in to comment
