Everything Mac Posted October 10, 2016 Share Posted October 10, 2016 So I figured I'd write a decent buyers guide for buying anvils. Repost with photos First of all I want to make it very clear that if you’re just starting out in blacksmithing you DO NOT NEED a “London Pattern anvil” to start hitting hot metal on. London pattern anvils are usually very expensive (your location in the world makes a big difference) not to mention relatively rare and hard to find. All too often I see posts on forums or Facebook where a new smith has spent all of their spare cash because they “HAD” to have an anvil. A large sledge hammer head, a section of rail track mounted vertically (more mass under the hammer) or any large chunk of scrap steel will make a perfectly serviceable anvil. Some are even better than a “real” anvil for one reason or another. Also I’d like to make it very clear that this guide is aimed at newcomers to the craft and not seasoned smiths. Also I’d like to note I’ve copied these images from the internet. All rights go to their respective owners. If you have an anvil that looks similar to the ones I’ve shown then please post them here so that we can use images from forum members. If anyone has issue with me using their image please let me know so I can take it down. So this is the anatomy of an anvil: Firstly lets look at a “Perfect” Anvil. This is a brand new Refflinghaus anvil pictured on blksmth.com - The face is perfectly flat. The edges are straight and crisp. There’s nothing broken or missing. This is arguably the daddy of all anvils. A wonderful tool. If I could afford it I’d buy one. But the reality is I can’t. Chances are that the anvil you are going to look at is very unlikely to look like the above. If it does you are either a) incredibly lucky or spending a great deal of money. Which is absolutely fine either way. So you’ve saved up a wad of cash and have found an anvil within reasonable collecting distance. What do you need to know and what should you be looking for? When going to view an anvil you need to bring a testing kit with you. You will need: A hammer A 1” ball bearing A ruler. (preferably metal) A scraper if the anvil is covered in paint. More on all that later. RULE NUMBER ONE: ALWAYS TAKE CASH WITH YOU AND BRING MORE THAN THE COST OF THE ANVIL!!!! Step 1: Figure out what it’s made of. The first thing for me would be to work out what it is made from. Generally speaking it really doesn’t matter at all. The only real thing you need to discern is whether or not it is made of cast iron. (the bad kind) Just for your knowledge though: There are several materials anvils can be made from - in no particular order. Wrought iron body with welded steel face. The oldest construction method of the bunch. These anvils have a forged wrought iron body with a steel face welded to the top. There are numerous British and American makers that used this method and it makes a superb anvil. The fact that so many survive today is a testament to the quality of their construction methods. - Older anvils had the face plate made up of several different pieces of steel, as steel was harder to make in large sections. Notable makers include Mousehole Forge, Peter Wright, Hill, Isaac Nash, Henry Wright, Wilkinsons and many others. All forged anvils have identifying features that give away their construction. The most obvious is the presence of handling holes at the waste of the anvil and often a handling hole under the base of the anvil. This is where large tongs gripped the body while it was forged. Another indication of forged construction is having a stamped makers mark, depressed into the steel rather than raised out of it. Forged wrought iron anvils have two very common “faults” - “delamination” and “sway”. More on these later. I’ve inserted an image of a forged anvil. This is a Peter Wright. Notice the handling holes at the waste and under the base. Also note the extra handling hole in the feet, this is characteristic of Peter and Henry Wright anvils. You can also make out the stamp in the picture. Another thing to note here is that I often see beginners try to identify anvils for one another on Facebook with some very strong opinions on what the anvil “DEFINITELY” is. If you are trying to identify an anvil with no clear markings I would suggest asking the forum or PM me directly. There are too many armchair experts out there who quite frankly have absolutely no clue what they are talking about. Case and point is that there were literally HUNDREDS of forges making anvils in Britain. Below is a forged English anvil. NOT ALL ENGLISH ANVILS ARE THE “MOUSEHOLE” BRAND. - A great many makers made anvils with the same features as Mousehole Forge. The above anvil shares all the features of a Mousehole but I don’t see a makers name. As such it is likely not made by Mousehole. http://www.blacksmithsonline.com/uploads/emoticons/wink.png [/url] Cast Steel - with technological advances and cheaper steel makers were able to cast entire anvils. Depending on the maker these can be hard to identify but will typically lack handling holes of any kind. - The biggest giveaway to a cast anvil is raised lettering on the body. Below is an image of a Brooks anvil. Note the parting line running centrally up the anvil and the raised lettering on the side. Cast anvils are generally less prone to sway, but it can happen. The issue many cast steel