5 Ton Benchmaster rebuild
ciladog
A few weeks ago I bought a 5 ton Benhmaster punchpress for under $150. The press was in pretty good shape but there were parts missing. The part that holds the 1" punches was missing along with the die plate. I figured no big deal and for that price I couldn't pass it up.
I took it all apart and did the electrolysis thing which I am hooked on now for cleaning up old machinery. It sure beats the old wire brush.
Today I started making the parts that were missing. The first was the part that holds the punches.
It started out as a piece of 1 ½ square that was forged to 1 X 1 ½ to make the blank. Then annealed and machined. The rest is history. Five hours of work on the forge, the mill, and the drill press.
post-3873-0-09642600-1338406207_thumb.jp
post-3873-0-05898800-1338406239_thumb.jp
post-3873-0-51089100-1338406265_thumb.jp
post-3873-0-18940900-1338406286_thumb.jp
post-3873-0-10187400-1338406317_thumb.jp
post-3873-0-69606100-1338406342_thumb.jp
post-3873-0-54819000-1338406373_thumb.jp
  • 2 weeks later...
Thanks Sam
You can definitely do hot forging on a punch press despite what some might say and here is how you can do Damascus.
Make two-step dies, that when closed gives you the thickness of the finished material and the width of the finished material. Attach the bottom die to a plate (say 5/8 “) and the top die to the ram. Adjust the press for maximum shut height.
Then make a bunch of step plates that you can put under the bottom die plate. Maybe 1/8 “for a 2 ton press. Each time you make a forging pass you just add another plate under the bottom die.
Hook the punch handle to a foot peddle and you have a press with 70-80 hits per minute. Just don’t make the dies too deep. It will take some trial and error. You do have to consider the maximum travel of the ram per stroke. But it can be done.
Oh, don’t you have something to make?
