lloe01 Posted June 18, 2012 Share Posted June 18, 2012 It is approximately 16" high with a 13"X16" base. It has a 5 3/4"X24" face, 15 1/2" horn and 1 1/2" hardie hole. The previous owner says 250 pounds, I say 350 or larger. my daughter says it has the number 186830 or 186930 on the front. She lives in San Antonio where the anvil was. I live 600 miles away and will go pick it up on July Fourth holiday. Woohoo! Link to comment Share on other sites More sharing options...
Farmall Posted June 18, 2012 Share Posted June 18, 2012 If it were a hay budden, it would be between 350-450 pounds according to the 1914 catalog. Here's a link to it on this forum. Hay buddens had a serial number on the front left side. It's a keeper!http://www.iforgeiron.com/topic/18789-hay-budden-anvil-catalogue-from-191415/ Link to comment Share on other sites More sharing options...
lloe01 Posted June 18, 2012 Author Share Posted June 18, 2012 If it were a hay budden, it would be between 350-450 pounds according to the 1914 catalog. Here's a link to it on this forum. Hay buddens had a serial number on the front left side. It's a keeper!http://www.iforgeiron.com/topic/18789-hay-budden-anvil-catalogue-from-191415/ Thanks, I will keep that as a reference! Right now they are still trying to figure out how to get it into the back of the truck. :) Link to comment Share on other sites More sharing options...
CurlyGeorge Posted June 18, 2012 Share Posted June 18, 2012 An easy way to get it in the back of the truck, if you don't have a way to lift it, is to set up a 2 X 12 ramp and just carefully walk it up the ramp. That's how I loaded and unloaded my 250# Trenton. Worked great. WOW!! What a score!! Congrats!! :) Link to comment Share on other sites More sharing options...
lloe01 Posted June 18, 2012 Author Share Posted June 18, 2012 An easy way to get it in the back of the truck, if you don't have a way to lift it, is to set up a 2 X 12 ramp and just carefully walk it up the ramp. That's how I loaded and unloaded my 250# Trenton. Worked great. WOW!! What a score!! Congrats!! :) They started to do that and the ramp broke. Now they are thinking about come along and chain and finding a real ramp. Added later: Ok, it finally made its way to my daughters house. Link to comment Share on other sites More sharing options...
Farmall Posted June 18, 2012 Share Posted June 18, 2012 stiffen the wooden ramp by gluing/nailing a 2X4 vertically to the center underneath...... Link to comment Share on other sites More sharing options...
Frank Turley Posted June 18, 2012 Share Posted June 18, 2012 I have 3 HB's in the shop and my largest, slightly over 300 pounds, has these measurements: 12.5" high; 11.25 x 13.25" base; 5.25 x 20" face; and 15.5" horn. All I can say is, "You've got a heap big anvil!" Good for you. Link to comment Share on other sites More sharing options...
Fatfudd Posted June 19, 2012 Share Posted June 19, 2012 go rent an engine hoist, its cheap and easy Link to comment Share on other sites More sharing options...
lloe01 Posted June 19, 2012 Author Share Posted June 19, 2012 go rent an engine hoist, its cheap and easy That is brilliant! Thanks! Link to comment Share on other sites More sharing options...
fluidsteel Posted June 20, 2012 Share Posted June 20, 2012 An easy way I loaded my 300# Fisher 4 times in the last year due to moving was I got 30 or so 2' 2"x6"'s etc from my Dad's scrap pile. Walked the anvil onto the first 4. 2 ea laid side by side then rocked it onto the heel side feet. Added a 2"x6" under the feet and repeated until it was high enough to walk right into my trailer. Easy as pie. Link to comment Share on other sites More sharing options...
lloe01 Posted June 20, 2012 Author Share Posted June 20, 2012 Heck, that is pretty good too. Thanks Link to comment Share on other sites More sharing options...
ThomasPowers Posted June 20, 2012 Share Posted June 20, 2012 What does the bottom look like? Also is the underside of the heel smooth or faceted? To my eye that anvil might possibly hail from Columbus OH and not Brooklyn NY. Either way a top notch anvil (I've got both kinds and use them both!) Link to comment Share on other sites More sharing options...
lloe01 Posted June 21, 2012 Author Share Posted June 21, 2012 What does the bottom look like? Also is the underside of the heel smooth or faceted? To my eye that anvil might possibly hail from Columbus OH and not Brooklyn NY. Either way a top notch anvil (I've got both kinds and use them both!) I will have her take a look. Link to comment Share on other sites More sharing options...
Timothy Miller Posted June 21, 2012 Share Posted June 21, 2012 My bet is it is not an HB. The base it too smooth Hay-budden bases were made out of scrap iron forge welded together they often have a lot of texture and sometimes even visible voids. It looks like it could be Trenton or an arm and hammer. Link to comment Share on other sites More sharing options...
CurlyGeorge Posted June 21, 2012 Share Posted June 21, 2012 Going by the serial numbers, and according to Anvils In America, for Trenton both numbers were born in 1924, and both numbers for HayBudden were from 1911. :) Link to comment Share on other sites More sharing options...
lloe01 Posted June 22, 2012 Author Share Posted June 22, 2012 What does the bottom look like? Also is the underside of the heel smooth or faceted? To my eye that anvil might possibly hail from Columbus OH and not Brooklyn NY. Either way a top notch anvil (I've got both kinds and use them both!) They had glued carpet to the feet Link to comment Share on other sites More sharing options...
Sask Mark Posted June 22, 2012 Share Posted June 22, 2012 Looks like a Trenton. Link to comment Share on other sites More sharing options...
ThomasPowers Posted June 22, 2012 Share Posted June 22, 2012 Yub definitely not an HB with a depression on the bottom like that! The carpet was a laugh though, guess with the paint and carpet it was a decorator piece used inside the house... Link to comment Share on other sites More sharing options...
lloe01 Posted June 22, 2012 Author Share Posted June 22, 2012 You mean I might have saved it from a life of luxury? I didn't get my daughter to try the ball bearing test on it. Hopefully that will be good or it may go back to being a coffee table :) Link to comment Share on other sites More sharing options...
lloe01 Posted July 1, 2012 Author Share Posted July 1, 2012 Ok, it looks like it says "Tre" inside a diamond, but can only see the left portion of the diamond. It has several coats of paint on it and has filled in a lot that might be able to tell me what it is. But It is probably is a Trenton I tried a big ball bearing on it and it rings incredibly loud! So, I will try to remove the paint when I get it home next Wednesday. Then I can see the weight and serial number. Woohoo! Link to comment Share on other sites More sharing options...
lloe01 Posted July 2, 2012 Author Share Posted July 2, 2012 Serial number is definitely 186839 Link to comment Share on other sites More sharing options...
lloe01 Posted July 5, 2012 Author Share Posted July 5, 2012 I got it loaded (well, my family and I got it loaded) and I brought it home and stripped most of the paint. It looks pretty good although the table has some damage with a few spots of similar damage to the horn. Link to comment Share on other sites More sharing options...
Please sign in to comment