anvils have is chipped edges. More on this later. Cast iron with welded steel face: (Henceforth called CISF) - There are several makers that constructed anvils in this way. Fisher, Badger, Star and Vulcan are the ones I know of though there may be a few more. These have a cast iron body with a steel face welded to it. Don’t ask me how they did it, as far as I know no one knows exactly how they did it. Either way it produces a perfectly good anvil. Though beware, Vulcan anvils are generally considered poorer quality as they had very thin face plates that were very likely to chip in use. Fisher face plates were quite hard I believe and are also prone to chipping. - It is worth noting that this method of construction produced an anvil which doesn’t “ring” and as such are relatively quiet. If the smith has concerns with noise, an anvil made this way would be a good investment. Below is an image of a Fisher anvil. Notice the raised numbers and makers mark indicating a cast anvil. If you are faced with an obviously cast anvil but do not recognise the makers mark, posting it to a Facebook group via your phone (assuming you have a smartphone) will often lead to a quick identification. HOWEVER google that maker yourself just to clarify it. Cast ductile iron - the last of the decent anvil construction materials. Ductile iron is similar to cast iron but much much stronger. IT makes for a relatively soft anvil but is vastly superior to cast iron. I believe only a few modern makers use ductile iron - they are made specifically for farriers. Below is an O’Dwyer farriers anvil. Identification of these should be rather easy. Cast iron: - Finally the worst of all the materials. Cast iron is brittle, weak and frankly an awful material to make an anvil from. These will dent and chip in use and should really only be considered if you honestly have no access to a large sledge hammer head or chunk of scrap steel. The money spent on a new cast iron anvil should easily cover the cost of a cheap hardware store sledge hammer which will serve you far better in the long run. Cast iron anvils come in several shapes and forms. They are very easy to spot once you know what you're looking at. The proportions of the anvil will be wrong. The horn will likely be either very short and stubby or flat. Or both. The overall shape often looks wrong and they will typically be very small in size. Less than 20lbs in most cases. Pictured are all cast iron junk anvils. Note that some cast iron anvils are marked USA. Which does not mean it is good quality. Step 2. Start checking the anvil over. Visual inspection. Now assuming you’ve given the anvil a once over you’ve probably figured out what it is made from and you may have seen a makers mark. But try not to get too excited and hand over the cash. Now is the time to really check the anvil over. This is where you need to start your visual inspection of the anvil. How does it look? Does it look in good overall condition or is it chipped or swayed? Are there parts broken off? Ideally the anvil should be in as good condition as possible. But it is still a perfectly serviceable tool even with some significant damage. Sway: This is the name given to an anvil face that has become concave through use. This could be a combination of poor quality materials used to make the anvil. (wrought iron is rather soft) Or simply the scars left from years of heavy use. *It is interesting to note that Peter Wright anvils were made from high quality wrought iron, compared to other companies that used “Best Scrap” which inevitably had bits of steel in there too. As such the “Best Scrap” anvils were often a little tougher than the Peter Wright anvils. As such the early PW anvils would sway relatively easily; PW started making their faces very slightly concave to combat this. Sway in an anvil is not a problem, indeed some smiths prefer it. Excessive sway however should really be avoided if at all possible. Ideally is there is any sway it should be less than 1/8” over the length of the anvil face. Use your ruler to check for this. This anvil has some sway, Personally this is the most I could work with but some folks are perfectly happy with more sway. The anvil is in otherwise perfectly good condition and well worth having. This anvil however has excessive sway. The face has dipped significantly and even the heel has been bent. (I should really point out that I am spoiled for choice for anvils in the UK and there are enough available within driving distance that I can afford to be fussy. - personally I would pass on this anvil and keep looking. BUT if you’ve spent several years looking and this is all you’ve found then it is still a workable tool. Nothing has been broken off and the central part of the face appears to be relatively flat. The face plate also appears to be intact. Buy it if it’s cheap. Pass if not.) Chipping and edges: All anvils can chip, cast steel and CISF anvils are particularly prone to it. As such there is a good chance the anvil you go to see will be at least slightly chipped somewhere. Whether or not this is an issue on the anvil varies dramatically. In short the less chips out of the edges of the anvil the better. BUT a chipped anvil face does not make it a bad anvil at all. Quite the contrary. Chips should be ground smooth and radiused with a flap disc on an angle grinder. This gives the smith some very useful