FieryFurnace Posted December 13, 2011 Share Posted December 13, 2011 It's been two years or so since I bought the Ray Clontz/Clay Spencer tire hammer plans. I've taken two classes with Clay since then and talked to him a bit about the hammer. I even bought my anvil post and backbone. I just haven't had the time to build the tire hammer. I was able to purchase the Ron Kinyon style air hammer from Phillip Patton of Patton Blades in Fort Wayne Indiana, and have used it quite a bit. A while back Clay called me and I mentioned the tire hammer in passing. I mentioned having already purchased my anvil post and he asked how much I got it for and if I could get more. Long story short, he put me in touch with the coordinator for a hammer build in Chapel Hill, North Carolina. I was able to obtain anvil posts for the entire build of 19 hammers. The posts were 6 1/2, 7 1/4, and 7 1/2-inch round and two six-inch square posts. I also built all of the treadles for the hammers. Anyway, I got to attend the build this past weekend and of course, got a hammer. I got "number 16" so mine is hammer #366. I'll try to get more pictures of the build and the hammer in the shop. I'm going to get the hammer unloaded tomorrow and then I'll be out of town again for a while. I'll position it when I get back in town. For now I just need to get it off and put it in the shop. Anyway, that's the latest and greatest at the Fiery Furnace Forge Blacksmith LLC. Quote Link to comment Share on other sites More sharing options...
petere76 Posted December 13, 2011 Share Posted December 13, 2011 Ho rah...Job well done. Great hammer build and all the best from #343. Peter Quote Link to comment Share on other sites More sharing options...
FieryFurnace Posted December 13, 2011 Author Share Posted December 13, 2011 here are a couple pictures of the build! Me and a guy I knew were placed on the drill press and drilled all the holes for the lower die screws. That alone took us a day and a half. Grub time! Quote Link to comment Share on other sites More sharing options...
Francis Trez Cole Posted December 13, 2011 Share Posted December 13, 2011 looks like a good time and a production line. Wish I knew you were going could have hooked you up with a place to stay my son lives there. Quote Link to comment Share on other sites More sharing options...
FieryFurnace Posted December 13, 2011 Author Share Posted December 13, 2011 We got it off today! I took it up to the steel yard and they used one of their lifts to put it on our trailer. We then used our animal hoist that fits in the truck hitch to lift it off the trailer and place it on boards with rollers. Since I am on gravel, dad and I put 1x10 boards down and then used 1-inch round bar as rollers. This is the anvil post and bottom die! We went with professionaly heat treated S-7 dies. Additional dies were $20 a set, but I have a lot of 4140 stock that I can make more dies out of. The post on my hammer is either 7 1/4-inches or 7 1/2-inches. The base plate is 2-foot square and 3/4-inches thick. Quote Link to comment Share on other sites More sharing options...
John B Posted December 13, 2011 Share Posted December 13, 2011 Nice looking machine there Dave, Did you weld the plate to the wheel with the tyre on or off the rim? Quote Link to comment Share on other sites More sharing options...
IronAlchemy Posted December 13, 2011 Share Posted December 13, 2011 I did the plate welding and we did it with the tire broken loose from the rim, wedged back with wooden wedges to keep it away from the heat, and the gap filled with wet rags. I know we have some pictures of it but they have not been posted anywhere yet. - Doug Quote Link to comment Share on other sites More sharing options...
Grant Posted December 13, 2011 Share Posted December 13, 2011 I was able to obtain anvil posts for the entire build of 19 hammers. The posts were 6 1/2, 7 1/4, and 7 1/2-inch round and two six-inch square posts. Dave -that is an impressive array of hammers. Are the anvils nested tube (6 1/2, 7 1/4 and 7 1/2)? I need to come up with an anvil for a treadle hammer and these look slick. -tks grant Quote Link to comment Share on other sites More sharing options...
FieryFurnace Posted December 14, 2011 Author Share Posted December 14, 2011 We did weld the plates with the tire still on the rim. They did it just as Doug said. Tire broken loose and held back with wooden wedges, then wet rags between the rim and the tire. 19 tires welded and no explosions......at least none that the weld team confessed to! Doug? The anvils are solid, which is recommended for power hammers and some treadle hammers. The tire hammer plans call for a minimum of 6-inch round or square material. The three measurements I gave were the size solid material I was able to obtain. The availability of that type material at my steel yard is spotty, so I picked up what they had which was 6.5-inch, 7.25-inch, and 7.5-inch solid round. The guys on the frame assembly teem just had to deal with the differences. Having said that, the Kinyon air hammer I own is made from large round tubing with something like 1.5-inch wall thickness. It is filled with sand. It has a 60 pound ram on it, and there is no sign of failure in the anvil post. I would ALWAYS recommend solid though. Extra mass = better hammer! I delivered all of the posts to the build location 11 hours away, payed a hefty cut fee to have these sawn to length, and when it was all said and done, the material cost the class a total of 45 cents per pound. (Covering material, travel, and time.) That was less than half of what the next cheapest option was. I don't know what happened to my pictures but I don't have time to fix them now! Quote Link to comment Share on other sites More sharing options...
Spears Posted December 14, 2011 Share Posted December 14, 2011 Hello Dave, Beautiful machine. It looks as maintenance free as anything could get. It's good to see your arsenal of equipment increase so well. I don't think anything on that is going to wear out very soon if ever at all. It looks like all of you had a good time at that workshop including everyone taking a hammer home. Thanks for showing the pictures. It is very inspiring. Spears. Quote Link to comment Share on other sites More sharing options...
