Hardox
  • Please log in to reply
17 replies to this topic
#1 Jeddly
Jeddly
    Junior Member
  • Members
  • 152 posts
  • LocationAnchorage, AK
Posted 06 March 2012 - 11:28 AM
I was asking around for some sheet steel for a sweet workbench, and a friend said he had a 4x8 sheet of this stuff called Hardox. 1.5" thick.
I've never heard of this stuff before, but did a little research, and it seems like some tough stuff.
I am having trouble finding an approximate weight on this stuff though. Any ideas?
Oh yea, its free.
There need be only one question you can ask yourself, 'How much of yourself are you willing to let others control'.
#2 ianinsa
ianinsa
    Senior Member
  • Members
  • 764 posts
  • LocationLa Lucia Durban South Africa
Posted 06 March 2012 - 12:14 PM
Nice product for wear surfaces, a XXXXXX to drill & grind,cuts nice with laser and plasma. not so sure of the effect of tack welds to face though.
I blown-away/like your price!
Noboby forgets where they buried the hatchet!
Fools wander and wise men travel.
#3 Jeddly
Jeddly
    Junior Member
  • Members
  • 152 posts
Posted 06 March 2012 - 12:29 PM
More reading reveals that its around 2k pounds. Holy heck! I really only wanted a 4'x4' table, but at a thousand lbs, methinks it may be a bit overkill.
#4 pkrankow
pkrankow
    Member
  • Members
  • 5,373 posts
  • LocationOhio
Posted 06 March 2012 - 12:40 PM
http://www.portlandb...ate-weight.html
It is a steel, so about 2000 lbs.
Good score. According to Hardox's website the stuff is moderately difficult to weld to requiring pre heat and such, but is weldable by all common processes.
Phil
Your brain is the most powerful tool you own.
#5 pkrankow
pkrankow
    Member
  • Members
  • 5,373 posts
  • LocationOhio
Posted 06 March 2012 - 12:41 PM
Maybe there is a new hammer frame in there...
Phil
#6 Jeddly
Jeddly
    Junior Member
  • Members
  • 152 posts
Posted 06 March 2012 - 12:55 PM
Well poop. Guy miss-measured. Its 8'x23'. And 11k lbs. Also 8+ hour drive away. Guess I'll keep lookin. :[
#7 bigfootnampa
bigfootnampa
    Senior Member
  • Members
  • 1,697 posts
  • LocationMissouri
Posted 06 March 2012 - 01:28 PM
Yeah I am sure that you'll find a better deal than that! Especially in AK! :rolleyes:
#8 r smith
r smith
    Senior Member
  • Members
  • 533 posts
Posted 06 March 2012 - 01:47 PM
Free??? If you had to buy it how much would it cost? How much time to go pick it up and what else does the guy have that he may give you while you are there?? That would make a great bench. Or cut in in half and have 2 4'x2' on wheels..... Free??? What are you waiting for my guess is that is at least a $1000 pice of metal probably more due to the alloy. Free???
#9 Jeddly
Jeddly
    Junior Member
  • Members
  • 152 posts
Posted 06 March 2012 - 02:58 PM
I have no way of dealing with an 11,000 lb piece of steel.
#10 pkrankow
pkrankow
    Member
  • Members
  • 5,373 posts
  • LocationOhio
Posted 06 March 2012 - 03:21 PM
Yea...1 ton is fairly easy to manage, can be pulled on a fairly regular trailer behind quite a few common vehicles. 5 tons is a different story...still not outside the realm of doable, but a whole lot less easy. If you had the truck and the gumption you can probably rent a capable equipment trailer for a couple days for not too much money.
8 hours round trip or one way?
Phil
#11 ThomasPowers
ThomasPowers
    Senior Moment Member; Master Curmudgeon
  • Members
  • 13,708 posts
  • LocationCentral NM
Posted 06 March 2012 - 03:41 PM
I remember attending an auction where they were trying to take *any* bid on a 3x8 table with a 2" thick top. The problem was that it was constructed in place and so would have to be cut apart to get through the door.
Thomas Psychotic Psychobabblonian Powers
#12 HWooldridge
HWooldridge
    Senior Member
  • Members
  • 2,622 posts
  • LocationCentral Texas
Posted 06 March 2012 - 07:01 PM
.2833 lb/cu inch...take a torch along and cut a piece in the size you want!
www.comalforge.com
#13 Jeddly
Jeddly
    Junior Member
  • Members
  • 152 posts
Posted 06 March 2012 - 09:23 PM
Its 8 one way.
#14 Thomas Dean
Thomas Dean
    Senior Member
  • Members
  • 2,397 posts
  • LocationHallsville, TX
Posted 06 March 2012 - 10:24 PM
Rent a track torch once you get there and cut off what you want or as much as you can haul. Return track torch and smile all the way home!
GOD is Good, ALL the time!
Member: ABANA, SCABA
http://www.pineconeforge.com
#15 Tim McCoy
Tim McCoy
    Member
  • Members
  • 474 posts
  • LocationLas Vegas, NV
Posted 06 March 2012 - 10:37 PM
Find a partner who will help cut and haul for all but a 4x4' piece :P
My Heart is a Silent Harp,
Played by Other Lives,
Tuned by Changing Needs,
With an Audience of One.
T. D. McCoy'82
#16 tomhw
tomhw
    Senior Member
  • Members
  • 152 posts
  • LocationBaton Rouge, Louisiana, USA
Posted 06 March 2012 - 11:20 PM
Hay, Rusty!
Jeddly, ask Rusty about his big table and how he moved it.
Measured with a micrometer.
Marked with chalk.
Cut with an axe.
#17 Ten Hammers
Ten Hammers
    Old fat guy with the pliers
  • Members
  • 1,298 posts
  • LocationBloomfield Iowa U.S.A.
Posted 07 March 2012 - 03:23 AM
Actually I have welded a bit of Hardox. Grind the millscale and pull the trigger. 3 and 6 pass stack welds. Some welds 8 feet long (single pass, 5/8 fillet). Welds lay out like a saddle on a sow. Car crushers. Landfill compactors. Pulse Mig. Don't try to drill it. I couldn't make the grade (to my own personal satisfaction) and I left to weld at another place. Most of my gouge skills were learned on Hardox. From 3/8 to 1 1/2" torch cut, formed, rolled and so forth. A Norton cup wheel skates on it unless you get rough and bear down to remove scale before welding. Free is good but that is a long drive.
" It ain't real if it ain't forged "
You can't clear the water till you've got the pigs out of the creek.
#18 pascalou
pascalou
    Senior Member
  • Members
  • 118 posts
Posted 08 March 2012 - 06:01 AM
hello
language selection at the top of the page :http://www.ssab.com/fr/Brands/Hardox/
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
