What is this?
Is it the same on the other side?
Brass and steel aren't "damascus" though you can combine the two in a similar diffusion welding technique, Mokume Gane.
Actually brass and steel bond easily. (see brazing) No idea what the purpose of that might have been but it'd be easy to make, very easy, easier than a mokume gane billet.
Yes, it's a "Machinist's Tool".
It's a laminated block, used in conjunction with a Magnetic Chuck, ... most likely on a Surface Grinder.
The brass laminations create a separate magnetic field in each steel lamination, ... causing the block to hold onto a Magnetic Chuck much more securely than a solid steel block of the same size.
Depends on how old you are, and if you ever get into bonified machine shop work. Put it on a shelf and admire it, for it is a nice piece of technology.
Hmmm..... I have a mag chuck......
On second thought, I think it's poisonous - perhaps you might send it to me for proper disposal :rolleyes:.
Robert Taylor
