DSW Posted September 14, 2014 Share Posted September 14, 2014 Reading the comments on the thread on post drill bits made me realize we don't have a thread dedicated to post drill picts ( well at least that I could find with a quick search this morning) So lets see what you all have. I'm still on an inactive hunt for one for myself. Link to comment Share on other sites More sharing options...
Vann Posted September 14, 2014 Share Posted September 14, 2014 My pre-1911 Silver Mfg Co. Advance No.14 How it looked in January thiis year, before dismantling for transport home. The first shipment of parts arrives home. How it looked in May - in grey primer. Cheers, Vann. Link to comment Share on other sites More sharing options...
Direwolf Posted September 14, 2014 Share Posted September 14, 2014 Here are a few pics, the first is a Champion, I got at a farm auction. It was mounted to a large heavy steel work table, converted to electric with a 3/4" Jacobs chuck. It has a lever/handle to manually feed the bit while drilling. It works great as I found it, it is set to run at approximately 100 rpm, small 2" pulley on the motor, large 14" pulley on the drill. I use a huge milling machine vise to hold the work piece. The second is a very large Boynton & Plummer meant to run off a line shaft. I bought it this summer at a farm auction for $10.00 it is so big that took three of us to load in my truck about 300LBS. If I hadn't bought it it would be gone to scrap, smashed up before it left the farm, there were several scrappers there. I will find a good home for it. It is a beautiful functional drill in mint shape, just takes up a lot of space. DSW if you lived closer to me I would be happy to set you up with a post drill. Vann, that is a beautiful drill! Silver made, IMO, probably the best drills. I have a large one I rescued off my neighbors stone fence for free just had to drag it to the truck. It sat there for 50 years in the sun and weather. It took a bit of time to free up but works perfect! Link to comment Share on other sites More sharing options...
Vann Posted September 14, 2014 Share Posted September 14, 2014 Vann, that is a beautiful drill! Silver made, IMO, probably the best drills. I have a large one I rescued off my neighbors stone fence for free just had to drag it to the truck. It sat there for 50 years in the sun and weather. It took a bit of time to free up but works perfect! Thanks Direwolf. I agree, Silver made great looking post drills. Here's a more recent photo (I couldn't find this last posting) Here I'm experimenting with colours on the flywheel (I don't like any so far !). This is almost all I've got at home so far, until I arrange for the third (and hopefully final) shipment. Cheers, Vann. Link to comment Share on other sites More sharing options...
Vann Posted September 14, 2014 Share Posted September 14, 2014 This is my Canadian Blower & Forge No.61 (almost identical to a Buffalo Forge). It's made from two wrecks (both CB&F No.61 post drills). The first was missing auto-feed lever & pawl, column, column foot, table. Three of the four flywheel spokes are cracked. The second was missing the crank arm & handle and the table. The frame was broken in half, the thrust bearings had mostly disintegrated, and the ball races were so badly worn they were unusable. Here's the first one partially dismantled. While the other was broken through the middle, this one had been as well, as this braze repair shows I found that the pawl on the auto feed lever had lost its ball (counter-weight) so the pawl doesn't engage. Here it is removed, awaiting repair. So, I still don't have a table, nor a working auto-feed. I have it mounted above a bench in my woodwork shop, where I occasionally use it to drive a Fortner bit. Cheers, Vann. Link to comment Share on other sites More sharing options...
Daniel S Posted September 15, 2014 Share Posted September 15, 2014 Mine is a Bailey's no 4 from the Illinois Iron and Bolt co. I was going to paint it, but I have too many other projects going on. I was wanting a smaller one, but none of the ones that I've found were complete. This one is 150 lbs. I just got this mounted today, so hopefully I can take it for a test drive this week. Link to comment Share on other sites More sharing options...
JTF Posted August 20, 2016 Share Posted August 20, 2016 some of mine , oh and my drill bit collection as well. i have another 612 buffalo in pieces, once i mount them all i will post photos of them completed, so many projects so little time. have found a Sears post drill for sale , i don't have a Sears { yet} Link to comment Share on other sites More sharing options...
aessinus Posted August 28, 2016 Share Posted August 28, 2016 Cole #7 (purported by a g-uncle to be a cordless gate pintle drill) with 1/2"Jacobs chuck Older one is only marked with v121 ; has the taper square drive for brace bits Link to comment Share on other sites More sharing options...
matto Posted August 29, 2016 Share Posted August 29, 2016 Canedy Otto new 16 canedy Otto 10.5 chamion nother smaller champion Buffalo 616 two aceme also have a couple more. Think there is another small champion and a silver MFG. on the wall also. Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted March 7, 2017 Share Posted March 7, 2017 Found this Champion while "junk shopping" it was laying out in the back grown over by weeds. It followed me home after leaving a fifty dollar bill with the owner. It was mounted on 3 1/4 inch angle iron and a big truck brake drum base. All I had to do was spray it with WD-40, oil it and put it to work. I use my newfangled drill press but if the Apocalypse comes I'm all set. Link to comment Share on other sites More sharing options...
Heelerau Posted November 26, 2018 Share Posted November 26, 2018 I recently found an auto feed that was missing from my Buffalo mod 615 , I use it for drilling holes in hoof picks. Good excersize ! Link to comment Share on other sites More sharing options...
Marc1 Posted November 26, 2018 Share Posted November 26, 2018 When I admire the dedication required to restore, clean or otherwise make work again this museum pieces, (I am a great fan of the Ford model A) if it comes to drill holes, I wouldn't use those contraptions if you paid me to do so. They are unsafe, slow, large footprint, weight a ton and do the job of a $50 handheld drill ten time slower. I concede they are nice to look at Link to comment Share on other sites More sharing options...
anvil Posted January 3, 2019 Share Posted January 3, 2019 lol, they also prove just why blacksmiths back in the day punched holes. I have a canedy otto like above. I ran it off a 1?4 hp motor. It needed bushings and the main shaft sorta wobbled. It was great for re-centering off centered center punch marks,,, just cant yer iron and walk the hole where it should have been... Link to comment Share on other sites More sharing options...
Please sign in to comment
