* * * * * 2 votes
Show me your forge (solid fuel)
284 replies to this topic
#1 Glenn
    Administrator
  • Administrators
  • 6,815 posts
Posted 14 October 2007 - 09:35 AM
Show me your solid fuel forge. Doesn't matter whether it is home made or store bought, coal, coke, charcoal or other solid fuels. Please give us a little information on the construction.
If someone questions your standards, they are not high enough.
#2 Glenn
    Administrator
  • Administrators
  • 6,815 posts
Posted 14 October 2007 - 09:37 AM
This forge was constructed from 10 ga plate steel, angle iron legs and a cast iron fire pot. The fire pot was about 8 inches by 11 inches and 5 inches deep.
  • Attached File  870.jpg   123.22K   535 downloads
#3 Mark Parkinson
    Member
  • Members
  • PipPipPip
  • 54 posts
Posted 14 October 2007 - 09:55 AM
made for re-enactments
build photos on my website at forgecart
and my every day "mobile" forge
#4 imagedude
    Senior Member
  • Members
  • 187 posts
Posted 14 October 2007 - 04:26 PM
Mine's made from 6mm (1/4") steel. The air is blown through a 8mm (3/8") stainless steel plate though mild steel would be perfectly acceptable. The fan is a 270cfm blower that was once used to cool the laser on a printing machine.
#5 Frosty
    Senior Member
  • Members
  • 7,796 posts
  • LocationMeadow Lakes Alaska
Posted 14 October 2007 - 04:32 PM
This is a pic of my large coal forge. The angle is a little odd but I wanted to show the ash dump which is a truck exhaust cap. The tuyere is welded up from 4" exhaust pipe.
The table is 3' x 3' fire brick on 12ga sheet, angle iron frame. No fire pot, I like a duck's nest and fire brick stacked to make whatever size or shape "pot" I need. The big hood is only marginally effective, I made it years before I knew what would work. When I move it into the new shop it'll get a side draft hood.
I also have a cast iron Buffalo rivet forge and hand crank blower but no pics.
Frosty
Outside of a dog a book is man's best friend.
Inside a dog it's too dark to read.
"Groucho Marx"
#6 skunkriv
    Senior Member
  • Members
  • 367 posts
Posted 14 October 2007 - 05:05 PM
This is my shop forge. 1/4" plate, angle iron legs and a Roger Lorance cast iron firepot. The hood is roughly the same size, shape, and color of a 100 lb propane tank :rolleyes:
The air from the blower (which is on the other side of the wall, less noise) is piped through 3" pipe to a box with a butterfly valve in it. Air exiting the box flows either to the tuyere or to a 3" pipe that is inside the hood. This pipe ends just below the chimney pipe. The air flowing through this pipe induces draft into the chimney (venturi effect) and so it draws really well even though there is only about 9 feet of vertical pipe, including the hood. When the air to the tuyere is totally cut off (and the fire is just smoldering) all of the air goes to induce the draft. Works great.
Edit-Ash buckets fill and then overflow. There are 8" dams on three sides welded to the legs. Ashes dump on the floor. When this area gets full I get a flat shovel and a wheelbarrow.
Steve White-Member UMBA, IVBA, BAM, ABANA
"The trouble with the rat race is that even if you win, you're still a rat"---Lily Tomlin
#7 irnsrgn
    Senior Member
  • Members
  • 1,760 posts
Posted 14 October 2007 - 06:43 PM
My first demo forge, set up in the ballroom of the hilton Inn in Sioux City, Iowa for the 100th National Blacksmiths Convention.
Irnsrgn
Knowledge must be shared or it lies dead in the mind.
#8 HWooldridge
    Senior Member
  • Members
  • 2,205 posts
  • LocationCentral Texas
Posted 14 October 2007 - 06:44 PM
Buffalo factory forge with large rectangular firepot - I added the tong rack. Used to have a factory half hood but that rotted away in a few years. I bought it practically unused from a man who had obtained it through government surplus. Apparently, the local military bases had scores of forges from WW2 that were sold off in the 1970's. The motor was 220v and he had it wired 110v. Since it would not come up to speed at that voltage, he simply set it in the corner until I found it in 1987. The factory rheostat and motor will create a great fire on the lowest setting with the damper barely cracked - I believe these blowers were designed to run several forges at the higher settings so it has no trouble with a single firepot.
#9 KevinD
    Senior Member
  • Members
  • 510 posts
Posted 15 October 2007 - 06:14 AM
Here I am rescuing my grandfathers coal forge.
See more pictures here...Excavation and Restoration
#10 jimbob
    Senior Member
  • Members
  • 968 posts
Posted 15 October 2007 - 10:08 AM
my coal forges
#11 primtechsmith
    Senior Member
  • Members
  • 840 posts
  • LocationAmelia, VA USA
Posted 15 October 2007 - 11:15 AM
This is one of the portables the Blacksmith Guild of Virginia built in our Forge building class in June. We finished 15 or so in about 3 hours!!!!! This design is by Mike Tanner....not me.
Peyton
  • Attached File  466.jpg   59.84K   456 downloads
Assistant Artisan Blackmith.
