NickOHH Posted November 8, 2015 Share Posted November 8, 2015 So I decided to try my hand at a quick touchmark. I wasn't sure if anyone was using an N which I'm sure is being or has been so I did a backwards one just to see how hard it would be to file in and if it would work. Quote Link to comment Share on other sites More sharing options...
Daswulf Posted November 9, 2015 Share Posted November 9, 2015 I have been thinking of making one myself. Nice work Nick. Quote Link to comment Share on other sites More sharing options...
rockstar.esq Posted November 9, 2015 Share Posted November 9, 2015 Try to get the letter cut with a square edge rather than sloped as you've got it. It takes less force to get them to leave a stronger impression. It doesn't take much depth either so you don't need to remove much from what you've got. A small chisel would likely do the trick. Quote Link to comment Share on other sites More sharing options...
NickOHH Posted November 10, 2015 Author Share Posted November 10, 2015 Thanks Das, gotta keep me posted if you try one. rockstar, thanks for the tip, it worked better than I thought but I will try cutting the edges a bit with a chisel a bit. Quote Link to comment Share on other sites More sharing options...