Grant Posted December 14, 2011 Share Posted December 14, 2011 I delivered all of the posts to the build location 11 hours away, payed a hefty cut fee to have these sawn to length, and when it was all said and done, the material cost the class a total of 45 cents per pound. (Covering material, travel, and time.) That was less than half of what the next cheapest option was. At-a-boy Dave. Nicely done! -and thanks for sorting out the different diameters of anvil posts. -grant Quote Link to comment Share on other sites More sharing options...
FieryFurnace Posted December 18, 2011 Author Share Posted December 18, 2011 Oh it looks like my pictures are back up! Thank for all the comments guys. I'm in Florida right now, with limited internet access. When I get back in town, I've got a bunch of pictures to sort through and I'll post some of the highlights! 'Till then! Quote Link to comment Share on other sites More sharing options...
FieryFurnace Posted December 30, 2011 Author Share Posted December 30, 2011 I poured a smalle concrete pad for the hammer today: three feet by four feet. It is six inches thick and I used rebar reinforcements. I drove nine pieces of rebar two feet in the ground and then put six pieces, criss-cross suspended in the center part of the pad. Hopefully it will be stout enough! Quote Link to comment Share on other sites More sharing options...
BM454 Posted December 31, 2011 Share Posted December 31, 2011 That pad sould be more than enough to hold it. It may crack with time due to the hammering but still should be strong enough to hold the hammer for many years. Scott Quote Link to comment Share on other sites More sharing options...
FieryFurnace Posted January 2, 2012 Author Share Posted January 2, 2012 Hopefully it will be! I may actually be able to pour the entire shop pad before too much longer. That'd be nice! It's been curing, but rather slowly. I had three good solid days with the weather above freezing, but it's turned cold again. It's set up enough to put the hammer on it, but it needs more time before I use the hammer. Quote Link to comment Share on other sites More sharing options...
Jacques Posted January 2, 2012 Share Posted January 2, 2012 It's set up enough to put the hammer on it, but it needs more time before I use the hammer. Recommended waiting time for concrete is 28 days/ 4 weeks to cure properly. Quote Link to comment Share on other sites More sharing options...
FieryFurnace Posted January 5, 2012 Author Share Posted January 5, 2012 I've got the hammer up on the pad, and posted some pics down in "Shop Tips 'N Tricks."http://www.iforgeiron.com/forum/21-shop-tips-n-tricks/ Quote Link to comment Share on other sites More sharing options...
musk-rat Posted January 5, 2012 Share Posted January 5, 2012 Could you send me some information on the class you took? I would be interested in build myself one:) Quote Link to comment Share on other sites More sharing options...
divermike Posted January 5, 2012 Share Posted January 5, 2012 well done, I was able to take a hammer class a couple years ago, I got number 300!! Clay is a great guy and my hammer has held up very well, just one weld on the switch box broke, and one set screw fell out on the upper arm assembly, watch for them loosening up! Clay also has a tool schematic on this site I posted somewhere, tools..egad..must have more!!! Quote Link to comment Share on other sites More sharing options...
FieryFurnace Posted January 5, 2012 Author Share Posted January 5, 2012 Clay is starting to teach tool making classes for the tire hammer. I don't have any details on those though. He is or was supposed to teach the first one somewhere in TN. I THINK! Don't quote me though! LOL I'll send you a PM musk-rat! Quote Link to comment Share on other sites More sharing options...
David Gaddis Posted January 10, 2012 Share Posted January 10, 2012 I am interested too, if available. Please pm me. Tn is travelling distance for me if the timing is right. Quote Link to comment Share on other sites More sharing options...
Vergatario Lopez Posted January 22, 2012 Share Posted January 22, 2012 saludos a todos los forjadores de esta pgina estoi en la busqueda de un martillo estilo rusty pero no cuento con una gia o plano le agradeseria cualquier ayudaSpanishgreetings to all the forjadores of this pgina estoi in the search of a hammer style rusty but nonstory with one gia or plane him agradeseria any aid Quote Link to comment Share on other sites More sharing options...
dkunkler Posted January 23, 2012 Share Posted January 23, 2012 Try this link http://www.appaltree...rusty/index.htm Spanish Intente este acoplamientohttp://www.appaltree...rusty/index.htmhttp://www.iforgeiron.com Quote Link to comment Share on other sites More sharing options...
FieryFurnace Posted January 25, 2012 Author Share Posted January 25, 2012 So today I got the hammer bolted down using 1/2-inch expanding anchors. They are about 3-inches deep in the concrete. So far, after pounding out a pair of tongs, everything is still solid. General overview of the forging station. Pretty much a 10x14-foot area. The tire hammer in place, turned slightly, as Mr. John B suggested. (which does make it faster and easier to get to.....good idea!) I used four layers of school bus rubber matting under the hammer. After the bolts were tightened, it ended up being about 1/2-inch thick. A happy blacksmith. I've made an edge of the anvil tool for it so far. I'll be making lots of tooling for it as the need arises. I'm still trying to figure out how to move the air hammer over a bit. That's not going to be fun! Quote Link to comment Share on other sites More sharing options...
HWHII Posted January 25, 2012 Share Posted January 25, 2012 Your shop is shaping up very nice. Can't help but notice the flamable material under the bench and on the ground near your welding table. Beware! I am speaking from experience here. ;) Quote Link to comment Share on other sites More sharing options...
