Solar Powered forge?
#1
Posted 03 January 2008 - 12:55 PM
Just found this, this guy melts glass in a few seconds using a big lens, could do that to get specific heats on steel too.
Sundrop Jewelry - Sterling Silver and Glass Solar Energy Jewelry
Merry Being,
Archie
#2
Posted 03 January 2008 - 04:22 PM
Altho it's a very good way to heat up small crucibles and melt nonferrous metals..for casting jewelry and other trinkets. . or experimenting with stuff. . .
One could build a furnace that receives concentrated light from an arrangement of mirrors. but that would require adjusting the mirrors very often.
#3
Posted 03 January 2008 - 08:13 PM
Solar furnace - Wikipedia, the free encyclopedia
Mont Louis/Font Romeu-Odeillo-Via
thats 3000C or 5432 degrees Fahrenheit, they use molten salts for heat storage and transport
one turns to the other and asks
"Does this taste funny to you?"
#4
Posted 03 January 2008 - 08:28 PM
#5
Posted 04 January 2008 - 01:52 PM
I thought about using one for a solar forge but then I was exposed to the high winds that are a regular occurance out here and decided that making such a structure windproof was beyond my interest level.
#6
Posted 05 January 2008 - 06:47 AM
agsolder said:
Yes ..It was Archimedes . .more of a well known scientist/inventor/mathematician . . . He made all sorts of contraptions to defend Carthage from the Romans in the Punic wars ...altho he was killed by Roman soldiers that were rampaging around after the city fell.
It is said he was killed because he would not follow the soldiers' orders because he hadn't finished his latest theorem.
#7
Posted 05 January 2008 - 03:34 PM
I was thinking it would be cool to try to set something up where the light would be focused into a firebrick forge... Too bad I live in Seattle where it -might- work 3 days a year. TX and AZ would have a better shot.
http://www.alchemyforge.net
#8
Posted 05 January 2008 - 03:44 PM
#9
Posted 05 January 2008 - 04:53 PM
My uncle told of using a magnifying glass to light cigarettes when he was out of matches..
I guess if you could multiply the effect by 100, or 1000 times, you might be on to something.
I suspect there might be some kind of physical limits on how mush heat can actually be generated this way.....but I'm no scientist and occasionally I am wrong( well......more than just occasionally).
If the idea really works, it could supply a lot of the world's energy needs.
Who knows.
#10
Posted 05 January 2008 - 05:19 PM
#11
Posted 05 January 2008 - 05:46 PM
Stirling Energy Systems Inc
Vid > http://www.stirlinge...pse_footage.wmv
Major CSP Projects
have a contract with Southern California Edison to install a 500 megawatt plant thats scheduled to open in 2009
#12
Posted 06 January 2008 - 01:31 PM
#13
Posted 06 January 2008 - 07:22 PM
For those of us who think that kaowool, IFB and fireclay is hard to find., that solar stuff is much worse. For larger applications, where convection is not so much of a problem, it might be OK. For example, solar might work well for a glass annealing kiln. About 900 F for a few hours.
#14
Posted 06 January 2008 - 08:40 PM
#15
Posted 06 January 2008 - 09:12 PM
theres alot of solar potential..
#16
Posted 07 January 2008 - 01:36 PM
If you know how many watts your heater must have and figure out the efficiency of your collector you can calculate how much you need.
I envisioned a heavily insulated (kaowool of course) forge "box" with a narrow slit to allow the focused power to track down the slit to make repositioning less frequent. If the watts go in it *will* get hot until the losses equals the input.
#17
Posted 12 February 2008 - 11:04 AM
A more elaborate setup would be to use mirrors. Most solar furnaces rely on some kind of parabolic mirror(s) to concentrate light. I do have an old satellite dish, but coating it with mirrors would be a lot of work and probably expense. With flat mirrors the concentration will be limited to the number of mirrors, but you can collect a lot more sunlight (area) than the lens. My idea is to use the light from several 4x8' arrays reflected (from below) onto the bottom of an oven (possibly with some concentration), which I hope would heat the iron more evenly and avoid having to look "into the light". Unless they are set up for sun tracking, the arrays will have to be adjusted fairly often, probably every 5 minutes or so for optimum temperature.
Anybody have any ideas what would make a good oven floor? Firebrick was my first thought, but it would reflect a lot of light. I need something that stays dark on the heated (absorbing) side while incandescing on the other - not asking for much, eh? Could a ceramic material have a flat black coating that would stay there at 3000+*?
Thanks and Good Luck!
#19
Posted 14 February 2008 - 01:24 AM
White Sands Missile Range
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
