* * * * - 8 votes
Steam Hammers
  • Please log in to reply
524 replies to this topic
#461 JNewman
JNewman
    Senior Member
  • Members
  • 1,214 posts
  • LocationHamilton, ON Canada
Posted 10 September 2013 - 09:08 AM
Other Massey users, do you ever have a problem with the oil dipstick and a bunch of oil being blown out when using the single blow/squeeze setting?  The previous users of my hammer started the hammer in low pressure hold up and I have always done the same as going from hold down to low pressure hold up the dipstick gets blown out.  As well the treadle guard on the hammer interferes with the treadle going all the way up which is not a problem at all when using the hammer with the treadle.   As the handles are on the opposite side of the hammer I am not sure exactly when the oil blows out but I suspect it is during the high pressure hold down.
I am ordering a plate burnout today to make a new treadle guard as I had to extend the treadle last week so I could run the hammer from the back side.  I had to forge a bunch of 12' long chisel bars and it was either punch a hole in the wall (which I considered)  or run them through from the back on a 45.  My dies are 9"x3.5" so I could not run them on the ends of the dies.  I am also ordering steel for new 8" square dies this week so I can run them on the other side from the front.  They are going to take a while to machine though I will probably have to run the bars through from the back again.
John Newman http://nfap.ca
#462 iron woodrow
iron woodrow
    carbon based lifeform
  • Members
  • 865 posts
  • Locationthe shadow of walshs' pyramid, FNQ australia
Posted 11 September 2013 - 02:55 AM
I never have had that problem on the MASSEYs I have used, the Clearspace #5s I've used have heavy weighted dipstick heads, maybe to stop such a problem happening....
and the #1 guided hammers have the oilers on the near side.
one of the #5s really huffs and puffs in hold up mode, and stirs up dust underneath, but no launching of dipsticks!
#463 nonjic
nonjic
    Long Member
  • Members
  • 938 posts
Posted 11 September 2013 - 10:15 AM
Ive seen them throw the dipstick ! It should be a pretty tight fit in the filler cap (earlier hammers did not have the stick at all)
Ive seen lots of CSPH's with a modification to hold it in place (screw and tab, or whatever)
The treadle guards can be a real compromise. They were a retrofit to earlier hammers, then become standards, after a 'slip squish' accident. I find them to be quite handy for dropping tooling on, most people take them off !
~ The artist formally known as John n ~
#464 JNewman
JNewman
    Senior Member
  • Members
  • 1,214 posts
Posted 11 September 2013 - 10:33 AM
My treadle guard is really handy for piling tools on while I am working  (can't have enough horizontal surfaces in a shop)  I do drop work sometimes and having heavy work on the treadle could get exiting.  My guard looks like it was shop built and it is pretty beat up anyways. It drops over the anvil so the head either has to be fastened up or the hammer running to take it on or off which I don't like especially since it is pretty heavy/awkward to take on or off by myself.  The new one will be open in the back with a piece that drops in.
I will have to think about a retainer.
#465 forgemaster
forgemaster
    Professional Blacksmith
  • Members
  • 961 posts
  • Locationon the eastern side of Mt Tumblebee
Posted 11 September 2013 - 11:59 PM
yeh we have blown the dip stick out occasionally, fixed it by going and swapping the older style cap out of our spare 5, no dipstick but no blowouts either.  We don't have a treadle guard, probably should, its something we talk about, we have dropped stuff on it over the years, everyone just stands back until the offending item falls onto the floor.  Last time it happened the ringing saddle ended up wedged over the edge of the top die.  The main problem we have figured with having a guard is when we use single blow with the pedal we drive with our heel and sit our toes on the edge of the anvil base cap, having a guard there will stop us doing this, needs some thought put into the design I feel before we go down this road.
Those who live by the sword normally end up getting shot by those who don't.