Yesteryear Forge
http://www.yesteryearforge.com
#12 yesteryearforge
    Senior Member
  • Members
  • 1,074 posts
Posted 15 October 2007 - 03:50 PM
Here is my forge shown in the old building, and a view of the new shop with all three in place
forges made from either 3/8 or 1/2 inch plate
hoods made from 3/16 plate
The big one is mine and the sides are cut out of 3/16 plate 6 ft wide and 14 ft long all one pc
the chimney is 1 ft deep x 4 ft wide.
Im 6 ft 6 so the forge is rather tall for most people but i built it to my specs
Mike Tanner
Give out before you give up. If it was easy anybody could do it.
#13 Jmercier
    Senior Member
  • Members
  • 342 posts
Posted 15 October 2007 - 05:31 PM
I'm getting forge envy >_< Nice cone btw Mike. I just sold mine this last weekend. Not that i really wanted to sell it, but it was the least used item in my shop and I took the money from it and put it asside towards the money I need to get a powerhammer (with an upcomming build-a-hammer workshop at a metal arts school near me).
Here's my meager coal forge =P
http://www.tharkis.c...p/coalforge.jpg
And here's my fancy coal bin !
http://www.tharkis.com/images/coal.jpg (that's the cone i just sold this last weekend /mourn, but at least i know the person i sold it to and he said i can go and visit it at any time and use it whenever i want =P )
#14 meancoyote
    Member
  • Members
  • PipPipPip
  • 85 posts
Posted 15 October 2007 - 09:32 PM
this is my forge, its made of a old washtub, fire bricks and clay. i burn charcoal, coal, wood, or what ever i can get. coal is real hard to get here. sorry i dont know how to post the thumbnail pics like everyone else.
Answer to your question:
Make your post as usual. Then below the box where you type in your text is a section called additional options. Go to the "Attach Files" section and click on Manage attachments.
Upload File from your Computer will let you browse your hard drive for photos. When finished and click on the UPPER button called UPLOAD.
Upload File from a URL
is where you place the URL if your photo is posted on the internet (such as the IForgeIron Gallery). Copy the URL and paste it here. Click on the LOWER UPLOAD button. To add another photo, repeat as needed.
When you are finished attaching photos, go back to the box where you type in your test and click on Submit New Thread to save both the text and the images.
Site Admin.
#15 Don A
    Senior Member
  • Members
  • 1,025 posts
  • LocationEast Tennessee / foothills of the Smoky Mountains
Posted 16 October 2007 - 07:58 AM
Meancoyote,
If that is charcoal briquettes you're using, you can get a lot more heat from the real stuff.
Lowes usually has real charcoal (about $4 / bag)... or you can make your own. There's a lot of info around on how to do that.
I'd venture to say that you would be better off with seasoned wood that you would with briquettes. It's a bit smokey until it chars, but the heat is going to be a lot better than the Kingsford or Matchlight.
Don
#16 Michael
    Senior Member
  • Members
  • 199 posts
  • LocationSan Francisco Bay Area
Posted 16 October 2007 - 11:20 AM
Here's mine, brake drum forge, I've since cut slots in the side for longer work. Legs from half inch square. I've got a bit cast iron sheave pulley on the lower rails now with lots of scrap piled on it. Currently looking to find or fabricate a squarish table out of bed angle iron and plate to give me a bit more room on top.
#17 Frosty
    Senior Member
  • Members
  • 7,796 posts
Posted 16 October 2007 - 01:57 PM
Consider an appliance lid or door, they're really easy to find if you know where the local illegal dump sites are. :cool: My first forge was a washing machine lid with a brake drum let into it and packed with clay to the rim of the drum.
Frosty
"Groucho Marx"
#18 Ten Hammers
    Old fat guy with the pliers
  • Members
  • 1,036 posts
Posted 17 October 2007 - 05:44 AM
Shop forge here at home. I might add that the forge table is 7 ga ( 3/16 ) and the hood is 14 guage. I have an airgate ( borrowing Junior's plumbing design to the tuyere) and power blower ( probobly a blower from a high efficiency appliance of some sort ). As Steve White I have a Roger Lorrance firepot but I built the tuyere and ash dump. Coal and Charcoal forge.
" It ain't real if it ain't forged "
You can't clear the water till you've got the pigs out of the creek.
#19 Dutchmancreek
    Senior Member
  • Members
  • 170 posts
  • LocationWest Virginia
Posted 17 October 2007 - 08:37 AM
Here's my coal forge...steel framing and table with a Centaur Forge firepot and hood. Before you say anything, the photo was taken after a major cleanup and painting...it's a lot dirtier now.
Attached File  forge 1.jpg   73.14K   392 downloads Attached File  forge 2.jpg   54.88K   265 downloads
Steve
Never take off your hat, never sign your name
[SIGPIC][/SIGPIC]
#20 Dutchmancreek
    Senior Member
  • Members
  • 170 posts
Posted 17 October 2007 - 08:46 AM
This is the front of the forge now...I forgot to include it in the previous post.
Attached File  tongrack.jpg   60.05K   292 downloads
Steve
[SIGPIC][/SIGPIC]
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
