Testing a forge weld, what to look for?
Today I tried a bit of forge welding too. Just a test and nothing complicated. I bend over the last bit of some flat bar, smashed it flat and then welded it . First cleaned it, then heated it up in my charcoal fire. I used a bit of borax, heated more till yellow heat and tested with a pointed end of another piece of steel if it was sticky. Heated a little more and smashed it on the anvil. Repeated for good measure and then tried to pry it apart in the vise.
Now I need a bit of help. Did this weld at all? What am I looking at? The nice gray areas, where they welded? Is it always possible to pry apart a forge weld?
nope they shouldnt come apart, how many times did you try to weld it, did you flux everytime? looks like it was to cold to me, but im not an expert on the subject, but thinner stock cools quicker so it might have been hot when you pulled it out, but not when you went to actualy hammer on it. just a guess though
Nick and Thomas seem to be saying the same thing.
Did you preheat your anvil? If you're welding thin stuff you can't rest it on the anvil face before you hit it. They have to happen simultaneously, and you have to pick the steel back up between strikes.
My first real goal is making some hinges for a couple of cabinets I want to make. So I really have to do more practice.
About all the tips posted above: No I didn't think of any of these. So, thanks for summing them up again.
Flux is not glue, in fact you do not need flux to forge weld. The folks from UK do not use flux and make nice forge welds.
Before you take the metal from the fire, do the dance so you KNOW where everything is and KNOW that everything is ready. You should be one step from the forge to the anvil. BUMP the two pieces of metal together on the anvil and put them back into the fire to reheat. Second time around BUMP the two pieces of metal, them lightly hit them with the hammer, and back into the fire to reheat just below the last temp. Third time out of the fire and onto the anvil and dress up the weld and blend the two pieces of stock to look line one.
A forge weld is the mixing of the liquid metal from the two pieces of stock. Does NOT take a lot of hammer blow to mix liquids. Think Ox/Ac welding. The photos where you see all the sparks coming off the anvil and going to the 4 corners of the shop is all Hollywood (and your forge weld being thrown to the four corners of the shop).
If all else fails, ask Mr. Lincoln, Mr. Hobart, or Mr. Miller for their blessing then put the metal into the fire and dress it up to hide the weld.
;) I like your thinking. I still try forge welding on oddball pieces and mangle it every time. Think I'll just try this for now myself till I get it down with normal pieces.
One thing that was hard for me at 1st was getting the piece hot enough to weld. I was just too afraid I'd burn the piece. The turning point was when I was told to leave it in until I just started to see sparks. Then I could get steel to weld no problem. Now I can read the steel better and tell when it's ready to weld, but I still use the spark trick when some one asks me to help them weld the 1st few times.
Hi Seek, find Mark Aspery on YouTube there is a video called "forge welding: scarfe-theory" have a try at the first weld he makes by folding the end of a piece of rod onto itself. 2 minutes into the video. that is a good starting point.
I disagree: a forge weld is a solid state weld no liquid needed. May I commend to your attention "Solid Phase Welding of Metals" Tylecote.
I know I confused things recently  using the term "dry"; and I apologize.
I meant to say that the surface of the metal was at or close to a liquid (or at least melting) state and only on the surface, not the entire bar. If I have this incorrect please correct me. Please provide what is actually happening to the surface(s) during the fire weld.
This was my understanding as well; hence the admonition not to hit too hard and squirt the liquefied surface metal out of the weld.
