BlasterJoe Posted January 3, 2017 Share Posted January 3, 2017 Well here is my second attempt at a file knife. This time I followed the step by step Glenn posted. The instructions were great and definitely helped me produce a better knife especially the heat treat portion. Thanks Glenn. I had trouble having the colors run the way that was explained but my thickness isn't as uniformed as it should be. That also contributed to a slight bend in the blade. It holds an edge well and still sharpened easily. I made the handle from a cut end of a hammer handle. Used JB weld for the epoxy. Little mahogany stain and some oil on the handle. Quote Link to comment Share on other sites More sharing options...
Glenn Posted January 3, 2017 Share Posted January 3, 2017 11 hours ago, BlasterJoe said: I followed the step by step Glenn posted. The instructions were great and definitely helped me produce a better knife especially the heat treat portion. Thanks Glenn. Glad the knife worked out for you. Thank you for remembering to mention those that helped your succeed, and thank them in the forum. Can you give a URL for the instructions you followed? Which Glenn did you refer to as there are several on the forum? Quote Link to comment Share on other sites More sharing options...
BlasterJoe Posted January 5, 2017 Author Share Posted January 5, 2017 Glenn, i looked it up again and you posted it a long time ago. The instruction were actually by Don Abbott. So thank you Don and thank you for sharing it. Quote Link to comment Share on other sites More sharing options...
