Heat treat spring
Normalize would probably work for those as they don't see much throw.  Try it and see!
If you need to harden and temper: heat till the steel loses it's magnetism, quench in warm oil, (vegetable oil is ok, warm is around 140 degF); draw temper to a deep blue  (this depends on the alloy used of course!)
As Thomas says draw to a deep blue.
       Although on a spring of this type it's hard to polish the entire spring to see the color. A traditional method to try (it still depends on the alloy used if it will work or not) is to dip in oil after hardening and flash the oil off over the fire. Repeat this atleast three times.
  • 3 weeks later...
  • 2 weeks later...
 Temper in the wife's kitchen oven at 550F its a perfect spring temper "dark blue" I doubt you need to do it at all as there is very little deflection in a springs of those types. I temper all my 4140 hammer dies and many other tools as well in my honeys oven. it's not just for pie you know. Just clean the parts well with a wire wheel so you don't take any left over quenching oil with you a stink up the house.
Also I don't know why anyone makes anything that needs heat treatment from scrap. You have know idea what you'll wind up with. If you need a small amount of material order it from Mc Master Carr. If you need a lot order that from Hudson Tool Steel the best prices and high quality.  Time is money and failed tools are a waist of both.
I don't see any problem using scrap in this situation, especially if the scrap is already a spring of some sort.
Many may do this just for sake of doing it, reusing otherwise scrap items, lack of funds, and some companies will not sell to non-business accounts. I have to supply McMaster Carr catalogs to my friend because they flat refuse to send him one. We get new ones all the time at work, so I take him the old one that we are getting rid of.
Well I guess if your making a spring from a spring and I see the value in reusing things and not waisting anything. I just can't get past putting a lot of time into making something only to have it crack in the first use. Anyone who has a computer can do their shopping online at the places I mentioned above, so no catalog is required, if you don't have a computer in 2014 that sucks . By the way a "8 x "12 ".032 thick piece of annealed 1075 is $16.42. that makes a lot of springs. And yep they are very stingy with there catalogs for sure.
old hay rake tines and potato planter belt make excellent springs. i treat them like W-1.
they are 3/8 round and are usually give-a-way stuff.
when tempering, i flash them once or twice in corn oil depending on my whim.
advice from Tom Bredlow years ago.
