Tempering Iron
Pure Iron is a specific material, and the nearest thing you will get to wrought iron, the UTS of Pure Iron is between 15 and 24 tons psi, The main difference beteen the two being that pure iron does not contain any slag or laminations and is purported to have superior corrosion resistance. It is also easily fire welded.
Made and supplied in the UK ( and exported world wide)
Samples were available and used at the International Blacksmiths Festival, and impressed many that tried them.
bad link removed
I have some 1005 steel in 3/8 round - it was leftover from a machining operation for electrical contacts.  Forges like "buddah" (that's butter for anyone who thinks I meant Buddha <LOL>).
It would be great if the low carbon stuff was generally available but it was special order and cost about as much as tool steel.
  • 3 weeks later...
