Cold weather smithing
So I was able to get the forge and all the stuff finished but it looks like my timing is out of whack...
At the end of October temperatures are barely reaching the low teens (in Celcius) as a high and nights are getting close to freezing...
At what temperature is it reasonable to still try and do some work.  I would like to try the forge at least once or twice before the snow flies.
Anything I need to keep in mind?
I could keep the anvil in the heated shop but the forge would be almost 10' from the door as I have a wooden deck in front of the door to the shop and I don't think having a forge on a wooden deck is a great idea...
I forge even into the single digits; granted, I am not out there for too long, and often build a campfire on the ground nearby to keep the ambient temp warmer. I forge outside, too. What's your situation? Do you have a shed or shelter? What is the minimum that YOU are willing to work with?
The criteria for forging in cold weather are:
1. Can you keep yourself warm enough to prevent hypothermia?
2. Can you keep the metal hot enough to forge?
Number 1 is a function of how much insulating clothing you need to wear (cotton and wool only!) to keep warm without impairing your ability to move around. Heavy gloves will keep your hands warm, but may interfere with your dexterity. Strong winds will chill you faster, but most windproof clothing is not fire-resistant.
Number 2 is a function of three factors: colder temperatures will require (a) more fuel to bring the metal to forging temperature, (b) cause more heat loss to the ambient air, and (c) chill the anvil, causing it to act as even more of a heat sink than usual.
So, in my experience working in a garage with the door open to a northern Ohio winter, if you're able to keep your core warm enough that your hands don't stiffen up and you're okay with shorter forging times and longer heating times, you should be okay. Even well below freezing, I've been able to do just fine with no more than an extra sweater and a wool watch cap. Just don't plan to do any water quenching when your slack tub is a solid block of ice.
One other note: unless you're working with an induction forge, make sure you have good ventilation! The temptation will be to close up the shop against the wind, but you dramatically increase the risk of CO poisoning.
What type of forge?  (Coal, propane, oil, charcoal, ...?)  I think that for most forges having a sheet of plywood on the deck should protect it sufficiently particularly if you've given it a borax wash.  Plywood walls can also help with wind issues.  I would leave it open on top for ventilation reasons.
When forging in snow I like to stand on a piece of plywood as it keeps my feet warmer.  Preheating the anvil is a must (as well as hammer's tongs, tooling).  If you are working high carbon materials beware of things "contact quenching"---placing a hot blade in a cold postvise can shatter the blade! and watch out for items flying though the air for a snowbank quench/shatter.
Capt'n Atli uses an electric iron to preheat his anvil.  Sets it on top when he enters his shop and by the time the fire and tools are ready the anvil is warm to the touch.
I have just rebuilt a coal forge 24"x24".  I have a few bags of charcoal to use to try out.  I'm not going to use up my limited supply of real coal yet just to try a few tings out.  My shop is a woodworking shop with just 2 large man doors and no overhead door.  It is full with no ability to have a forge inside.  The forge would need to be outside but again, there is a wood deck just infront of the doors....
I like the idea of using an iron to warm the anvil and hammers.  If I get a calm day with some decent temp and no major wind I might move the anvil outside and go to it...
If not then I guess I need to wait for spring...
22 minutes ago, ThomasPowers said:
I built a 1 soft firebrick forge powered by a plain old plumber's propane torch and used to forge in my basement during the Ohio winters
Not to hijack but I have to ask out of curiosity sake. If you were welding small stock in a single brick forge would you suggest a 2300F or a 2800F brick? I thought about making a small two brick forge for smaller projects that would be too wasteful in my gas forge or when I can't burn solid fuel.
Yes; (what do you have to hand?  How often will it be used for welding?...2800 should last longer but is the extra worth the price increment?  Is there a difference in fuel use due to insulative qualities, ?  I never forge welded in mine as my projects were nail making, small blades and a lot of silver forging so I was trying to keep the temp under the melting point of fine silver for the most part.)
remember now that our forefather Blacksmiths made their living by Forging year around regardless of the weather or Temps.  I'm sure in your section of the world there were blacksmiths 100-125 yrs ago and the temps were worse so we are told.  Are we getting soft?  I am!
