VainEnd84 Posted January 22, 2017 Share Posted January 22, 2017 So this is my first ever attempt a building a burner of any kind, so I figured a Frosty T burner would be a good place to start, simple and effective, it seems to have worked out rather well. I couldnt source a reducing 1" - 1/2" T so I had to use a 1" - 1/2" bushing to connect the tube to the T. Everything else is pretty much exactly as described in The Frosty T burner topic. Comments and crisicisms welcome, especially if it helps me make an even better burner. Here is video of it running in the middle I increase the pressure from 3 - 20 psi then back down to about 5 psi. Quote Link to comment Share on other sites More sharing options...
VainEnd84 Posted February 11, 2017 Author Share Posted February 11, 2017 I've finally found the time to build the second burner that I will be using in my forge, It needs a little tuning but they seem to be running well. Now I just need it to warm up enough here so I can finally build my forge. Here is a video of the two burner setup. https://youtu.be/ZgAjNPoO6r4 Quote Link to comment Share on other sites More sharing options...
Frosty Posted February 11, 2017 Share Posted February 11, 2017 You subbed a 1" T to 1/2"? I'm pretty sure the illustrated directions call for 1" x 3/4" for a 3/4" burner or 3/4" x 1/2" for a 1/2" burner. Regardless they look to be burning nicely outside of a forge. Are you going to be using them for torches? They tune differently in a forge due to back pressure. Looking good so far, keep us in the loop please. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
VainEnd84 Posted February 11, 2017 Author Share Posted February 11, 2017 I must have misread the directions, I thought the openings on the T needed to be double the inside diameter of the mixing tube. I have, however, found a local source for reducing T's in many different sizes so I won't have to use a reducing bushing which should make tuning them easier. Yes I will be using them in a forge. Once it's not -30c and I can work in my unheated shop comfortably, I will actually be able to build the darn thing. Quote Link to comment Share on other sites More sharing options...
Frosty Posted February 11, 2017 Share Posted February 11, 2017 Ah, that's easy to misunderstand, the intakes need to be 2x the AREA in cross section rather than diameter. 2x the dia. is 4x the area in cross section. It's a common mistake and I spent a lot of time trying to come up with a way to get it right in the directions in an easy to understand way. -30c eh, guess I'll stop griping about it being in the single digits f. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
VainEnd84 Posted February 11, 2017 Author Share Posted February 11, 2017 Oh, well now I feel kind of silly, but onwards and upwards! I will correct my error with the new parts. I haven't plugged the burners into my brick pile forge yet but will hopefully get there sometime this week, and it's supposed to warm up next weekend so I may actually be able to build my proper forge! Quote Link to comment Share on other sites More sharing options...