#466 forgemaster
forgemaster
  • Members
  • 961 posts
Posted 13 September 2013 - 01:08 AM
To get this thread back onto steam hammers after it had been rudely hijacked by owners of massey clear space owners, we own a steam/converted to air hammer which I bought from the steel works here in Newcastle.  As you will see from the photo attached it has a non standard top cover, which houses a buffer which stops the rod from smashing into the the top cover (if there was a std top cover there).  All the larger hammers at the steelworks (BHP) had this buffer fitted, it has 2 lines going to it, one from the incoming supply pipe, and the other comes from or to the exhaust pipe.
My question is are these an "off the shelf item" or are they a modification the BHP has manufactured themselves, I have seen photos of hammers in Europe with what looks to be the same thing fitted.  Anyone know?
Also can these buffers operate with steam as well as air, or is it just air only, the hoses going into to buffer are actually hydraulic hoses, biut it is air which is going through them.
Phil
#467 forgemaster
forgemaster
  • Members
  • 961 posts
Posted 13 September 2013 - 01:24 AM
As far as I can see the addition of the buffer top was to allow the removal of the trigger, which the hammer head would hit if it was brought up too fast, if the trigger was not there the hammer would/could smash into the top cap and also probably the gland at the bottom of the cylinder.  The problem with the trigger was when the hammer would hit it, the control handle which the trigger was attached to would normally nearly break the hand of the hammer driver, he'd let go of the handle and the hammer would go out of control.
#468 JNewman
JNewman
    Senior Member
  • Members
  • 1,214 posts
Posted 13 September 2013 - 06:54 AM
Speaking of steam hammers I was in a shop the other day with about a dozen steam hammers.  They were on a shutdowm so none were running but the "small hammer"  in the shop was 3000lb.   It was a closed die shop and they want me to make some tongs for them.  Hopefully I get a chance to see things running when I deliver the tongs.
#469 Jim Kehler
Jim Kehler
    Senior Member
  • Members
  • 160 posts
  • LocationSteinbach, Manitoba, Canada
Posted 13 September 2013 - 08:57 AM
The hammers I have experience with had a cap with a spring inside attached to a pin that went into the cylinder so the piston would hit the pin before it hit the top.
#470 John Larson
John Larson
    Member
  • Members
  • 445 posts
  • LocationBaltimore, MD
Posted 13 September 2013 - 04:51 PM
Phil, this thread is not exclusive to steam hammers at this point, but rather an educational thread where truly experienced hammer users are educating those of us like me who need the lessons.  Your response has been in video and written form and has shown me some of the aspects of "best hammers",. and John Nicholson's postings have been invaluable as well.  So don't stop giving lessons, please.  I'm really appreciative.
Producer of Iron Kiss air hammers (ironkisshammers.com). See my blog here at IFI.
#471 John Larson
John Larson
    Member
  • Members
  • 445 posts
Posted 13 September 2013 - 04:59 PM
On steam hammers and self-contained hammers, the amount of pressure on top of the piston at near the top of the up-stroke is sometimes not very high and is below atmospheric in a Beche. So top cushions have to be designed with this in mind. The yellow cap on the steam hammer that you have shown with two hoses undoubtedly holds a piston that is pushed perhaps by a rod that the regular ram piston pushes near the top of the stroke. The little top hose feeds that cushion piston needed pressure (perhaps from the bottom of the regular ram piston).
#472 forgemaster
forgemaster
  • Members
  • 961 posts
Posted 13 September 2013 - 07:17 PM
Hey John
Its cool, just didn't want the OP to think we were hijacking his tread for Non steam hammer purposes, (perish the thought). I don't really want to know how these caps work (although what you said is interesting) I was interested to see if these were an off the shelf item somewhere, this hammer in Europe has almost an identical looking cap on it.
One day when I have the time, I'll pull that cap off and have a look inside of it. When this thing was in operation and when the hammer driver let the hammer go to the top of stoke in between jobs, there was an audible clang as the rod hit whatever it was in there. The guys that worked under it said that to get a longer fuller harder blow they would actually drive the rod up into the buffer in order to get a run at it so as to speak, (sort of like a forging version of an Evil Kenevil ramp)
#473 forgemaster
forgemaster
  • Members
  • 961 posts
Posted 13 September 2013 - 07:31 PM
While on the subject of hammer guards and safety etc, and while looking through my files for those photos I also found a photo of a temporary disposeable hammer guard/safety shield for hand hammers too.