surfaces to work on when forging. As with sway, a little chipping is not a problem at all. Almost all of the anvils I’ve owned have been at least a little chipped. Excessive chipping however should be avoided. This anvil below has chipped edges. In my opinion this is not excessive chipping and with some work with an angle grinder and a flap disc this is a perfectly usable anvil. Notice how the chips are limited to the outer edges of the face and do not extend into the face itself. Excess chipping would be where the chips extend deep into the face of the anvil itself or deep into the body of the anvil; so much so that grinding it back would require removing a significant amount of the anvil. Common sense should prevail here. Sharp edges: New smiths seem to be fascinated by the idea that anvils need to be perfectly flat and have perfect 90 degree edges. This is not the case. AT ALL. You really do not need sharp edges for 99% of forging processes. If a sharper edge is required then a hardy tool can be made for this job. Delaminating/ Delamination: This is only an issue for anvils where a separate face plate has been welded on. Nine times out of ten the weld was perfect, but you need to remember these were made by humans and some times mistakes did occur. Delamination is where the weld between the body and the face of the anvil has begun to fail. This can occur on just part of the face or across its entirety. Above is a perfect example of where a face plate has completely delaminated and broken off of the body of the anvil. Of course this does not always happen like this. Some times the delaminated area of the plate remains attached to the face plate but is detached from the anvil body. This is why it is important to check the entire face for ring and rebound. A delaminated plate will sound different; dead if you will, compared to the rest of the face. More on that below. Again common sense prevails. If 90% of the face plate is missing I would walk away. If a small portion at one corner has broken off and the rest appears to be ok, and the anvil is in otherwise good condition then you could still buy it. Welding an anvil: DO NOT EVEN CONSIDER THIS IF YOU ARE NOT A HIGHLY COMPETENT WELDER. If in doubt don’t buy the anvil and walk away. Anvils can be repaired by competent welders. It IS doable. BUT only if you do it properly. The vast majority of Facebook armchair smiths I’ve seen have offered WRONG advice on this matter. As a general rule I almost always suggest that people do not weld their anvils as 99% of cases do not really require it. However there are times when an anvil would benefit from a good quality repair. An anvil with a small piece of the plate missing is a good example. The anvil above has a significant amount of the face missing but it seems to be in good condition apart from that. Depending on the sale price it could be a good candidate for repair. Just do your research. The Robb Gunther method is generally regarded as a good way to repair an anvil. Step 3. Testing: Assuming your anvil passes a visual inspection and has no obvious flaws then it is time to test it. Ring and Rebound: These are the most well known tests for any prospective anvil buyer. Be aware that paint or rust on the face will dramatically effect the results so you should clean at least a portion of the face if you can. (with current owners permission obviously) Ring: Take your hammer and gently strike the face of the anvil. If the anvil is forged wrought iron or cast steel it will ring like a bell. The pitch of the ring can also help indicate what the anvil is made from. A wrought iron anvil in my experience usually has a high pitched ring like a bell, with almost a musical note to it. This is usually not a prolonged note. In my experience cast steel anvils have a very high pitched ring that can be very piercing and almost unpleasant to the ears. The ring can also be quite prolonged and drawn out. Cast iron anvils with a steel face will produce a note when struck but will not sound like a bell. The note shouldn’t reverberate or be prolonged at all. Cheap cast iron anvils should sound dead under the hammer. I can’t honestly say what they sound like as I have never been in the situation where I’m looking to buy one. Strike all over the face, horn, heel and body of the anvil. Even the feet. At this point it is worth noting that the horn and the heel of an anvil WILL sound different to the body. Higher pitched usually. This is because there is less metal in these areas so the note is different. When striking the face it should all sound the same. If you are striking and suddenly the face sounds wildly different in one area it could indicate a crack or delamination. Be sure to visually inspect this area closely and be sure to test it with the rebound test. Also check to see if your hammer blows have left dents. Dents left by light blows are a good indication that the face is soft. I’ve used an anvil with a soft face and it worked perfectly well, just keep it in mind and use it as a negotiation point if needs be. NB - ring is only an indication. It is not a rule set in stone. My first anvil barely had any ring to it at all but it was a perfectly good anvil. Rebound: To me this is the more important of the two tests. If you’re on the hunt for an anvil the I’d keep that 1” ball bearing in your car on the off chance you come across something. “Rebound” is the name given to the amount of energy an anvil reflects back at the user. But it can give a good indication of face plate problems. Take your 1” ball bearing (Larger or smaller it doesn’t really matter.) and your ruler. Now hold the ball at 10” above the anvil face and drop it. It’s best to do this so you can see how high it bounces. 