lloe01 Posted July 26, 2015 Share Posted July 26, 2015 (edited) Does anyone have close-up pictures of their Mayer 25 lb hammer. Specifically, the ram and the arms.mine seems to have a lot of things welded where there should have been bolts.The welds look old.thankslarry Edited July 26, 2015 by lloe01 Quote Link to comment Share on other sites More sharing options...
Black Frog Posted July 27, 2015 Share Posted July 27, 2015 A lot of things look modified on that hammer. Yikes.If you Google, "Mayer power hammer" you'll find pics of original configurations. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted July 27, 2015 Share Posted July 27, 2015 As mayers and little giants are close you may want to contact the feller that bought the LG business off of Sid. Quote Link to comment Share on other sites More sharing options...
Black Frog Posted July 27, 2015 Share Posted July 27, 2015 Roger Rice is in charge of LG now, he only has limited parts for Mayers, most parts are not interchangeable with LG. Quote Link to comment Share on other sites More sharing options...
Metalsculptingben Posted July 28, 2015 Share Posted July 28, 2015 Roger Rice helped me loads on making my hammer run correctly. Quote Link to comment Share on other sites More sharing options...
Augus7us Posted July 29, 2015 Share Posted July 29, 2015 Hey lloe if you still need photos I'll snap some of my 25lber when I'm back in the shop. Let me know if you need photos of anything aside from the ram Quote Link to comment Share on other sites More sharing options...
lloe01 Posted July 29, 2015 Author Share Posted July 29, 2015 Augus7us,thanks! Pics of the arms would be great. Especially, the lower portions. I haven't found any closeup pics yet. Quote Link to comment Share on other sites More sharing options...
Augus7us Posted July 30, 2015 Share Posted July 30, 2015 Here you go brother, hope they help. Let me know if you need more Quote Link to comment Share on other sites More sharing options...
lloe01 Posted July 30, 2015 Author Share Posted July 30, 2015 That is perfect! Thanks! Quote Link to comment Share on other sites More sharing options...
lloe01 Posted August 6, 2015 Author Share Posted August 6, 2015 I've emailed several times 2-3 weeks ago and no reply yet from Roger.Guess I need to call. Larry Quote Link to comment Share on other sites More sharing options...
Metalsculptingben Posted August 7, 2015 Share Posted August 7, 2015 I found that it is best to call. Quote Link to comment Share on other sites More sharing options...
lloe01 Posted August 8, 2015 Author Share Posted August 8, 2015 From the little giant website it looks like I can replace everything hanging on the crankpin (arms, pins, spring, toggle links, etc...) with 25 lb LG parts. I sure hope so.Im concerned about running it the way is is.Larry Quote Link to comment Share on other sites More sharing options...
lloe01 Posted August 8, 2015 Author Share Posted August 8, 2015 Can anyone tell me what size the bolts are that connect the toggle arms to the cross head, toggle arms to the toggle links, and the ram to the toggle links? I searched and didn't find anything. Thanks! Quote Link to comment Share on other sites More sharing options...
Frosty Posted August 8, 2015 Share Posted August 8, 2015 I measured the ones on my 50# LG. when I replaced them.Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
lloe01 Posted August 8, 2015 Author Share Posted August 8, 2015 I measured the ones on my 50# LG. when I replaced them.Frosty The Lucky.Hi Frosty. Someone took to welding everything instead of using bolts. I'd rather have bolts for assurance. If you look at the top pictures, there aren't a lot of bolts. Plus, it looks like they turned the cross head upside down and used pins instead of bolts. This looks like it would introduce a bunch of slack where there shouldn't be any. So I really want bolts Quote Link to comment Share on other sites More sharing options...
Frosty Posted August 8, 2015 Share Posted August 8, 2015 Indeed they did but you're going to have to cut the welds to change things out anyway measure them then. I probably sounded pretty cavalier with my last suggestion, I didn't mean to come across like that but it's the only alternative I see being reliable. Even if you look up the Patent docs or had the as built drawings for this very hammer a lot of time and owners have gone through it. You can't count on anything being factory spec.I'd just take a grinder to the welded pin/bolt heads cut them loose and go from there. Heck there could be enough wear you'll need to shim them or fill and drill the holes.Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
lloe01 Posted August 8, 2015 Author Share Posted August 8, 2015 Indeed they did but you're going to have to cut the welds to change things out anyway measure them then. I probably sounded pretty cavalier with my last suggestion, I didn't mean to come across like that but it's the only alternative I see being reliable. Even if you look up the Patent docs or had the as built drawings for this very hammer a lot of time and owners have gone through it. You can't count on anything being factory spec.I'd just take a grinder to the welded pin/bolt heads cut them loose and go from there. Heck there could be enough wear you'll need to shim them or fill and drill the holes.Frosty The Lucky.Thanks, Frosty, I took it as you telling me how you did it.I'm really hoping to replace it all with LG parts (everything that is hanging off the crankpin, anyways). I think I will ask Roger when I do order.But, I will definitely listen to any advice from you Larry Quote Link to comment Share on other sites More sharing options...
Frosty Posted August 8, 2015 Share Posted August 8, 2015 But, I will definitely listen to any advice from you Larry I hope you keep a bucket of salt handy! Well, okay listening is okay just use your own judgement about taking advice. Yes? Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
lloe01 Posted August 8, 2015 Author Share Posted August 8, 2015 Hah! I sure will.Thanks. Quote Link to comment Share on other sites More sharing options...
Augus7us Posted August 8, 2015 Share Posted August 8, 2015 lloe01 please take photos as you restore her. Not a lot of documentation out there for Mayer's Bros hammers. Quote Link to comment Share on other sites More sharing options...
lloe01 Posted August 8, 2015 Author Share Posted August 8, 2015 lloe01 please take photos as you restore her. Not a lot of documentation out there for Mayer's Bros hammers.Great idea! Quote Link to comment Share on other sites More sharing options...
Frosty Posted August 9, 2015 Share Posted August 9, 2015 It's good to document what you did if for no other reason than for your own owner/repair manual. Keeping a notebook is a good thing and document how much you spend, money and time it's all part of the machine. There's no telling what little tid bit might save you hours of headache later down the line.Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