(This is to be taken with a grain of salt too guys, I'm not being serious here, just made me laugh seeing the photo thought I'd share)
#474 nonjic
nonjic
    Long Member
  • Members
  • 938 posts
Posted 14 September 2013 - 02:44 AM
I have seen the buffer cylinders (buffer pistons) on quite a lot of hammers. They tend to be fitted to 'stamping' closed die hammers, as once you are off the foot treadle and onto the trimming press the ram is going to reciprocate back up to the top on its own.
I have seen them on 'Erie' , Chambesburg, Huta Zygmundt, various Russian & Massey closed die hammers. I can only recall seeing them on Erie open die hammers.
Don't half make a clang when you smack the ram piston into them! Basically they are just a deep disk with piston rings round the diameter, and a smaller diameter that the other piston head smacks into. Sometimes they are seated on a cone face. The ones ive experience of have a permanent feed of air to them from the top.
Ive got a video on my phone of a 6000lb erie open die we rebuilt 'topping out' into the buffer - Ill throw it onto youtube later when I get a chance.
#475 John Larson
John Larson
    Member
  • Members
  • 445 posts
Posted 14 September 2013 - 05:50 AM
More good info. I really like the looks of that modern day steam hammer with the two posts and horizontal beams to hold the guides and cylinder. Could use that design right now where fabrication has to be used instead of devoted wishbone castings like days of old.
Structurally, the two post and wishbone designs fight the inherent rocking forces of a C-frame design. Every time the hammer head is lifted the C-frame wants to tilt forward, and then tilt backward as the hammer head comes down. The two posts symmetrically share the loads.
#476 Ford8nman
Ford8nman
    Newbie
  • Members
  • Pip
  • 6 posts
Posted 21 September 2013 - 08:27 PM
I just read through this thread, and wow there is a ton of info here. I happened to notice that 4 or 5 of the people in this one thread are banned? It says that above their picture. What's up with that? I guess we won't see pictures of harrismetalsmith's new steam hammer running?
#477 Dillon Sculpture
Dillon Sculpture
    Member
  • Members
  • 1,478 posts
  • LocationAtlanta area
Posted 22 September 2013 - 07:32 AM
Those are two of my favorite hammer pics Phil, the photography is amazing! I too am disappointed that Matt's hammer won't make this thread...
Forging an anvil with Bill Brown.
#478 Ric Furrer
Ric Furrer
    Junior Member
  • Members
  • 575 posts
  • LocationSturgeon Bay, Wisconsin, United States
Posted 24 September 2013 - 08:07 AM
Hello All,
Does anyone have the catalog for the Niles Bement Pond company? I'm curious about what they made and the steam hammers in particular.
Ric
Richard Furrer
http://www.DoorCountyForgeworks.com
#479 forgemaster
forgemaster
  • Members
  • 961 posts
Posted 02 October 2013 - 12:01 AM
For those of us that are power hammer, massey hammer nut/weirdos I have taken some footage that you all may wet your pants over.
2 ton massey clear space, (biggest clear space Massey made)
When you have someone say "oh so and so has the biggest powerhammer made", you can say," was it as big as this"
Be warned there is a rude word uttered in the video, (was not my doing) if you are to watch this around sensitive ears I'd turn the sound off.  Its not really obvious but still.  (mods if you can edit it out in here (IFI) feel free)
[media][/media]
Next time I hope to get it actually working in anger,(ie forging something)
The specs are weight of falling parts (ram) 2 ton, stroke 38 inches, dia of ram, 20 inches,  overall height of hammer 14' I", total weight of hammer 52 tons,  motor HP 160, blows per minute 80, blow energy 43000 ft-lbs bar size worked efficiently 13 to 22 inches square.
A truly awesome and beautiful machine.
Phil
#480 AndrewOC
AndrewOC
    Senior Member
  • Members
  • 382 posts
  • LocationSydney
Posted 02 October 2013 - 12:27 AM
Ah memories,
A.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