10” is ideal as it’s very easy to do the math for it. A “good” anvil should have more than 70-75% rebound. So the ball should bounce a minimum of 7” high. Many anvils will produce rebound higher than this but anything drastically less should be approached with caution. This is where cleaning the anvil face makes a big difference. Paint and thick layers of rust WILL drastically reduce rebound, so clean the face if you can. Like the ring test, you should check rebound all over the face. The heel will have less rebound than the face, just like the ring there is less material there so it behaves differently. The rebound should be the same across the whole face. An areas where it suddenly rebounds a lot less may indicate a crack or delamination. If this occurs during the testing then have another good look at the anvil. (Common sense) It may be that there is a significant crack you missed initially so proceed accordingly. As frustrating and disappointing as it it. (Trust me, I know) You are better off in the long run to save your cash and walk away from an anvil that is too damaged to be usable. Step 4. HAGGLE!!!! So you’ve looked over the anvil and everything is in order. There’s a couple small flaws, a little sway or maybe a chipped edge. Use that to your advantage. Start to umm and ar about the price. Make a cheeky low ball offer. You never know you might get lucky. If for arguments sake your seller wants $400, why not offer $250 or less! They might know what they have is valuable but they might not. You might get laughed at but on the other hand they might either accept the offer or come back with a slightly reduced figure. Ultimately you’ve saved yourself some cash. Remember rule number one? Always bring cash and bring more than you need if you can afford to. Money talks. Your seller might start to budge on price if he sees some nice crisp notes being counted out infant of him. A trick I’ve heard of people use is to count out the sum they want to pay in front of the seller. Some guys crack at this. The other trick to try is to ask if they have any other blacksmithing stuff. You might stumble on a gold mine of equipment. If that is the case and you can afford it (and there are things you want) then you should try and get some other stuff as part of the deal. So I hope this has helped some of you out there. If you have any questions don’t hesitate to ask. PM me directly if needs be. All the best Andy Quote Link to comment Share on other sites More sharing options...
Glenn Posted October 10, 2016 Share Posted October 10, 2016 Thank You Andy !! Quote Link to comment Share on other sites More sharing options...
Black Frog Posted October 10, 2016 Share Posted October 10, 2016 ...my Fisher picture. :-) Quote Link to comment Share on other sites More sharing options...
Frosty Posted October 10, 2016 Share Posted October 10, 2016 Good piece Andy, well done. Josh can tell you how steel face plates are welded to the cast iron body. I can too but Josh can describe it exactly and show you the patterns used ramming up the molds. I still say a 1" bearing ball is excessive, I can carry a 1/2" ball in my pocket all the time and not notice it unless I'm fishing for a key or change. But that's not an issue. Good description of how rebound testing is done. This'll help a lot of folk, good on ya. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Everything Mac Posted October 10, 2016 Author Share Posted October 10, 2016 47 minutes ago, Black Frog said: ...my Fisher picture. :-) Hope you don't mind chap. It's a perfect example. And thank you all gentlemen. All the best Andy Quote Link to comment Share on other sites More sharing options...
Daswulf Posted October 10, 2016 Share Posted October 10, 2016 Great write up Andy. Well done. Quote Link to comment Share on other sites More sharing options...
Jim Coke Posted October 10, 2016 Share Posted October 10, 2016 Just a note... . If you pull up to the sellers house and see a. White pickup with a license number. BKFROG. ITS ALREADY SOLD Quote Link to comment Share on other sites More sharing options...
JHCC Posted October 10, 2016 Share Posted October 10, 2016 Great article, Andy. 1 hour ago, Jim Coke said: Just a note... . If you pull up to the sellers house and see a. White pickup with a license number. BKFROG. ITS ALREADY SOLD Is this the voice of experience? Quote Link to comment Share on other sites More sharing options...
Jim Coke Posted October 10, 2016 Share Posted October 10, 2016 Nope... He is the best at rooting them out of the weeds.. a true anvil magnet. Quote Link to comment Share on other sites More sharing options...
Black Frog Posted October 10, 2016 Share Posted October 10, 2016 Ha!! ....the harder I work, the luckier I get. :-) Quote Link to comment Share on other sites More sharing options...
draavi Posted October 10, 2016 Share Posted October 10, 2016 Thank you. I currently use a good old hunk o' steel. But, as someone who is still on the hunt for an "anvil", this helps! Quote Link to comment Share on other sites More sharing options...
