can anyone explain induction heat treatment ?
I need to harden and temper carbon steel on induction furnace.
The one i have is high frequency induction transformer.
The coil i made for it doesnt work and gets tripped indicating high frequency.
what is the diff. b/w medium fr. and high fr. inductions ?
and why does it trips ?
22 hours ago, the iron dwarf said:
you need to match the coil to the machine, check the specifications of the machine and wind a coil to match, set the frequency to the optimum for the coil
ok let me gather information about the setup then i will get back to you.
17 hours ago, BIGGUNDOCTOR said:
Also do not touch the coil with the part.
Small parts require high frequencies, big parts lower ones.
https://www.ambrell.com/ambrell-induction-heating
This is the company that we got a unit from, and they are very helpful with technical questions.
ok kind sir thank you.. will talk to them.
