Temper Colors and Oven Tempering
Perhaps...but easily attainable is the gold-straw colors.
Problems occur when small amounts of oilly residue end up on the piece and the oven heats that funky oil.
Result may be you are to buy that new house sooner that expected.
Consider a toaster oven from Wally World and put in the shop.
For a little while.  Maybe... because the lacquer may change the color immediately!  These colors are very thin oxides and are usually what artist's refer to as "ephemeral"!  Like the colors of a fresh caught grayling... they shimmer with beauty... and then fade!  Some things cannot be captured and admired at leisure!  You have to be there "in the moment"!
Greetings,
Sounds like a small opener... You can put a 2in pipe in your forge ...thick wall...  heat it up cherry  ... slide in your part.... wait for color....quench.  and finish...I suggest if you finish with spray enamal or lacquer..  only put a dusting on first AKA tack coat...wait to dry...
Good luck
Jim
