Hot and heavy work
Had a little time to play today.  Cranked the forge up way hot and gave a few handled tools a try and a new hold down from an old coil spring.  Been thinking of making a turning wrench the way Mark Aspery does in his book.  Needed  a fullering tool for that so dug out a few bits of spring from the D-8's track tensioner springs. The piece in the chop saw will be a set hammer, if I remember right the material for it use to be a torque arm of one of the logging trucks.  Was a little bored the other afternoon so I whittled up a  set of mini tongs out of a small willow branch.  And from a week or two back brother in law was looing for a solution for his kebab skewers.  Beat out a set of duck bill tongs from some 1/2"sq stock.  One day soon will have to get out and visit so he can give them a try.
DSC02031.thumb.JPG.38c3eb111c7ca1fe366feDSC02032.thumb.JPG.7c9ea3584b9588413e391DSC02034.thumb.JPG.dad4929db1c26278f3d0fDSC02033.thumb.JPG.49373aee2ad175c3006e2DSC02027.thumb.JPG.4902246d0b83d5e906f3bDSC02028.thumb.JPG.0d733aee693235196d214DSC02029.thumb.JPG.ced27ef2aaa63dc6badfdDSC02014.thumb.JPG.5be4188e58698f4f98a67DSC02016.thumb.JPG.5103d80f5116c50f709f9
My goodness you WERE a busy boy weren't you. I love the willow tongs, I might have to move a rocker out on the porch. The duck bill tongs look handy too. All in all some darned nice tools, I'll have to hear what you say about how the the top tools and hold fast work.
The hold down has proven itself already,  used it to hold the top tools down while punching the holes.  Been a real treat to have wish I had found the right sized stock sooner.
I've seen a video of an old gentleman carving the pliers  may have even been posted on IFI.  The springs are scary strong.  quite the job cutting them down so I could extract them safely from the old track frame.
That's a gorgeous set of springs you have there!  I like the tools you're making from them, but the springs are sure pretty.  I guess you know you're a blacksmith when you're just as happy with a photo of some good "scrap" as you are from some nicely made tools....
In amongst other things today put proper handles on the tools.  Made a backing plate for the vice and a dog wrench the way Mark Aspery does, but used a strip of leaf spring for it.  The fuller tool has a little too small of a radius  so I will have to make another at some point down the road.  The handled hot cut was a real treat to trim the end off the spring stock before I started and cut to length at the end.  was cool enough out to air harden the loop an the end of the handle.  Needed one little tweak and it broke the curl off.  So back in the heat it went to be drawn out again.DSC02035.thumb.JPG.6d6e8e5c6b565431f7a8cDSC02037.thumb.JPG.3e9d419d82c2c96d22912DSC02039.thumb.JPG.d9e593c1ed2b642bbcb4cDSC02040.thumb.JPG.57378fddf7147cce580d8
With a decent fullering tool and the backing plate it goes surprisingly fast and easy.   The hardest part on mine that I found was trying to square up the corner of the fork tine.  Being spring stock hard to quench it enough that it doesn't deform when driving it down on the anvil to square the  bend up  without ending up so hard it's brittle.  Further compounded by being small stock on a cool day losing heat quick.
Had a short little end off a track pin from making my cut off hardy.  Turned it into a cupping tool for a rounding hammer face.  And finally finished up a set of hammer tongs that have been laying on the floor for who knows how long now.  they are way to light for what I want but at least they are something.  And a piece of the heavy spring,  its 2 1/4" in diameter so if my math is right a 2 3/4" long piece should give me 3 lbs.  Now I just need a helper to make a rounding hammer.
DSC02046.thumb.JPG.1c39435b0dd91303b7623DSC02047.thumb.JPG.3a905376be32de54cf779DSC02048.thumb.JPG.9dfc171aa78b528547ba3
I a going to need a striker soon.  Getting all these good bits of hammer stock laying around itching to do something with.  One of the trucks came in complaining that 3 out the 4 drives where turning when they where doing the push pull thing in the mud, D-8 cat on one end 545 Cat skidder on the other.  So now I have a nice piece of T800 Kenworth axle minus the splines  :)
DSC02049.thumb.JPG.65e0daa330f1fefa7a746DSC02050.thumb.JPG.11ed5710504463680cd3b
