wrought iron value?
  • Replies 57
It's. 4" round bar, as far as grade I have no clue looks like fine grain and very shiny at the break. I happen to work at a scrap yard and only noticed this because a piece came in broken. I believe they are some sort of tie bolts from a farm and they are about 15' or 20' long and the the diameter is rough didn't actually measure. It.
even the industrial silos at the Globe Mills only used 1.5" rod.  Please measure the diameter and a picture of the break would be GREAT!
I once was given a bit over 100' of real WI 1" rod that had been used to mend a cistern cracked in the 1906 quakes in Socorro NM.  They had one end threaded and the other was a hook
Heavy bolts like that would likely have tied round a huge industrial chimney!  The old Carnation plant in Nampa Idaho gave the scrap yard, where I worked at the time, some that were about 2 1/2" diameter if I remember correctly.  They came off of a brick chimney that had been maybe 150' tall.  The giant articulated loaders, that we used to move around bales of crushed cars, had all they could do to drag some of those around!
You're sitting on good money!
Wrought iron in that size is almost unheard of these days.  If I had the money, I'd buy a foot from you.  Not sure what I'd do with it, but better to have it than not!
Sell it in foot-long chunks and set a price for your time + shipping....  You could make a few dollars or even offer it for trade on stuff you need.
I'd recommend sending some to experienced smiths so you can get their feedback/endorsement for the quality.
I think if you priced it right you could make some real money on that stuff.  I certainly wouldn't just give it away.  Wrought in that size would be very valuable many  different of sorts of smiths.   With a good power hammer that material could be forged down to any dimension.  People doing restoration work would love  it.
Well the bottom level for WI seems to be about US$1 a pound.  In more easily worked sizes I've seen it go for up to $6 per pound---but I've always considered that excessive as I usually buy mine at 20 cents a pound at the scrap yard.  Might check out places like http://www.oldglobewood.com/real-wrought-iron.html  to see how they are pricing it  As I recall they were starting out high for the small stuff and getting a lot cheaper for the big stuff.
I don't consider a chop saw as "efficient" for cutting 3.5" rod; a horizontal bandsaw where you could set it and leave it and it would turn itself off at the end of the cut is efficient!
I might be interested in a chunk to make some early medieval anvils from depending on price.
Price-wise, I wouldn't get too crazy.  While $6/lb doesn't sound too bad, think about how much just a foot of it weighs.  $180 per foot, roughly, plus shipping.... you're now in the prohibitive range for 70% of the customer pool.  Yea, everybody would like to have a piece, but hardly anybody can afford a piece.
Not saying it's not worth it, though.  You just don't see wrought iron in 3" bars anymore, and rare stuff is always expensive.
Why I said the market was neither deep nor wide---not a lot of people using real wrought and that's a size that cuts most of them off and not a lot of deep pockets.  At $180 I'd forge weld up a stack of smaller stuff and get bragging rights for doing it thataway too!
As for why it was on the farm---maybe picked up to weight implements and was probably originally from the *old* industrial base in the NE USA.
Posted · Hidden by Steve Sells, April 19, 2014 - useless
Maybe someone just really liked wrought iron? I dun got the most uh dem wrodd iyerns. How much you got billy Jim John d'gee Mc'sanders?
