Matched pair damascus clip and drop point. Just completed.
matt trout
Have not posted anything in a while, thought I would throw these two out there. Custom order for a friend in N.C. Matched pair of clip point and small horizontal carry drop point.
Blades are 99 layer voodoo (left –then right twist) 1095-15N20 damascus, roughly forged to shape, ground, oil quenched tempered twice. 304 stainless bolsters-pins-guards, All peened . Brass inserts in guard that do not show up in photo – once again phone photo challenged.  I tried a bit of file work on the backs, need to practise that some more. Used black epoxy to fill around scales and tang. Scales are lacewood that I stabilized with epoxy under vacuum.
Sheaths are 9-10 oz cowhide. I used a tri-weave stamp for tooling and swiped black dye over the high spots in one direction before dying the entire sheath. Gives a different look. As always comments/suggestions welcome. Matt
post-46419-0-66409200-1398087229_thumb.j
post-46419-0-73876500-1398087239_thumb.j
post-46419-0-65499800-1398087250_thumb.j