Shelter is good, ventilation is a MUST. I light the barrel stove a while before going out and lay a piece of 2" x 8" x 8" plate on it and come back in half an hour or so. In the mean time I plug the two magnetic engine heaters in and stick them to the propane tank. When I come back I lay the now hot piece of plate on the anvil to warm it up. I return it to the stove when I start forging and keep it there in case I want to weld.
One of the guys here who is a full time smith heats a piece of plate to weld on if he needs to weld in the cold and the trick works a treat.
Since the accident I rarely do any smithing below the 10s what kind of hobby would that be? Even IF my old shop forge isn't baffled and it's screaming hot within 10' or so when it's hot the thing doesn't shine on my feet.
Frosty the Lucky.
Frosty the Lucky.
Good info....
The accident?  Cold intolerance?
Jerry went mono y mono with a black birch. The birch cracked his egg, after an extended stay in the hospital and some rehab, Jerry fed the birch to the barrel stove...
I would think a new shop might be in order. I say that as the temptation to build a lean to is great but a shop fire with a bunch of wood working tools at risk is a nightmare. It is surprising tho how confortable a patio on the leaward side of a building can be when your properly dressed, especially if you build a runford style fireplace out of an old drum to warm you up.
Remember that bottom forges aren't exactly charcoal friendly, it takes a very different fire management to work right. Typicaly a ring or a few fire bricks to add 2-4 inches depth, and crank the blower real slow!
I realize some folks heat a slab of steel to place on the anvil to pre-heat it prior to forging on very cold days.  I never have felt a need to do that, but in case I ever decided to, how hot can the plate be before one might ruin the temper on an anvil?  Mine is a 170# Hay Budden.  I realize forging with something fresh out of the forge is in contact with the anvil for only a short time compared to just laying a plate on it a leaving it there.
3 hours ago, ThomasPowers said:
Well the anvil can get over 300 degF. I've used a glowing piece of steel and managed to get the face to where it felt warm to the touch
I guess that I'd be safe doing that, then.
I just had it in my mindset that a slab of red-hot steel would/could remove the temper somewhat if left for any length of time, if for only 1/8" to 1/4", thereby softening the face a little.  Maybe the overall mass and lower temp of the anvil body would prevent removing any near-surface temper.
Don't get carried away, the plate I have is heavy enough I don't need to get it very hot and it'll warm the anvil up nicely. It's also large enough I'd have to put it in the barrel stove for a couple hours to get it to red heat. I'd break out the weed burner before then.
If I only had say 40lbs of 3/4" plate then maybe it'd need to be red hot to warm 125lbs to reasonably warm. Still, if a person isn't sure a quick swipe or to with a tempil stick will let you know before the anvil gets hot enough to draw the temper.
I wouldn't have any problem putting a mobile forge on the wooden deck in front of the door, and the anvil just inside.
There is zero fire hazard to having a forge on your wooden deck.  Even if you drop a hot coal on the wood, there isn't enough heat in the coal to set the wood on fire.  Mass, surface area, ambient temperature, wind.... it all plays a part and there's no chance that a conflagration will ensue.
Folks use barbecue grills on their wood decks all the time and it's not a problem.
And, don't forget that you'll be right there to stomp on any coals that fall.
The worst that could happen is that you put a little burn mark on the wood.... but what are the odds of that when it's so cold out?
With the anvil inside, out of the wind, you can forge a goodly bit because you're only two steps away from the forge.
Location, Location, Location; I once started a fire in the woodstove lighting a 6" diameter log with a single kitchen match (6% humidity); back in Ohio I'd need a pile of kindling to do the same. Folks tend to give advice based on *their* location and hope that the reader can make the modifications appropriate to theirs.
And of course we know you're not implying it's safe to use a turkey fryer on your pouch anywhere. We are right aren't we? When I was Boy Scout age it was no bid deal to light a one match fire, you could use a paper match even and no kindling. It's a dessert thing.
