Arm and hammer anvil
My mom was scrolling through Craigslist this week and told me she saw an anvil for sale.I waited while she found the ad but I didn't figure it would be anything I wanted.The add said" anvil 300$" with a picture attached;I looked at the pic and saw that the anvil looked to be around 200 lbs so decided to go look at it.the anvil turned out to be a 200 lb arm and hammer in pretty decent shape with a nice metal stand.I pulled out the money loaded up the anvil(I didn't even mind the 200 lb weight since I was payin 1.50$ a lb)and came home.I cleaned her up and she is back in use :)post-25948-0-40238700-1379722323_thumb.jpost-25948-0-06665100-1379722359_thumb.jpost-25948-0-99100900-1379722432_thumb.jpost-25948-0-32121300-1379722473_thumb.jpost-25948-0-58279000-1379722664_thumb.jpost-25948-0-40825000-1379722724_thumb.jpost-25948-0-91450100-1379722763_thumb.j
I do not think that they welded the anvils with the beads running up and down like that, but in the other axis around the anvil.
What is the serial # on the front foot under the horn? If it is a number lower than 46555 it was probably forge welded according to the info that I see in Anvils in America. Around 1940 is when they began arc welding the base on.
I have an 84 lb Arm & Hammer that was forge welded and it looks like it may fail at the weld. Someone may have welded over that type of a defect on your anvil
I would not worry about the weld you got a good deal
So your anvil was made before 1940 around 1935 according to Anvils in America. So it was forge welded and probably looked like this
post-10376-0-42594300-1380026128_thumb.jpost-10376-0-47648200-1380026133_thumb.jpost-10376-0-50311200-1380026137_thumb.j
This is my 84 lb Arm & Hammer you can see how the forge weld looks incomplete. Some one may have welded over this type of defect to prevent failure
Interesting.
I have a 362# A&H with forged divots in the face, and I was wondering about those too
that anvil is beautiful!!!!!
Greetings Rhett,
I also have a A&H with the same divots and dots in the base.. I think it was part of the process using scraps when forming the base ... Mine looks real crude..
Forge on and make beautiful things Thanks for the input i thought i had saw an anvil with bumps like mine somewhere else.
Jim
thanks jim now i know mine isnt the only one like this
. Thanks for the help clinton i didnt think the welds looked original
