Striking Vise
marcusb
Finally made up and mounted a striking vise in my new shop I built. Basically I found a nice heavy 4.5" vise cheap that someone had cut the leg off :( . Had some disc bolt that made a perfect stub leg, so I did a heavy bevel and welded it up with 7018. Mounted is opposite my anvil on the same stump. Forged a staple for the leg. Im trying to think up a nice clamp for the jaws that will let me lay large stock across the anvil, clamp it then use sledge.
post-14866-0-25199800-1410228744_thumb.j
post-14866-0-97315200-1410228917_thumb.j
The floor plate came out of my local steel yards "scrap" area. I think it was some kind of a jig plate that was used very little. It's 1/2" thick and weighs 250lbs.
This vise sits around 8" lower than my other vises so it works really good for upsetting or other projects that require heavy hammering.
