jwaingdci Posted August 16, 2014 Share Posted August 16, 2014 Hi I have a "75ish" pound anvil and I'm wondering how I should secure it. I'm thinking to a stump from a maple tree. Would ratchet strapping it work? Thanks in advance Link to comment Share on other sites More sharing options...
iron quake Posted August 16, 2014 Share Posted August 16, 2014 Take a couple steel bars across the feet and lag the ends to the stump. A couple short lengths of 1/4 x 1" with a hole in each end and 4 lag bolts will do the trick. If you can heat them up and form them around the feet thats better but you don't need to. Link to comment Share on other sites More sharing options...
arftist Posted August 16, 2014 Share Posted August 16, 2014 Take a couple steel bars across the feet and lag the ends to the stump. A couple short lengths of 1/4 x 1" with a hole in each end and 4 lag bolts will do the trick. If you can heat them up and form them around the feet thats better but you don't need to. That's more or less how I do it. Link to comment Share on other sites More sharing options...
iron quake Posted August 16, 2014 Share Posted August 16, 2014 Rubber, plastic materials have few uses in a smithy. Try to keep to metal, wood, stone and leather. There are exceptions always of course. Link to comment Share on other sites More sharing options...
Frosty Posted August 24, 2014 Share Posted August 24, 2014 That is a nice stand. Were I making one like it the only thing I'd do differently is to through bolt and glue the planks. Well, make a little wider base or a bending fork might cause it to be tippy. Lots of guys here have anvil stands like this one, it's solid old school. Frosty The Lucky. Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted February 11, 2015 Share Posted February 11, 2015 A bit of wood or steel carved to fir the curves beside the feet and a length of chain around the waist either lag bolted or with lag eyes in the side if the stump and either 1/4" lode binders or... The name elides me (part timers) ... Ah turn buckle. To clamp it down. Lode binders are nice if you need to pull them apart often. Link to comment Share on other sites More sharing options...
Please sign in to comment
