New to metal work and need some help
So I've never used one of these forums  before or been good at writing, so       hopefully I do this right.  I've always     wanted to learn how to forge and cast metal. I've played around with casting   aluminum a little bit with minimal success. But loads of fun. But when I get back home from work I want to start learning to forge. I have a general idea on what I want to build for a gas forge but no real good ideas on what to use to make it work well and I have a RR tie I'm going to try and make into a anvil. If there's anyone out there that could share some tips, tricks, and advice on materials,tools, techniques, ect. All would be greatly appreciated.
Don't use a RR tie to make an anvil, the creosote is nasty stuff---use a  piece of rail if you can't find a nicer solid chunk of steel
The Complete Modern Blacksmith by Weygers has a whole chapter of turning a chunk of rail into an anvil and is one of the books I suggest for folks starting out.
Welcome aboard Jedediah, glad to have you.
Have we met? I live on Vine Rd. and silly buggers they are the Association of Alaskan Blacksmiths elected me president. Our next club meeting is in March, I'll have to ask the date my memory stinks. We're also hosting a 2 day Mark Aspery Joinery clinic June 11th. & 12th.
Meetings are open you only have to be a member to participate in club business. There is usually at least one demonstrator at meetings and several stations for folk to work at.
Clinics are pay to play of course and we're working out the fee for Mr. Aspery's clinic.
Near the bottom of the Iforge opening page is the regional organizations section The Alsakan Association sub section is near the top. I'll PM you with more direct contact info if you wish.
Sorry about that I meant the rail not the tie. And I know what book your talking about I picked it up about a month ago  it was what gave me the idea for using a rail
And frosty that would be great if I could get the dates I'll be back home for a bit in March so hopefully it'll work out so I could go and any other contact stuff I'm sure would be very useful and appreciated
Cool, it's a good time to hook up with the club it's going through a growth spurt. We went several years with the same guys and in the last year and a half it's more than doubled. You'll have lots of newcomers to the craft to work with, meeting demos are leaning towards basic skills sets and tool making. It's a GOOD time to join the gang and start the craft.
Where are you in the Valley? WE may be neighbors, if not there are guys scattered from Willow to Palmer and an occasional from Sutton.
Oh, one of our board members is a caster mostly bronze but he puts on the Art on Fire iron pour in June.
Welcome to the group! the next meeting is March 19th at Jims place in Anchorage. I am sure that coming from the valley there will be at least a car you can follow.
while casting is not a Blacksmithing skill we are lucky to have Pat in the group and he casts for a living. very good guy.
hope to see you at a meeting. if not March then the next one is May 14th at Pats in Palmer.
Bummer the 19th is 4 days longer then I'll be home for. But I'm out in the big lake area. And I think I met pat. He's the one with Artic Fire and bronze? I went in there to ask a few questions on casting.
I do have one question. What's the difference between soft and hard fire bricks I've looked them up and other then the obvious one is harder then the other I don't really understand the difference?  And are they even worth using for a forge? What's the pros and cons of using bricks?
Welcome Jedediah
The soft brick is much more fragile, better insulator, very light. Hard is much tougher, not as good of an insulator and heavy. Often hard brick is used for the forge floor for longevity and to soft elsewhere.
E. J. Bartells in Anchorage has both types, I don't know about sourcing in the valley.
There are a bunch of threads here about building propane forges with many pros and cons of the different materials, sizes shapes, etc. Kaowool is a good insulator and so long as it's kiln washed  properly it's reasonably robust. Soft or insulating fire brick suffers from thermal cycling and will heat check rather quickly. Hard brick lasts a lot longer but it has about the same R value as lime stone, approx R1 per foot. Not good.
I have split hard fire brick as the floor in my forge over insulating cast refractory and while it's okay I wouldn't do it again. I think I'd go kiln shelf over 2" of Kaowool for the floor.
Drop by I'll show you how my gasser is built and tell you all the things wrong with it.
What is a kiln wash I've seen people talking about it but I haven't been able to figure out what it actually is. And I'd love to be able to come by and check out your set up that would definitely help me understand all this stuff a lot better then reading and writing about it
Kiln washes are coatings for the inside of kilns and furnaces to protect them from aspects of the environment. Ceramic and pottery kilns have the widest range of washes I've seen, different clays, firing temperatures, glazes, pigments, etc. all have their own high energy chemistry.
Kiln washes for forges tend to be for 3 main uses. To protect against welding fluxes typically containing borax which is caustic at welding temperatures. Silica dissolves in caustics so flux eats most refractories. Another use is as an infra red reflector, the more heat you can keep IN the forge the less fuel you have to burn and the higher temperature you can maintain. Lastly (for the main uses) is as a stabilizer for ceramic blanket refractory. This stiffens it  so it becomes more structural often called a rigidizer. It also encapsulates the fibers so they don't end up i your lungs, silicosis is a B-A-D thing. And lastly as an IR reflector it not only helps keep heat IN the forge it helps shield the blanket from heat and mechanical wear.
Probably one of the best pieces of advice I have to offer is don't get in a rush and don't try to make the best or a perfect forge. The more you learn the more you'll realize why some of us old timers have so many old forges gathering dust.