Everything Mac Posted October 16, 2016 Author Share Posted October 16, 2016 We need to take a deeper look at "Sway" - occurring on wrought iron anvils with a steel face plate. Let's imagine for a moment that we aren't talking about metal anvils but we are intact looking at something made of entirely different materials. - please bear with me on this. Let's pretend for a moment that the body of your anvil is made from fudge. Yes. Fudge. That brown sweet stuff I would love nothing more than to sit and eat half a pound of. (For our analogy Nougat would work equally well.) Fudge is reasonably hard compared to many sweets. You'd have to press pretty hard on it before it starts to deform right? But in the grand scheme of things fudge is not that hard, so if you want to forge sweetie goodness you're going to need something a bit harder to go on top of the fudge to protect it. In steps Toffee. Now toffee can be really hard. Especially if it's just come out the fridge. But if you sit it on the side for a while it warms up a bit and becomes a bit softer, it will bend rather than crack but it is still significantly harder than fudge. Would you agree? Toffee would be ideal, something like jolly ranchers hard candy would be too hard and would just shatter if you hit them. So we've made our anvil with the fudge body and the toffee face and we can now forge out some nice sweeties. But the problem with these materials is that they are not immovable objects. By their very nature they have a certain amount of ductility in them. Fudge is significantly more ductile than good quality toffee but toffee will still bend rather than shatter (if it's not too cold.) Having a toffee plate that is particularly hard would increase the risk of the edges chipping. 20 years worth of pounding out sweets will inevitably take it's toll on our anvil. That toffee will eventually start to deform and press into the fudge beneath it; and so you have an anvil that has developed a swayed face. Now obviously the fudge represents wrought iron, which is significantly softer than the steel face represented by the toffee. The steel face on an anvil has not been hardened so much that it is brittle and simply cracks. It can quite easily deform if used heavily for a significant number of years. Struck by a team of workers with sledge hammers for example, as was often done when these anvils were made. It is incorrect to assume that because the anvil has swayed that the face must therefore be soft and milling it flat would be relatively easy. Now as I've mentioned the steel is not "Jolly Rancher hard candy" hard, but "Toffee" hard. Still hard but retains it's ductility rather than being so hard it will shatter. A carbide bit will do it but that doesn't mean you should. Milling a swayed anvil flat can remove a significant portion of the steel face plate from the anvil. - Typically a face plate is about 1/2" an inch thick, more or less. One would like to hope that the heat treatment of the anvil hardened the entirety of the 1/2" thickness but I have heard of cases where this has not happened and a smith has removed almost all of the hard material from the face plate leaving soft steel underneath. Effectively ruining the anvil completely. Now with that said I must mention that I personally have had an anvil skimmed. As with welding an anvil face it CAN be done. BUT, and it's a big but, you run the risk of ruining the anvil completely. I had a 262lb Peter Wright anvil that I had owned and used without issue for a year as suggested by folks on here. The face had a few pit marks where it had been left outside for goodness knows how long and these pits effected the look of some of my work. 99% of the time it was ok but some times the pits were making it difficult to finish the work as I wanted. Now as I mentioned above PW anvils has a radiused face to combat sway. It so happened that the pits did not go deeper than this radius on the face and so I figured I would likely be able to get away with having it skimmed flat. I had the job done by a smith that had the equipment to do it. It was not milled but skimmed with a surface grinder with a belt finisher attachment. (There's a video on youtube as it happens of my anvil being done) As it happened I got away with it and the material underneath was as hard as the original face. I got LUCKY! Very lucky. I do not recommend this course of action 99% of the time. You are normally far better off just learning to use the anvil as it is. Use the anvil for a year and see what you think after that. If however the anvil in question is heavily swayed I'd suggest keeping it as it is. All the best Andy Quote Link to comment Share on other sites More sharing options...
Everything Mac Posted October 18, 2016 Author Share Posted October 18, 2016 test Quote Link to comment Share on other sites More sharing options...
njanvilman Posted October 18, 2016 Share Posted October 18, 2016 On 10/10/2016 at 7:25 AM, Jim Coke said: Just a note... . If you pull up to the sellers house and see a. White pickup with a license number. BKFROG. ITS ALREADY SOLD Or if in New Jersey, ANVILS. Quote Link to comment Share on other sites More sharing options...
