my third knife
vaporlock
Hi All,
I forged my third knife last weekend. First time i used XC90.
Pretty happy with the forging result,
post-55290-0-65470700-1415979687_thumb.j
post-55290-0-74386100-1415979727_thumb.j
However , I think i made a mistake finishing the bevel before tempering . Somehow the bevel cracked .
Could also be insufficient heating before selective quenching
post-55290-0-39439400-1415979772_thumb.j
post-55290-0-38232100-1415979799_thumb.j
I imagine it could have been avoided if I would have tempered it straight after quenching. In which case I could have tempered at a lower temperature.
Any thoughts?
Vaporlock
I looked up this steel to see what it was made of.  Looks like 1095, just really high in manganese.   What did you quench it in?  Did you use a magnet to determine the proper quenching heat?
If you quenched in water, this will cause it to crack.  If you over heated before quenching, this too can cause cracking.  This doesn't account for any mistakes in the forging of the blade where cracking may have occurred (forging too cold).
Hi All,
Yeah, I think it was a case of overheating before quenching, possibly forging too cold. quenching (selective) was done in veg oil .
Thanks all for the comments, It gives me a few things to look at when trying to make the same without the crack :-)
Vaporlock
