kevin1050 Posted April 11, 2012 Share Posted April 11, 2012 Me and my friend are trying to save a firepot from a coal forge. It is broken in two and we need some help on trying to repair it, if it can. Any suggestions? Quote Link to comment Share on other sites More sharing options...
keithh999 Posted April 11, 2012 Share Posted April 11, 2012 Old cast iron is almost impossible to weld with nickel rods....even with pre and post heat they still crack and crackle into more pieces than you started out with!!....brazing is iffy unless you coat the inner pot with refractory.to help keep the heat down. Best luck ive had is with straps of mild steel being bolted across the cracks in several spot to hold it all together. prebend the straps to match the firepot radius and use grade 8 bolts. for the last forge i rebuilt i had a "donut" cut at my fab shop and using another forge dished it out to match the inside contour of the original pot and bolted in place. (see my rebuild post "whats missing on this forge " and "its not missing now" to see what im talking about. Good luck and i hope you manage to save the pot. Keith MMM Fab & Forge Quote Link to comment Share on other sites More sharing options...
Backwoods Blacksmith Posted April 11, 2012 Share Posted April 11, 2012 Straps with rivits or bolts. A very experenced welder and nirod Quote Link to comment Share on other sites More sharing options...
jmccustomknives Posted April 11, 2012 Share Posted April 11, 2012 For welding it, 3/32 nickle 99 rod. Preheat the iron, use short (1") beads 6" apart to help even out the heat. Normally peining is necessary, but that may cause further cracks and brakes. After you are finished bury it in something to slow the cooling rate (sand, ashes, vermawatsits :wacko: ). It's a 50/50 shot that you'll put it off. Those rods run 25 to 30 a pnd. Quote Link to comment Share on other sites More sharing options...
pkrankow Posted April 12, 2012 Share Posted April 12, 2012 Post pictures? Phil Quote Link to comment Share on other sites More sharing options...
VaughnT Posted April 12, 2012 Share Posted April 12, 2012 I wouldn't touch it with a welder unless you're really good. And even then you have to wonder if it would just be easier/cheaper to fab up a new firepot or buy one from Centaur Forge. Bolting straps across the crack and then covering those straps with fire cement would be the easiest, cheapest method, and would have a good chance of working. Quote Link to comment Share on other sites More sharing options...
kevin1050 Posted April 12, 2012 Author Share Posted April 12, 2012 Thanks for all the great advice. I think we will be going with straps secured with bolts. Just have to find a place to get grade 8 bolts. What would be better straps on the outside or inside? Quote Link to comment Share on other sites More sharing options...
pkrankow Posted April 12, 2012 Share Posted April 12, 2012 Outside straps. The bolt heads will erode over time, no avoiding it. Phil Quote Link to comment Share on other sites More sharing options...
kevin1050 Posted April 12, 2012 Author Share Posted April 12, 2012 Got it and thanks again for all the advice. When we decide to tackle this project I will post before and after pictures. Quote Link to comment Share on other sites More sharing options...
clinton Posted April 12, 2012 Share Posted April 12, 2012 You could use the metal straps and weld them on using 7018, keep it cool, make small welds one inch at a time and let it cool down before laying down another bead Quote Link to comment Share on other sites More sharing options...
Frank Turley Posted April 12, 2012 Share Posted April 12, 2012 John Neary, recently deceased, aka Cracked Anvil, told me that cast iron was an amalgam of sawdust, molasses, and baby caca. Quote Link to comment Share on other sites More sharing options...
Ten Hammers Posted April 15, 2012 Share Posted April 15, 2012 Still laughing......... Frank, you forgot a pitched quid of Red Man and some clinker for texture. Quote Link to comment Share on other sites More sharing options...
kevin1050 Posted April 15, 2012 Author Share Posted April 15, 2012 Well I got the Redman, kids are out of diapers, everything is do able. Maybe add some bublegum in the mix to hold it all together? lol Thanks guys for the advice! Quote Link to comment Share on other sites More sharing options...
mudbugone Posted April 15, 2012 Share Posted April 15, 2012 I'll be back shortly with a mix from an old blacksmithing source that might actually help you fix this ... From a long time back in an old blacksmithing archive article..IRON CEMENT A cement for stopping clefts or fissure of iron vessels can be made of the following: Two ounces muriate of ammonia, I ounce of flowers of sulphur, and I pound of cast-iron filings or borings. Mix these well in a mortar, but keep the mortar dry. When the cement -is wanted, take one part of this and twenty parts of clean iron borings, grind- together in a mortar. Mix water to make a dough of proper consistence and apply between the cracks. This will be useful for flanges or joints of pipes and doors of steam engines. Yet another formula...Iron-Rust Cement The iron-rust cement is made of from fifty to one hundred parts of iron borings, pounded and sifted, mixed with one part of sal-ammoniac, and when it is to be applied moistened with as much water as will give it a pasty consistency. Formerly flowers of sulphur were used, and much more sal-ammoniac in making this cement, but with decided disadvantage, as the union is effected by oxidizement, consequent expansion and solidification of the iron powder, and any heterogeneous matter obstructs the effect. The best proportion of sal-ammoniac is, I believe, one per cent of the iron borings. Another composition of the same kind is made by mixing four parts of fine borings or filings of iron, two parts of potter's clay, and one part of pounded potsherds, and making them into a paste with salt and water. When this cement is allowed to concrete slowly on iron joints, it becomes very hard. ******************************************* Below formulaThe following link might be better suited to your particular repair (scroll down to the mixture) Brimstone=sulphur & Black lead=graphite Cement For Cast-Iron Tanks - Cement For Heated Objects Cement For Cast-Iron Tanks The following is recommended for damaged places in cast- tanks, cisterns, etc.: Five parts brimstone, 2 parts black lead, and 2 parts of cast-iron filings, previously sifted. Melt together, taking care that the brimstone does not catch . The damaged place, perfectly dry, is well heated by laying a piece of red-hot upon it, and is then stopped with the cement previously heated in a melting ladle until it becomes Read more: cementrepairingironfireironsofthttp://chestofbooks.com/crafts/art/Artisan/Cement-For-Cast-Iron-Tanks-Cement-For-Heated-Objects.html#ixzz1s9Vy2WJH Quote Link to comment Share on other sites More sharing options...
