Taitius Posted November 24, 2015 Share Posted November 24, 2015 So I have a little problem and I am kind of stymied... I bought a bundle of various sized 52100 round stock a few years ago at a blacksmithing event, can't remember the details at the moment. I just recently pulled it out and tested a small piece for a slipjoint knife build. I forged the shape, ground it to near the final thickness, normalized and hardened. Low and behold I barely get 50 HRC... Did it a second time and got virtually the same result---------so I see 3 possibilities: I got sold something that isn't 52100, my heat treat process was totally wrong, or I had massive decarb. I don't think decarb is really the issue because I ground away the surface steel and put a wash of satanite on before the hardening (the second round was done without the satanite just in case that had botched the quench, but results were the same). My heat treatment may have been a bit off, but I still wouldn't expect to get such low hardness. Here is the procedure I used: 2 normalizing cycles at about 1475, held for about 2-3 minutes then air cooled. Bring up to 1500 then hold for 10-15 minutes and quench in 125 degree cooking oil--------as quenched hardness was only 50 HRC. My temperature control should be pretty good, I use a thermocouple in my forge to monitor temp during heat treats. I also used a similar process to harden some W1 (with shorter soaking times) at the same time and I got a hardness of 65 HRC. So, any ideas what might be going wrong??? Link to comment Share on other sites More sharing options...
Bo T Posted November 26, 2015 Share Posted November 26, 2015 I have read of similar problems in the past. Heat it to 1550 F and quench, then test. If that doesn't do the trick, bump it up another 50 F and try again. Link to comment Share on other sites More sharing options...
Steve Sells Posted November 26, 2015 Share Posted November 26, 2015 I have no idea where you got your information a few minutes at 1475F does almost nothing. HEAT TREATMENT of 52100 Normalizing: Air cool from 1650-1700F Spheroidize Anneal: the following step down cycling is recommended 1500°F (815°C) for 3 hours, 1350°F (734°C) for 4 hours, 1250°F (675°C) for 3 hours then a slow cool to 1000°F (538°C) and then air cool. Maximum annealed hardness: 207 HBW Hardening Quench in oil from 1500-1550°F (816-842°C). Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted November 26, 2015 Share Posted November 26, 2015 Buy a piece of new 52100 from a store, and put it in with a sample of what you already have as a test sample. If it comes out right, and the material you have now doesn't you may not have 52100 in the knife. Follow Steve's advice above, and you should be good. Link to comment Share on other sites More sharing options...
78sharpshooter Posted November 30, 2015 Share Posted November 30, 2015 Try again with the stated specs and heat the cooking oil to 160 f Link to comment Share on other sites More sharing options...
Please sign in to comment
