axle shaft, what steel ?
does anyone know what material axle shafts are made out of? I forged a sword and want to get it hardened so I can finish it. I can send it to a heat treating place that we use at work but they are going to want to know "what it is?" and "an axle shaft" won't work! thanks for any help.
Many different factors are involved. The age; alloys may have changed in the industry over the years. Is it a stock axle (original part) or is it a replacement? Could be better or not as good as original. What make of car did it come from? This could be less important as the Big Three could all get axles from a common vendor. Not sure if they were all made in-house. It could be anything from a medium to high carbon 10XX steel to an alloy such as a 4xxx or 5xxx grade. If your heat treater needs the info, you could, as Steve said, have a scrap piece tested.
  • 2 weeks later...
