Cast Iron, Wrought Iron and Etching
  • Please log in to reply
11 replies to this topic
#1 Gundog48
Gundog48
    Senior Member
  • Members
  • 159 posts
  • LocationKent, England
Posted 30 September 2012 - 11:41 AM
Many of you here have been blacksmiths for many a year, I however, have just started a few months ago. Nowadays, wrought iron is very hard to come buy as it isn't produced in any scale any more, and as most of what I do is bladesmithing, I've never really forged iron.
I saw a wonderful example of an etched wrought iron crossguard and pommel on the forums, and I'd like to make something similar for a knife I am making. From what I gather, wrought iron is iron that has been folded, welded and hammered many times to get rid of many of the impurities found in cast iron. I have a piece of cast iron I managed to find, so if I were to weld it back on itself many times, I would have wrought iron?
And with the etching, is it just a case of etching the wrought iron as it is? I assume the layering of the iron produces the desired effect and that I don't have to add a different metal to the billet, like with pattern welding steel, to create the contrast?
Thanks!
#2 bigfootnampa
bigfootnampa
    Senior Member
  • Members
  • 1,697 posts
  • LocationMissouri
Posted 30 September 2012 - 12:41 PM
NO! You have it wrong. It might be possible to make wrought from cast iron but I think you'd need a bloomery... you cannot forge weld cast iron.
#3 Dan P.
Dan P.
    Member
  • Members
  • 444 posts
  • LocationDidbrook, Gloucs
Posted 30 September 2012 - 12:56 PM
Take a peek;
http://en.wikipedia....ki/Puddled_iron
#4 ThomasPowers
ThomasPowers
    Senior Moment Member; Master Curmudgeon
  • Members
  • 13,708 posts
  • LocationCentral NM
Posted 01 October 2012 - 11:20 AM
The Real Wrought Iron Company, LTD in Coalbrookdale UK sells real wrought iron otherwise you are at the mercy of the scrap stream where you are at---here in rural NM, USA I picked up a 1" round 48" long wrought iron bolt at the scrapyard Saturday---paid about US$1 for it... Has quite visible striations and so is probably a lower grade---what knifemakers prefer as high grade wrought iron does not show much "pattern" in the etch. (Old wagon tyres are a favorite source of low grade WI out here)
Repeated forge welding of cast iron to get wrought iron is about as accurate as repeated forge welding of glass to get fiber glass---it's not the way it's done! You could puddle your own from cast iron; however that would make the price probably more than *ten* *times* *MORE* than buying it directly. You can also take iron ore and smelt your own wrought iron in a bloomery for expensive small yields---I've done so many of times to learn a fairly useless ancient skill; but except for bragging rights and hour at the local scrapyard can get me more wrought iron than a week building and running a bloomery!
Remember most everything made of iron before the 1850's (Bessemer/Kelly Process) was made from wrought iron or cast iron so old buildings, bridges, ag equipment can all be a source of the real stuff once you train yourself to recognize it!
Thomas Psychotic Psychobabblonian Powers
#5 Gundog48
Gundog48
    Senior Member
  • Members
  • 159 posts
Posted 02 October 2012 - 01:12 PM
Thanks Thomas, that was very enlightening! I'll check out the company you mentioned. What is the best way to differentiate wrought iron from cast iron when sifting through scrap? I can't really go around whacking things with a hammer or etching them while I'm there, sometimes the use of the piece can give a hint, I guess, but is there an easier way?
Really, low grade stuff is what I want, the plan is to form it to the shape I want for my knife fittings then heavily etch them for a dramatic look!
#6 basher
basher
    Junior Member
  • Members
  • 614 posts
  • Locationlondon UK
Posted 02 October 2012 - 01:33 PM
I have some.
If you are close by then you would be welcome to a bit.
the real wrought iron co re welds and re roles wrought iron it is very good quality stuff for making decorative wrought iron but lacks the real character of old poor quality decorative iron (in my opinion).
Owen Bush bladesmith
Forging Soul into steel
bushfire forge school of smithing
#7 Bentiron1946
Bentiron1946
    Senior Member
  • Members
  • 3,700 posts
  • LocationCave Creek, AZ, USA
Posted 02 October 2012 - 04:29 PM
If you are in an area where it is near impossible to acquire wrought iron give eBay a try, there are usually a couple of guys that sell it there in short lengths for the blade smith or jewelry artist. One problem with though and that is it is not cheap. You can also buy already made up billets so you can just grind you own knife.
Malleum sapientiorem vidi excusso manubrio!
#8 ThomasPowers
ThomasPowers
  • Members
  • 13,708 posts
Posted 03 October 2012 - 10:23 AM
Well, especially for the low grades, the striations shown by weathering are a dead give away---how I recognized the 1" dia x 4' long bolt at the scrap yard. I also look for forge welds and items treated like wrought iron---there are some design differences used with it. Also look for the green stick fracture of real wrought iron---many scrap yards will let you hacksaw a corner and break it off.
Can you see the striations in this piece:
http://i1271.photobu...g/SANY00173.jpg
Last time I looked around in the UK it was awash with real wrought iron---found pieces in my hosts garden where rubbish had been discarded 100 years ago. Much more common than in the USA where we didn't have nearly the population during the early industrial revolution!
Another way of recognizing WI from CI is what it's used for. Just like CI and mild steel are used for different types of things nowadays; WI and CI were used for different types of things back then---you don't find cast iron Wagon tyres---they would break the first rock they hit!
#9 Frank Turley
Frank Turley
    Member
  • Members
  • 1,474 posts
  • LocationSanta Fe, New Mexico
Posted 03 October 2012 - 09:26 PM
Some scrap yards have a shop adjoining, and the owners may allow you to use their grinder for a spark test.
Grandaddy of all blacksmithing schools
http://www.turleyforge.com
#10 Gundog48
Gundog48
    Senior Member
  • Members
  • 159 posts
Posted 04 October 2012 - 12:43 PM
Owen, I'll make it my job to come and visit you as soon as I get some time off school! To have an such an experienced and accomplished bladesmith so close to me without even visiting is a crime! Not sure what I could offer in return that you wouldn't be able to make 10x better, but it would be nice to have a peek at a proper bladesmith's shop and come back with a little bit of loot!
#11 basher
basher
    Junior Member
  • Members
  • 614 posts
  • Locationlondon UK
Posted 04 October 2012 - 01:40 PM
I am around most of the tiem , just email prior to when you want to visit to make sure.
#12 Eric Leonard
Eric Leonard
    Newbie
  • Members
  • Pip
  • 1 posts
  • LocationA Desert
Posted 06 February 2013 - 12:53 AM
local scrap yard owner flat out refuses to sell his scrap iron/steel to any private person, business's however.... i even found 6 large mining drill bits i was interested in.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
