mnt Posted October 28, 2014 Share Posted October 28, 2014 Well, I finally got time to play around with my little forge and try out a couple of things. I recently finished up a press break to put bends in angle iron to make some furniture legs that I have had on my list for quite awhile. There may be a faster easier way to do this, but this is what was in my head. I had to do a little persuading at the second bend, as the metal flared outwards a bit, but I am relatively happy with it. I need to do a little more tweaking on the break, since the channel I used was not quite up to snuff for the 20 ton press. In fact, I need to do some tweaking on the press too, but that's what I get for using a Harbor Freight press. The rectangular tubing I just heated up and put in the press, I was hoping for a more uniform "bulge" more gradual, but I went a little too far. Also, one side bulged in and the other 3 sides went out. I will have to experiment with making sure they all go outwards. The last is a bottle opener from a 16 mm wrench. I had to push it a little out of round to make it work, since I made the circle a bit too big. All in all a good learning experience. Link to comment Share on other sites More sharing options...
Please sign in to comment