Tubalcain2 Posted November 3, 2016 Share Posted November 3, 2016 very good summary. you did forget to say that soderfors are the best anvils in the world, but i'll have to cut u a break there. Quote Link to comment Share on other sites More sharing options...
264booking@gmail.com Posted November 4, 2016 Share Posted November 4, 2016 AWESOME post Quote Link to comment Share on other sites More sharing options...
Gorō Posted November 26, 2016 Share Posted November 26, 2016 Very HELPFUL! Quote Link to comment Share on other sites More sharing options...
Sargos Posted February 6, 2017 Share Posted February 6, 2017 Once again I am finding myself thrilled to find all the knowledge on this site. Quote Link to comment Share on other sites More sharing options...
JHCC Posted February 6, 2017 Share Posted February 6, 2017 46 minutes ago, Sargos said: Once again I am finding myself thrilled to find all the knowledge on this site. Apart from the stunning wrong-headedness of declaring Sodefors superior to Mouse Hole, I quite agree. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted February 6, 2017 Share Posted February 6, 2017 Now, Now, The Sodefors groupies are like Apple Computer Groupies; I picture them standing around their anvils in hipster garb... Mousehole, Peter Wright, Hey Budden, Trenton, Arm and Hammer are more like Microsoft users: mainstream users, using what's generally available. Fishers are like Linux users, more interested in getting the job done, less in the "RING" while doing it. (funny I haven't started the pain killers today---yet; after lunch things may get weird! Unpleasant medical testing in the late morning; though my Daughter the Veterinarian has offered me a large plastic cone to wear afterwards...) Quote Link to comment Share on other sites More sharing options...
JHCC Posted February 6, 2017 Share Posted February 6, 2017 4 hours ago, ThomasPowers said: The Sodefors groupies are like Apple Computer Groupies; I picture them standing around their anvils in hipster garb... Yeah, that's Frosty's profile picture to a T. Quote Link to comment Share on other sites More sharing options...
Tubalcain2 Posted February 6, 2017 Share Posted February 6, 2017 6 hours ago, JHCC said: Apart from the stunning wrong-headedness of declaring Sodefors superior to Mouse Hole, I quite agree. don't get me started..... Quote Link to comment Share on other sites More sharing options...
Craig Tallant Posted March 26, 2017 Share Posted March 26, 2017 Sooooo .. I have been rolling slow and steady getting into this new world of pounding metal and am ready to buy my anvil .. funds are limited and I found a " Colonial" style anvil on Old World Anvils for 135.00 .. it is 4140 tool steel 4x4 and has a stake ... I still have a hard time figuring out a fair price for a beginner anvil .. what is the opinion out there.. I was also thinking of cutting a slot into the center of a double shoulder tie plate to fit tightly around the base of the stake .. is this a good idea .. its about a 12 lb tie plate. Quote Link to comment Share on other sites More sharing options...
Frosty Posted March 26, 2017 Share Posted March 26, 2017 Unless you weld the stake to the tie plate it's not going to help other than to give you a steel plate to put stuff on and not light on fire. Drive the stake anvil into a wood block or good adobe hard pan and put it to work. You aren't going to know an improvement from a mistake till you have some hammer time. People around the world have been smithing on stake anvils for thousands of years and still do. Things like horns, heals, hardy and pritchell holes are specialty add ons developed in the last couple few hundred years. Oh they come in handy but for the most part you'll be using the face and edges. Down the road if the gods of fire and steel smile on you and grant you the opportunity to pick up a Soderfors anything jump on it if you can. Don't let yourself be sucked in by those jealousy ridden souls who think an antique technology is somehow competitive in any way other than weight and shape. Sure you can do outstanding work with ancient tech say a camp fire, blow pipe, smooth boulder and cobbles. But, why in the world would someone not needing counselling want to, other than on a lark or LARP? Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Craig Tallant Posted March 26, 2017 Share Posted March 26, 2017 Heard, I will take that info to heart. Looks like I have myself a Anvil then :). If I were to have the steel plate welded to the stake would it provide enough improvement to make it worth the trouble? Frosty, you are usually the first one to respond with helpful advice and not tell me to just use some clay in a bucket and use my forehead as a hammer like they did in the good ol days lol ... this has been a year and a half long project ( I move slowly with stuff like this lol) .. just wanna say I appreciate the help. Quote Link to comment Share on other sites More sharing options...
